3
Everything posted by A-man930
Wanting metal Tail light boxes? Possible group buy?
A-man930 replied to brimy311's topic in MJ Tech: Modification and Repairs
COUNT ME IN!! take a pair for sure edit. most recent list I saw: 1.)Cdn Glenwood 2.)pingpong (with bed sides if possible) 3.)88pioneer 4.)dakal 5.)Raoden83 6.)DJM/78 7.)possum 8.)Jpnjim (either style/bedside preferred) 9.)jimoshel 10.)89eliminator 11.)Cracker 12.)Cracker (set number two) 13.)Blue XJ 14.)RandysMJ (either style) 15.)Jeepcomj (One Set) 16.)exjay33 17.)A-man930 -
Anyone looking for bed-side Patch Panels?
A-man930 replied to jpnjim's topic in MJ Tech: DIY Projects and Write-Ups
Any pics of the pieces or info on what's going on with the 6ft bed situation??? -
Here's another 6' bed guy interested :brows: -
Might want to consider your throttle position sensor as the culprit.
School me on shortarm v.s. longarm lifts
A-man930 replied to A-man930's topic in MJ Tech: Modification and Repairs
Gonna revive this thread. After another wheelin trip I've decided against anyting that hurts what ground clearance I have, so drop brackets are out. I was looking around this thread viewtopic.php?f=2&t=19871 and I'm very interested in the Clayton radius arm kit. It looks tough as nails and dead simple, only thing is I don't know the upsides/downsides of a radius arm versus the others. This isn't the "y link" that everybody's been bashing in this thread is it? -
If you're interested I've got a driver's side from my '90 thats in decent shape...
another PM sent :)
All inclusive Long Arm upgrade thread:
A-man930 replied to jpnjim's topic in MJ Tech: Modification and Repairs
nice writeup :cheers: -
See I have the opposite problem, my horn likes to honk itself :rotf: I've replaced the relay thinking it was the problem, so I'm thinking its the switch itself
I'll see if I can hunt down tha wiring diagram...
I hesitate, but here's another brake system thread
I understand. So that leaves the warning switch as the only reason not to just use a tee (I'll check on the legality of that here in Missouri.) The extra work isn't really a concern as I was planning on cleaning up the whole mess of brake lines I've created with the '96 booster/MC swap I did over the summer. My main concern revolved around wether there was any metering done by that block. -
The supposedly is in refrence to the cutaways I've seen on here that don't have the port drilled completely through... Point taken. I guess the only reason I was toying with that idea is due to my worries/concers after seeing those nasty cutaways... what else is wrong with this thing??? Thanks for the imput BTW :D -
Brake Lines...need suggestions
A-man930 replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
:typing: Your not new here.........are you??? :rotfl2: :popcorn: no not new, just not being very observant I guess! :rotf: -
After realizing the rather large amount of confusion surrounding our trucks' braking systems, I've decided to hold off on my own endeavor untill I have a few issues clarified. 1. The junction block up by the master cylinder... does it preform any proportioning functions? or is it basically a glorified Tee connection with a fancy safety feature? (the extra line going to the rear that supposedly bypasses the rear height valve in the case of front brake failure) 2. If this thing isn't any more than a junction, is there any reason I can't just replace the thing with some Tee junctions? I was planing one Tee to divert direct MC pressure to the two front calipers, and then plumbing an adjustable prop. valve into the rear line prior to diverting it to the wheel cylinders on each side. Am I missing anything here??
wow, I'm just now realizing how much of a can of worms this height sensing valve issue really is... -
Well I definately could be wrong on that. My point was aren't there many many pickup trucks out there that didn't use this type of system? -
I just purchased two 25' spools of poly coated 3/16" brake line, an adjustable prop. valve, and all the necessary tube nuts/tees to replace all my 19 year old potential truck-crashers. I don't believe any other light trucks have used a height sensing valve and they work just fine. I'll just set up my prop valve on a gravel road somewhere to get the brakes to lock up together. Plus when I'm wheeling I can re adjust them to nearly the same as the fronts. oh and I got a double flaring tool kit for $30... who loves employee discounts?! :D -
EXO cage tree protection...
A-man930 replied to CWLONGSHOT's topic in MJ Tech: Modification and Repairs
subscribing -
I need a fuel sending unit
A-man930 replied to lostissues's topic in MJ Tech: Modification and Repairs
I sent my pump module off to get rebuilt... I haven't installed it yet but it looks like it'll work great. http://fuelsender.com/services.html $130 or so, and its been cleaned, re-tubed and sealed, painted (with the correct stuff inside and out), had the wiring and level sending unit checked/repaired, and has a lifetime leak guarantee. -
wheel stud knurl interference question
I'm not too worried about breaking the stud so much as I'm worried about trying to press one that is too big in diameter into the hub... Read Blue XJ's post, this is what I want to avoid. -
update, more precise measurment is .597 to .598 -
I've got a set of Superior axleshafts and an Aussie locker for my 8.25 sitting under my bed right now, and the only thing holding me up is a little confusion on what I should do as far as wheel studs. I initially wanted to spend a couple extra bucks and get some super-duper-never-break-never-ever studs from ARP, but they didn't have anyting by application, so I called them. The dude on the tech line told me that he didn't have anything with the correct thread pitch, shoulder length, or knurl diameter available to purchase directly from him. The part that caught my interest was what he told me about the knurl diameter. I measure from .575" to .600" ID on the hubs of my new shafts. Stock replacement studs from NAPA are .615" knurl diameter. This ARP guy strongly suggested that I go no bigger than .605" knurl diameter so not to risk splitting the hub... I called Superior, he said beat in some new stockers... what do the ever so helpfull experienced dudes on here say?
I vote you go find an XJ 8.25. I got mine for a hundred bucks or so, muuuuch better than a 35
Rear Fender Flares Needed for my 88 Comanche
A-man930 replied to moconnell's topic in MJ Tech: Modification and Repairs
Well I'm in St. Louis so PM me if you're interested.
