Jenny 87
After weeks of looking at Cherokees and not finding what I wanted I stumbled on a very abused Comanche. After a Google search and a read up on the Comanche wiki page I was determined to get myself an MJ.
I ended up finding a relatively clean MJ  sportruck 2.5L / 2x4 / 4 speed for sale about 2 hours away. After a quick test drive I jumped on it. This is my first ever Jeep and by far the oldest vehicle I ever owned.
This truck seems to have quite a history. After looking at the original manual and some service documents I found out that this truck was first bought in Missouri then made its way to Arkansas. After that, a bill of sale indicated it was in Mississippi at one point. And now its back in its home state of Missouri.
This thing is surprising rust free after living in the midwest for so long. I don't think I will need to get new floor pans welded in. There are a few dings and dents I will need to get ironed out in the future.
10 Priorities on my checklist:
1:  P̶u̶l̶l̶ ̶o̶u̶t̶ ̶t̶h̶e̶ ̶v̶i̶n̶y̶l̶ ̶f̶l̶o̶o̶r̶
2: Insulate and soundproof the floors/roof
3: Replace all fluids
4: S̶w̶a̶p̶ ̶i̶n̶ ̶a̶ ̶n̶e̶w̶ ̶h̶e̶a̶d̶l̶i̶g̶h̶t̶ ̶r̶e̶l̶a̶y̶
5: Investigate the minor oil leak
6: Install a new fan cover
7: Install power steering
8: Waterproof the firewall
9: Oil the hood release
10: Clean up the ground points
10 Things I would like to do:
1: Upgrade to a 4L
2: Get a fresh paint job
3: Install the original radio
4: Find an OEM roll bar
5: Replace the cracked sportruck stripes
6: Upgrade to 4x4
7: Switch out the wheels
8: Raptor line the bed
9: Clean up the grill/headlights
10: Replace the rocker panels
19 minutes ago, 89 MJ said:
8675309
I couldn’t help myself. What state in the Midwest are you in? I’m in WI.
I'm in MO
4 minutes ago, eaglescout526 said:
 Calm down there Tommy tutone. Kinda wanted to say James Halliday in celebration of Ready Player Two's release.
Great looking truck! Shame you plan to ditch the mighty 2.5L.
The drive train swap is more of a pipe dream at the moment. Need to work on the easy stuff before I tackle any major changes.
First day of work.
I hope I don't get any hate for my choice in tools/toolbox. I don't have a garage so I'm going to be shuffling my tools from in and out of my apartment everytime I work on the truck. I needed something inexpensive and portable.
I felt like the best place to start was with the nasty vinyl floors. They had become brittle and the insulation was permanently damp. I want to stop this thing from rusting beyond my ability to repair. Before I could get to the floors I needed to evict a chipmunk that made my truck his home.
They don't look as bad as I thought they would. There are some major holes on the passenger side which surprised me, I assumed the majority of rust would be on the drivers side.
I can't say its perfect but its good enough for today. Having the floor ripped up reminds me that I need to repair the parking break. Added floorpans and carpet to my list of stuff to buy. In the meantime I need to find a welder that would be willing to help me out.
Feeling quite accomplished after a long day... I need a beer.
Decided it was time to install the headlight relay. I'm starting to work later at night and I would rather not burn out my light switch.
I had to clear out a small birds nest from under the passenger headlight area. This truck seems to be the home for many small animal's.
An easy enough install, only took me 20 minutes. I have some Hella E-code housings and fresh bulbs coming soon.
I also got these in today. With winter fast approaching getting these things welded is my top priority.
5 hours ago, MiNi Beast said:
i need to do floor pans as well. are you going to do install on them? :rtft:
I don't have a welder or any idea how to weld. I asked around and found a few people willing to help me out. Hopefully they can come through because the mechanic quoted me 2,500$ for the installation.
your floorpans don't look all that bad at all.  you'll want to drill out all the spot welds with a spot weld cutter bit (grind off the rust before drilling because rust will dull a drill bit fast) and remove much of that frame cap and side support so you can treat underneath of it, then cut out the worst part, then weld in a flat piece of steel where the hole is.  replacing the entire pan to fix a small hole is unnecessary and a ton more work.  :L:  when you're all done, coat in POR-15 or Chassis Saver and then you can get new vinyl or carpet or whatever floats your boat.  :D
don't forget to fix the rain leak that let that water in. :(
thats how I fell in love with mj's as well.
Woke up early today and decided to work on a few things.
There aint a better way to start your day.
My turn signal decided to go out on me yesterday so that needed fixing. I never really worked on car electronics but this was very straightforward. don't worry I put in an orange bulb after I took this picture.
While I had the lights off I might as well swap out the plastics and touch up the trim.
I was going to put in some Hella E-codes but they decided to send me two left sides. Anyone get shipped two right sides and want to trade? :laugh2:
Looks pretty good. Unfortunately it makes the faded grill stand out much more. I will probably be painting that tomorrow.
  • 3 weeks later...
I haven't been able to work on the truck very much recently. I went on vacation for the holidays and visited my family. Now that I'm back I think its time to tackle some of my leak issues.
I was a bit shocked to find NO gasket on my valve cover! One of the previous owners must have not cared very much about spilling a quart of oil every week.
Everything looked clean and crack free thankfully. Popped in a new felpro gasket and snugged it down.
Pro tip... wait for your engine to cool all the way down before trying to slip on a room temperature gasket. Learned that lesson the hard way. :doh:
3 minutes ago, eaglescout526 said:
Even more pro tip, don’t snug it down past 55inch pounds of torq or the cover will crack. But how in the hell does that engine not look like an oily mess?
Yeah I made sure to be gentle. It absolutely is an oily mess, I was putting oil in it constantly. My parking spot at work is clearly marked.
