AMC86Kid Posted March 26, 2020 Share Posted March 26, 2020 I have the 3 speed A904 and the 207 t-case has anyone ever rebuilt these at home with a rebuild kit ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 26, 2020 Author Share Posted March 26, 2020 So they sell the rebuild kit for the tranny on RockAuto but does anyone know where I can get new gaskets for the 207 transfer case ? Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 26, 2020 Share Posted March 26, 2020 Parts catalog calls for the use of RTV and no gaskets are used. I have a book on rebuilding the 904 as well. Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 26, 2020 Author Share Posted March 26, 2020 Yeah I shopped around and shops want around 800 for the tranny and 250 for the T-case I'm gonna take apart the T-case and see if I can just reseal it back together with RTV so it don’t leak no more any suggestions on what type of RTV to use or will just about any type work? Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted March 26, 2020 Share Posted March 26, 2020 4 hours ago, AMC86Kid said: rebuilt these at home How mechanically skilled are you? From some of your other threads and questions, I would be hesitant about advising you to rebuilding the transmission yourself. Start with the transfercase and see how you feel. The transfer case should be quite a bit easier and more straightforward than a transmission. Not saying don't do it, just go in with your eyes open. Good luck! Link to comment Share on other sites More sharing options...
omega_rugal Posted March 27, 2020 Share Posted March 27, 2020 i wouldnt suggest messing with an auto transmision unless you have enough experience, get some bad trannies from the junkyard and try with those first, learn how to dissassemble it and rea ssemble it until you can do it blindfolded, also get the service manual and read it cover to cover before doing anything... a transfer case is easy for almost any one with opposible thumbs, you can use almost any RTV as long as it comes froma good brand Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 27, 2020 Share Posted March 27, 2020 Mopar has their own brand of RTV. 5010884AD. Hate having part numbers memorized. Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 27, 2020 Author Share Posted March 27, 2020 Yes I do agree with J.E.E.P I'm starting with the transfer case first then decide if I’m gonna pay a shop to do the tranny right now now I have all the bolts out the T-case but the security 12 point 10mm one that’s on it, I will have to go buy a socket for it tomorrow Link to comment Share on other sites More sharing options...
Minuit Posted March 27, 2020 Share Posted March 27, 2020 Rebuilding a transfer case would be much easier than rebuilding an automatic transmission, and if you're going to learn to rebuild a drivetrain component, that's what I would start off with. Just make sure you have a copy of either a rebuild manual for the exact model of transfer case you have or better yet, an FSM that includes this. That'll include important stuff like torque specs and any special instructions that need to be followed. Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 27, 2020 Author Share Posted March 27, 2020 ok so as I'm taking the T-case apart i noticed these breather holes link: https://ibb.co/W6YV106 can anyone explain what there for or if theres a link to any info online that i can read about Link to comment Share on other sites More sharing options...
omega_rugal Posted March 27, 2020 Share Posted March 27, 2020 don´t forget to get ALL the tools requiered before you begin. it sucks to have everything dissaembled and THEN realize you need a special tool... Link to comment Share on other sites More sharing options...
87MJTIM Posted March 27, 2020 Share Posted March 27, 2020 8 hours ago, omega_rugal said: don´t forget to get ALL the tools requiered before you begin. it sucks to have everything dissaembled and THEN realize you need a special tool... BFH and duck tape. what more you need? Link to comment Share on other sites More sharing options...
derf Posted March 27, 2020 Share Posted March 27, 2020 6 hours ago, 87MJTIM said: BFH and duck tape. what more you need? WD40. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted March 27, 2020 Share Posted March 27, 2020 4 hours ago, derf said: 10 hours ago, 87MJTIM said: BFH and duck tape. what more you need? WD40. Blue tipped wrench. Guaranteed to loosen anything! Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 28, 2020 Author Share Posted March 28, 2020 ok well i managed to take the t-case apart and the inside looks pretty good dirty but the parts don't look all chewed up one thing that looked interesting was when i inspected this piece i noticed it was blue and not offset white like all the other pieces does this mean that someone else had worked on it in the past ?? Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 28, 2020 Author Share Posted March 28, 2020 Ok so i finally got all the t-case parts cleaned now its ready for reassembly i sure hope i manage to get it all back together correctly my question is do i just go crazy with the gasket sealer to make sure it doesn't leak no more? Link to comment Share on other sites More sharing options...
Warren Mohler Posted March 28, 2020 Share Posted March 28, 2020 More is not better Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 28, 2020 Author Share Posted March 28, 2020 got it i will just put what looks to be an adequate amount also need to get some ATF fluid to dip the parts in before i reassemble Link to comment Share on other sites More sharing options...
Warren Mohler Posted March 28, 2020 Share Posted March 28, 2020 For t-case I liked Permatex red gel gasket, 1/8 bead is all thats needed, no parts need dipped in atf that will just make a mess, you are going to fill it that is all that is needed Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 29, 2020 Author Share Posted March 29, 2020 Sounds like a plan but after I put it back together how am I suppose to fill it up with ATF fluid ? Link to comment Share on other sites More sharing options...
Warren Mohler Posted March 29, 2020 Share Posted March 29, 2020 Fill Plug Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 29, 2020 Author Share Posted March 29, 2020 Nice so where should I look for this fill plug ? Link to comment Share on other sites More sharing options...
AZJeff Posted March 29, 2020 Share Posted March 29, 2020 24 minutes ago, AMC86Kid said: Nice so where should I look for this fill plug ? See those two sort of bronze colored hex head plugs on the back case half at the top of the photo above? Those are the drain and fill plugs. I would be wise to remove both and clean their threads before refilling. Link to comment Share on other sites More sharing options...
Eagle Posted March 29, 2020 Share Posted March 29, 2020 37 minutes ago, AMC86Kid said: Nice so where should I look for this fill plug ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted March 29, 2020 Author Share Posted March 29, 2020 Thanks guys will do also is there a specific amount of fluid to put in or do you just fill it up to about half way ? Link to comment Share on other sites More sharing options...
