White_Comanche Posted June 11, 2025 Share Posted June 11, 2025 That pair from eBay arrived. The caps are just as described... straight, not warped, and not many imperfections. Molding and replicating these should be possible. Believe I'm almost there on how to go about mold making. Unfortunately, what ever pair I use, the studs will need to be sacrificed. I'll need to cut them out, and make that mid plastic spar flat. With that being said I am willing to exchange these with a pair that is equally MINT, but do not have the bolt studs for whatever reason. We both pay shipping, and detailed pictures will be sent of each pair. Administrators and frequent members of Comanche Club only respond please. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 11, 2025 Share Posted June 11, 2025 I might have one side. I know I got a couple that the studs were broken or missing. Not sure where I put them. Link to comment Share on other sites More sharing options...
watchamakalit Posted June 12, 2025 Share Posted June 12, 2025 I have a set but need to check condition. I know at least 1 has broken studs. not sure on the exterior shape. I will check in a couple days. Link to comment Share on other sites More sharing options...
White_Comanche Posted June 12, 2025 Author Share Posted June 12, 2025 Singles or Doubles will work, just as well. I'll send detailed pictures to anyone who has either. Link to comment Share on other sites More sharing options...
The86manche Posted June 12, 2025 Share Posted June 12, 2025 I think i have a set in storage but I would have to check on them as i don't remember conditions. Link to comment Share on other sites More sharing options...
White_Comanche Posted June 13, 2025 Author Share Posted June 13, 2025 This is quite the nice pair I have. The lucky one(s) who might receive these will need to take some descriptive shots. This is one photo of several that I can share for those who think they have some caps. Direct message your pictures please. Link to comment Share on other sites More sharing options...
White_Comanche Posted July 5, 2025 Author Share Posted July 5, 2025 Been getting help with a molding supply company on fabricating these. We're getting closer to identifying the best method. They're complex parts to mold, but I accept the challenge Link to comment Share on other sites More sharing options...
DesertRat1991 Posted July 5, 2025 Share Posted July 5, 2025 19 hours ago, White_Comanche said: Been getting help with a molding supply company on fabricating these. We're getting closer to identifying the best method. They're complex parts to mold, but I accept the challenge Much respect for looking into this. That embedded metal plate always seemed like overkill for a trim piece to me, but I guess the threaded studs probably made for quicker assembly line installation. One alternative to consider would be to mold that vertical wall a little thicker and sink a t-nut into the outboard side. Then, the end user would just need to run a bolt and washer through from the inboard side to install. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 5, 2025 Share Posted July 5, 2025 7 minutes ago, DesertRat1991 said: Much respect for looking into this. That embedded metal plate always seemed like overkill for a trim piece to me, but I guess the threaded studs probably made for quicker assembly line installation. One alternative to consider would be to mold that vertical wall a little thicker and sink a t-nut into the outboard side. Then, the end user would just need to run a bolt and washer through from the inboard side to install. This ↑. Right here is a much better idea honestly. Link to comment Share on other sites More sharing options...
watchamakalit Posted July 5, 2025 Share Posted July 5, 2025 And they could be replaced when the road debris corrodes them. Link to comment Share on other sites More sharing options...
White_Comanche Posted July 7, 2025 Author Share Posted July 7, 2025 Using t-nuts is probably a great way of mounting these. Thanks for the input guys. Yes, I intend to add some thickness to that bar for more support. The idea is to have that mid support completely flat. End user would ultimately dry-fit, mark and drill holes. This allows for slight variances in hole locations, bumper warp, etc. And gives flexibility on the chosen method of bolting them in. Link to comment Share on other sites More sharing options...
White_Comanche Posted July 20, 2025 Author Share Posted July 20, 2025 This is going well, and as planned. Sans one seized up Dremel tool, however. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted August 3, 2025 Share Posted August 3, 2025 Nice Link to comment Share on other sites More sharing options...
White_Comanche Posted August 11, 2025 Author Share Posted August 11, 2025 At first, I was hesitant in showing in-progress shots. Now with this much time into it, I doubt too many would even get to this point. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 11, 2025 Share Posted August 11, 2025 13 hours ago, White_Comanche said: Now with this much time into it, I doubt too many would even get to this point. What does this mean? Link to comment Share on other sites More sharing options...
White_Comanche Posted August 11, 2025 Author Share Posted August 11, 2025 On 8/11/2025 at 11:46 AM, fiatslug87 said: What does this mean? It means that I'm creating a product to fill a void, and I don't want to disclose too much of the process. Link to comment Share on other sites More sharing options...
White_Comanche Posted October 12, 2025 Author Share Posted October 12, 2025 Reached milestone today. Next stage is mold making Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted October 12, 2025 Share Posted October 12, 2025 YEAH BOIS This is what's UP right here! Link to comment Share on other sites More sharing options...
watchamakalit Posted October 13, 2025 Share Posted October 13, 2025 Woot woot Link to comment Share on other sites More sharing options...
White_Comanche Posted January 19 Author Share Posted January 19 Much has been accomplished in the past several months. Sure has been a real journey learning about large scale reproductions. It's been both Fun & Very challenging. Every step has been met with one roadblock or another, workaround, or re-thinking. Just poured the largest pieces of the mold blocks today. Really hoping that these cure completely fine — and without any sort of reaction involving the silicone. I borrowed my work building to mix the product. I'll know in the morning if it all went well. Link to comment Share on other sites More sharing options...
Jeeper1093 Posted January 19 Share Posted January 19 Sweet! GL Link to comment Share on other sites More sharing options...
White_Comanche Posted January 20 Author Share Posted January 20 Here's the result. The bumper pads and keys successfully extracted from the molds. No cure inhibition with the silicone occurred... Cure Inhibition refers to contaminates either being on the surface of the part or embedded into the actual material that prevents silicone from curing properly. Instead of dry and tack-free, you would get very sticky results. The business I'm working with in Denver says I'm on the right track. Next are creating the other mold parts, along with establishing pour mouths and vent tubes. Link to comment Share on other sites More sharing options...
89 MJ Posted January 20 Share Posted January 20 Link to comment Share on other sites More sharing options...
watchamakalit Posted January 20 Share Posted January 20 This is getting tough to watch, I'm to impatient. Seriously excited for these. Link to comment Share on other sites More sharing options...
farmboi Posted 3 hours ago Share Posted 3 hours ago This has been awesome to watch. Can't wait to see the finished product. Link to comment Share on other sites More sharing options...
