A-man930
    3
Everything posted by A-man930
  1. *sigh* if only they offered a selectable locker for the 8.25...
  2. Guess I never really knew foglights were meant to cast to the side (never had a car/truck with them.) I would still be interested to see how regular projectors would work down in the bumper, not as "foglights," but headlights. If they're aimed correctly I don't see how they could be anything but an improvement and could be left on during normal on-road use. Additional lights for off-road (or occasional deserted road :brows: ) use would obviously be good, especially for the side casting.
  3. Just had a thought for those of us with (or considering getting) an aftermarket front bumper. Why not use HID projectors as "foglights?" The cutoff point would be diffused by standard headlamps in the factory position (would have to match color temp.) Oncoming traffic isn't going to mind, as the bumper sits nice and low. Thoughts?? Sorry to hijack...
  4. I've been told NOT to use GL5 as the sulfur content is no-good for the brass syncro rings... My rebuilder recommended 5w30 engine oil (synthetic.)
  5. Yea but it aint just looks... I'm thinking camping.
  6. Hmm, how many counterweights on a '79 crank??
  7. So the brights are that much better huh? I do like that... In reference to this writeup: http://jeep-xj.info/HowtoBiXenonProjectors.htm I guess I'm not convinced I'd be happy with the results. Believe me I'm normally all for a DIY alternative to expensive and/or unavailable commercial offerings, but there are some things I question. 1) Integrity: Will this now swiss-cheesed housing be likely to warp/crack when shook to death in an off-road environment? What will happen to all that foil tape when its repeatidly exposed to engine bay heat cycles, water, mud, and whatever else manages to get flung onto it (i.e. burst p/s line) Is it gonna continue to hold the projector in that just-right position?? 2) Appearance: Will this home-brewed lexan front cover become all hazy and gross over a few years and after a few mudbaths? Is this foil tape seal gonna actually keep moisture and contaminates out of the housing? I'm sure someone on here can vouch for some of these concerns but in my mind there are some things that arguably are better suited to be produced professionally with oe-like tolerances etc.
  8. I don't know about anybody else but I don't like the "cutoff" line that HIDs give you...
  9. I had a heck of a time trying to get a plug to thread into the egr port in the manifold. So much so that I ended up just cutting the tube, crimping it, and welding the seam shut. Works like a charm :clapping:
  10. I keep meaning to take mine apart and see what is actually "worn." Nothing worse than thinking you can rely on the parking brake :fs1:
  11. lookin good!! I'm also in the "can't spend too much time on my play toys" camp. Priorities man, but we can still have our fun :thumbsup:
  12. Checking in from Warrenton, MO. I know there are other MO MJs on here! I'd like to join in on a wheelin' trip with some other mj guys but the funds just won't be around for another 18+ months :ack: Just a meet and greet would be a good time I'm sure. I know some good bars in the westplex! :cheers:
  13. I've heard that its actually not too uncommon to over time see the unibody sheet seperate from the stuff welded in. I'm wondering if it would be feasible/better to run supports inward to the frame for the entire length of the slider? Instead of only past the cab, as you say. What I'd like is some more cut-away pictures of the section of floorpan outside the "frame rail" as viewed from the interior. or I just need to get into one and start cuttin!
  14. Subscribing :popcorn:
  15. i'd go with at 242 if there were a terra-low kit for it :(
  16. I've heard the same thing. This is the route I would go if I had an '86. The GM 3.4 is a very reliable, simple, and cheap replacement for a 2.8 (which isn't really all that bad to begin with.) You can probably even keep your oe intake/exhaust.
  17. Simplicity is king. Question becomes is it adequite?
  18. I used silicate sand... and I now have a horrible disease!! ;)
  19. Thanks for the info everyone. I'm gonna keep my eyes peeled for someone parting out a 2wd MJ so I can get those leaves. Then some 6.5" coils up front to bring it to about level. I'll go budget and go without the ACOS or adjustable shackles. JeepNewb, I was looking around on Barnes4wd site and I like their axle swap combo kits. Any other good perches out there?
  20. Ugh, you guys are gonna talk me into a 6" lift aren't you? Keep it up and I'll cave, lol. I'd like the truck to sit level, and I'd like to have good street manners coupled with better performance in the rocks. I'm fairly firm on 33" tires, everything else is up for grabs. I like the idea of nearly infite adjustability with the IronMan4x4 shackles and the JKS ACOS, but I know its best to be close to what you want (with springs) and then fine tune after. So Garvin, you only got 4.5" from the SOA? With 2wd or 4wd springs? Or were they bastard packs? Whatever I do, It sounds like I should start with the rear lift and then choose what to do up front. Agreed? Too many options is a good thing right!? :wrench:
  21. I've already got my wheel wells cut out quite a bit. Idk, maybe I'm just worrying about it too much. :dunno: Already got a JKS trackbar, looking at UCAs, LCAs, and quick discos from JKS as well. I guess I'm not interested in going all the way to 6-6.5" in lift becuase I don't want to be at the outer limits of a shortarm suspension...
  22. Haha, figured that's what you meant. So I think I'll start looking for some 2wd springs and go with some 4.5" coils with some JKS ACOS spacers for the fine-tuning up front. Thanks!
  23. Yes what? Bad idea??
  24. I don't know what it is, but I sometimes wish I had a 2.5. Maybe I need to check my testosterone levels :rotf:
