Things are coming along.
New panel for the top of my summit heater unit, bit of alloy welding.
Some pretty powder coating.
Playing with solid rivets, made a little cone filter cover, cuts down on the noise a little bit.
Rear shock and bump stop setup is killer, I can wind out third off road and it feels amazing. My friend and I took it down a trail after it was back together and we were giggling like little girls at how awesome it was taking bumps.
Stepped up my hydraulic e brake master size to .75" and it works great, seriously want one in everything I own. Such a handy little device.
Took it to Granite State Dyno today for a tune. It has been rather flat and I thought it was due to the poly motor mounts causing the PCM to pull timing. The PCM that was in the truck was tuned with EFI live and wouldn't take a HP tuners tune so I ran down the street to a junkyard and picked one up for $50, the joy of having a common vehicle. Got a tune in the ol bastard, still wondering where all my horses are though. I used a VSS from Jags that run and it works!! Alex got the computer to read the correct speed and all is well and good. I do have two O2 sensor codes, I think its a wiring difference between early and late PCM's but I'll look into that later. It only made 186 WHP though, so I am going to do a compression test tomorrow, see what's up.
Sounds good though.
