3
Everything posted by A-man930
Thanks for the replies! To the questions as to weather I could get things clean enough, I think the acid dip is dessigned to take care of any residual rust/grease, and it sounds like this is a standard pre-dip step when galvanizing anything. I'd obviously need to get as much as possible off with sandblasting or whatever. I didn't realize this. Why exactly is this true? I was considering sandblasting, welding, acid dip, then galvanize... explain. My real concern revolves around the cab being able to take the heat of the process and not warp or anything weird like that.
Comanche forever? So I found out that one of my customers can hook me up with galvanizing services, I really want to ask him if he'd be able to do something as big as my cab/frame. But before I bother him I thought I'd ask around here to get some opinions. I know it would have to be stripped down to nothing, be pretty much free of dirt/rust/paint, and I'd have to be pretty well done with any welding to the chasis. I can't see why this wouldn't be a great investment, as the truck is virtually rust free right now. What better way to preserve it?!
subscribing
battery cable?? could have lurched the motor hard enough to short out the pos cable to the starter.
I can confirm that the renix intake manifold will bolt right up to the HO head and the engine will run (everyday :D ) No the ports don't line up just right, but it does run and there's no fabrication required. Obviously this is a less-than ideal setup, but if you're not up to the fabrication of adapting the renix tb to the HO intake, or the wiring headaches of swapping both the dash harness and the engine bay harness, then this would be my suggestion.
i don't have a pic, but I got some weatherproof ones here at work (NAPA) and besides making your butt sweat ALOT they're great :D
Immediate clutch help needed!!!!
A-man930 replied to streetjeep2.5's topic in MJ Tech: Modification and Repairs
sounds like a master to me. The fluid is bypassing the piston seal. -
dayum... :drool:
Bwhahahaha! love it :D
Leaf Spring Replacement
A-man930 replied to Kenosha Warrior's topic in MJ Tech: Modification and Repairs
x2 on a specialty spring shop, St. Louis Spring is where we send our customers. My buddy is gonna send them his stock springs for his '70 IH 1200 pickup to be re-arched because no one makes a replacement set off the shelf. They'll do basically anything you want as long as its safe and you know they've got the experience to do it right. -
explain...
Preferred Oil for our "older" engines???
A-man930 replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
Correct :cheers: -
Yea don't ask me, I just find it interesting they're advertising it this way. I'll call today and see what the deal is. -
Per Valvoline: 1.Valvoline VR1: Contains 75% higher zinc than SM motor oil with a balanced additive package designed to work in both racing and street-legal applications. This product will protect older style push-rod and flat tappet engines. Valvoline provides this product in both multi and mono viscosity grades: 20w50, straight 50, 10w30, straight 30, straight 40, and straight 60. 2.Longer-Lasting Zinc/Phosphorus: Valvoline uses an advanced zinc/phosphorus additive that keeps higher levels of phosphorus in the motor oil where it protects the engine instead of poisoning the catalytic converter. Valvoline is the only brand offering this unique additive across its entire line of passenger car motor oils including SynPower -- the only synthetic offering this additive. Granted this is from a manufacturer's mouth. Worth investigating. -
I was mainly interested in his explanation of viscosities and how they relate to a xW-xx labeled oil, as well as his explanation of synthetic v.s. conventional oils. But yes if you read the whole thing he definately blows off the whole notion that a "new" oil formulation could in fact be bad for an old engine (it sounds as if the article was written before the latest API rating...) The more I research this topic the more I seem to find, again, who knew there was so much to it!? :eek: I definately am sold on using synthetic oil in any vehicle I own, and now with a better understanding of motor oil viscosity ratings I am very hesitant to run anything rated 15Wxx or even 10Wxx for that matter. Unfortunately pretty much all diesel oils seem to be rated as such. This leads me to believe that an additive may really be the best way to go (so far...) -
http://www.ferrarichat.com/forum/faq.ph ... s_articles I just ingested this the other day. Who knew it could be so complicated!? Upon reading this article I'll be changing to the 5w30 or possibly a 0w30 of a different brand with a ZDDP additive. That being said I currently run Valvoline "Not Street Legal" 10w30 racing oil. This was suggested to me by the Valvoline product rep during a training session at work (NAPA). He says it has "higher levels" of zinc that the old hot rodders coming in to the store would be asking for. I just sold some to my buddy with an old IH 304 and will be carrying some in the store from now on. However, upon further investigation it seems that its lack of detergents is a problem for a street engine... here's the valvoline info pages. http://www.valvoline.com/products/consu ... otor-oil/9 http://www.valvoline.com/faqs/motor-oil/racing-oil/ So it seems SYN power, "not street legal," or VR1 racing all have adequate levels of zinc and phosphorus for our engines. -
Doh! :doh:
I call first dibs on the bellhousing when you're selling it!
I have the same thing happen in my truck. And I also have an NP231 from a later model XJ. I have heard there are some issues with the splines from different years
Need a little help on replacing some hard lines
A-man930 replied to Backroads's topic in MJ Tech: Modification and Repairs
The more hard line the better IMHO. It doesn't rot on the inside like rubber will eventually, it isn't pinched or cut easily, and most of the steel line available at the parts stores is coated so its not gonna rust away instantly or anything. Plus if you're replacing any part of the high pressure line from the pump you shouldn't use plain old fuel hose as its not rated for the kind of pressure fuel injection pumps put out. Dedicated fuel injection hose is the correct way to go and its easily twice as expensive. I'd just use sections of hose for the connection to the fuel sender and up to the rail and keep the rest steel. Of course hose is much easier so its your call :waving: -
Installed 2005+ Dakota Bench (Pics Inside)
A-man930 replied to comanche09's topic in MJ Tech: Modification and Repairs
the part I'm most intrigued about is that center console... :idea: -
Anyone looking for bed-side Patch Panels?
A-man930 replied to jpnjim's topic in MJ Tech: DIY Projects and Write-Ups
This isn't a deal breaker for me or anything, I was just getting my hopes up on having a simple one piece deal that I could maybe even tackle myself. Now it means I'll have to enlist some help from someone who knows bodywork, but I'll still end up with new clean bedsides that aren't all hacked up and dented in from too many close encounters with trees :brows: No, definately not a deal breaker. -
If you're comfortable doing brake lines you're well suited to handle fuel lines ;) With fuel you can see a leak without even starting the truck. -
Is anyone else a little dissapointed with the taillight end of the piece? I guess I was expecting it to do that last curve inward right above the taillight :( Don't get me wrong I'm thrilled to have anything at all its just gonna be harder to get that part straight on mine now.
