Did the swap today minus the ebrake cables, I'll do them this weekend. Found a 05 liberty at a junk yard and got the backing plates, hoses, and ebrake lines off of it. This is a direct bolt on with the exception of putting 3/8 brake fittings on the KJ lines(they switched to a metric fitting for whatever reason). Anyways onto a quick write and pics..
Jack up the rear, set on stands, remove wheels, then pop off the diff cover and drain fluid..
Image Not Found
Remove 8mm cross pin bolt..
Image Not Found
Remove cross pin and push axles in to release the c-clips.
Image Not Found
Slide out shafts and remove wheel studs, replace with studs from dana 30 wheel bearing..
Image Not Found
Remove 4 nuts holding on the drums, get rid of all that crap..
Image Not Found
You will be left with this..
Image Not Found
Bolt on liberty backing plates, I put all the ebrake stuff on first. It was easier on the workbench.
Image Not Found
Add new rotors, and calipers..
Image Not Found
Run your lines, into the stock location. I welded the liberty brackets behind the leaf perches. Bleed your brakes and your done.
Image Not Found
Difference is night and day, I had a leaking wheels cylinder which I didn't know about. Total time was 3.5 hours and a hour or so re-flaring the lines and setting up the emergency brake pads.
