4th Generation MJ project
Got my coolant swapped out today. Cleaned up some oil from all the blow by. Got a new air filter, the other needs alot of cleaning. It was soaked with oil. New parts list after tinkering:
Spark plugs
Cap and rotor
Wires
Battery
My battery is 5 years old. When I turn on anything in the cab I can see the voltage gauge drop. It runs at 10 most of the time.
Thinking on swapping the temperature plug on the block. Not sure the gauge is correct. Fan isnt kicking on since I went to the 195° thermostat.
Got my plugs, wires, cap and rotor in. Plugs were over due it seems. Handy trick for retrieving and starting plugs is a little piece of tubing. Then I noticed this little rubber grommet crumbled on the value cover.
  • 4 weeks later...
  • 4 weeks later...
Not much of an update. Silly how long things take with kiddos and honey do lists. Had some member advice help with a tricky bolt. Finally got it off with the right tool. Started grinding on the 8.8. The welds on the inside will be tricky. Got the steering components off and ready for new end links.
