what's the official name for the door stop thingie?
and are they still available new?  the MJ I'm helping with needs both replaced.  :(  I mean, I assume they are available new.  I keep trying to get junkyard ones and keep finding them with cracks already forming.  :fistshake2:
thanks guys! :D  sorry for the misplaced circle.  technically I'm looking for the door check itself. :L:
so amazon reviews of the cheap ones include a lot of "had to mod to get it to fit" and "broke within a year".  :(  the mopar ones on quadratec are 100 a pop.  ouch.
https://www.quadratec.com/products/55014_8200.htm
I guess I should go with the middle with a Crown?
https://www.quadratec.com/p/crown-automotive/front-door-check-arm-assembly-jeep-cherokee-xj
this isn't something that's shared with XJ rear doors, is it?  I haven't been checking them in the 'yards.
I believe I found a Mopar one for considerably less than that one but I'm not sure where anymore.  I did a cursory look through my receipts but don't have time at the moment to look further.  I'll see if I can find it later.
They are cross compatible for 97+. I put a set out of a 98 2dr xj in mine after it broke into 4 separate pieces and wouldn’t allow my door to close. Not 100% on the xj rear door thing tho as mine were out of a 2dr
The rears from a Cherokee will bolt on, but won't work the same. Your door won't open as far, as the arm is shorter than a front door one. The springs broke on mine, so I bought some rear ones at the JY thinking they'd have less wear; I ended up swapping arms to end up with a proper good set.
