28
Everything posted by HOrnbrod
^^^ Agree. If the 91 has been "beat to gel" as you say, get under it and really go over the unibody, frame, and suspension components. Sheet metal is easy to replace; repairing undercarriage problems isn't. And if you do decide to repair the 91, please lose the stupid front bumper and light bar on the hood. That stuff is okay on a Renix, but not an HO. :thumbsup:
Ignition wiring intensification help?
HOrnbrod replied to DirtyDeeds's topic in MJ Tech: Modification and Repairs
Factory Service Manual. You can download it here: http://comancheclub.com/topic/12083-electrical-manual/ -
You need to invest in an 88 electrical FSM........... -
Distributor timing. PLZ GAWD HELP!!
HOrnbrod replied to XJs4Ever's topic in MJ Tech: Modification and Repairs
http://tomasz.korwel.net/2006/12/19/replacing-ignition-distributor-in-jeeps-40l-engines/ -
How do you know? Ever look at them using an A/F meter over varied conditions?
The "703's" are optimal according to my A/F meter for my stroker engine also. I run them at 49/39 psi.
I put a 136A alternator in years ago and it required no cutting or grinding on the bracket. It was tight getting it to squeeze in, but it fit. Others have reported slight bracket grinding was required; mine didn't. And the plastic piece doesn't need any trimming; just needs to be reclocked. That will be obvious when you reconnect the wiring harness to the new alternator. The "fast idle" option switch applies a ground to ECU pin 30 on the HOs. You can't do it with the 91 and 92 4.0 models, as ECU pin 30 doesn't exist on these models. Might work if you swap in a 93 or up ECU or open up and modify the stock ECU.
Good troubleshooting article for 2.5 TBI HERE. I'd start with a fuel pressure test with engine running.
Carb or TBI? Can't tell in your pic.
What Brand starter should I buy???
HOrnbrod replied to fire797's topic in MJ Tech: Modification and Repairs
For what?? -
Pretty confident? :rotf: Buy it or don't. I say don't. Eventually you'll find a complete shell for far less than $500.
comanche overheating at highway speeds
HOrnbrod replied to Newton's topic in MJ Tech: Modification and Repairs
I put one of these FFD radiators in almost eight years ago. Haven't run hot since. I used to use Modine radiators. They used to be one of the best you could buy. Now all they make (or have some foreign outfit make) for our trucks is a $100 aluminum single core unit with plastic side tanks. Probably a C.R.A.P. too. :shake: -
http://ffdynamics.com/products/jeep-cherokee-aluminum-radiator -
4.0 Backfiring, stuttering, and misfiring
HOrnbrod replied to Spydie's topic in MJ Tech: Modification and Repairs
:thumbsup: Too bad Chrysler didn't make a FSM set for the XJ/MJ vehicles only instead of having to wade through all the 91 YJ and SJ stuff I don't need. Learning to navigate the FSM's takes some time, but it's a lot better than doing guesswork without them. -
That's about the average price for a set, although quite often they go under $50. -
CSF. Chinese Substandard Fabrications......... -
Mnkyboys 89 Comanche project
HOrnbrod replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I'm skeptical of that 4-6 hour install time, but i'm also not the worlds most competent tech so heh, still a cool looking kit though. Yep, I think it could easily double that time, especially since for the side mount you have to pull the intake manifold and hardwire the controller into the ECU harness.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Idiot light clusters have different flex circuit boards than the 4-gauge and 6-gauge clusters, and the foils are not interchangeable unless the part numbers match. I have a stack of foil circuit boards left over but unfortunately all are for HO clusters. The blue housings for the various types of Renix era clusters all carry different p/n's, and I don't know if they are interchangeable or not. Bridging torn foil traces for repair is quite easy using short pieces of ~22AWG or lower stranded copper wire. Just tin each wire end, scrape the varnish off both sides of the foil break down to the copper using an Exacto (sp?) knife, then solder the wire bridge across the break.
Invest in a Factory Service Manual set. Best friend you will ever have. -
Genssi 80W CREE LED White 1156 Reverse Lights
HOrnbrod replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
No, I don't have an LED replacement guide. I used the trial and error method and really didn't have many errors. Just stay away from the cheap "off-shore" LED junk. I used the Superbright site for most all of the LED stuff. -
How much boost do you think will happen when everything's hooked up and tuned? Maybe 5-6 psi? I'm looking at THIS kit - no hood cutting. And only $3K. :ack: The wife will kill me, but that's nothing new. :yes:- 798 replies
- 2.5l
- supercharged
- (and 7 more)
