bruceb Posted October 6, 2019 Author Share Posted October 6, 2019 No, I am not pulling the bed for this paint job. It is a California truck, so very little in the way of rust. Also, I am painting the same color as original, so keep the re-paint straight forward! Link to comment Share on other sites More sharing options...
Pete M Posted October 6, 2019 Share Posted October 6, 2019 that makes sense. I've pulled a couple beds now and it's pretty easy, so I feel I should mention it just in case "perceived difficulty" was the reason. Link to comment Share on other sites More sharing options...
CaptainPatchy Posted May 27, 2020 Share Posted May 27, 2020 Looks like a super cool project, I'll be interested to see your progress on this Link to comment Share on other sites More sharing options...
Pete M Posted May 28, 2020 Share Posted May 28, 2020 On 10/6/2019 at 11:02 AM, bruceb said: indeed! how did the paint turn out? Link to comment Share on other sites More sharing options...
bruceb Posted May 29, 2020 Author Share Posted May 29, 2020 Project is still underway. Getting ready for a new head, cam, lifters. Also need to the 2" drop in the front with new ball joints, etc. Link to comment Share on other sites More sharing options...
Dougster123 Posted November 3, 2020 Share Posted November 3, 2020 On 9/20/2017 at 3:35 AM, bruceb said: In addition to sorting out the front air dam, I am planning a cleaner look than the tubular rear bumper. Here are ones I like the looks of, thoughts? My favorite is on the yellow truck. Wow! Any ideas where did that grey truck bumper came from? THAT's what I'm after. Link to comment Share on other sites More sharing options...
Dzimm Posted November 4, 2020 Share Posted November 4, 2020 45 minutes ago, Dougster123 said: Wow! Any ideas where did that grey truck bumper came from? THAT's what I'm after. That's a custom roll pan install. Probably an S10 rollpan that had the seams welded up and painted to make it look like it's integral to the bed. Definitely a clean install. Link to comment Share on other sites More sharing options...
Pland Posted March 25, 2021 Share Posted March 25, 2021 Love the build! I'm not doing an SCCA clone truck, but I've been doing a lot of the same things you have to lower my comanche. My question is about the shocks though. With the fronts, did you have a problem with the upper bushings seeming like they didn't compress enough? I just installed mine yesterday so I haven't gotten it on the ground, but the nut bottomed out before it they did in my opinion. I'm going to just drive it for a while and see how they do before I make any changes to them though. Also, I noticed you used the shorter tacoma shocks in the rear. Did you feel this was needed? I also bought these and installed them last night, but I don't have have the cherokee shackles like you do, just lowering blocks, and it seems like the shocks fully extend too easily when you push up and down on the back of the truck. Sort of like limiting straps. Do the shackles make a difference in this? I know it's been a while, so I'm not sure if he will respond, but I'd really like to see some pictures of @Goatman's prothane bump stops. Mine currently bottom out pretty easy even after trimming them. I've though about cutting out a section of the tube, then using a piece of pipe whose outside diameter is the same as the inside diameter of the bump stop tube, then welding it back together (if that makes any sense). Did you modify your bump stops at all @bruceb? Link to comment Share on other sites More sharing options...
Jesse J Posted March 25, 2021 Share Posted March 25, 2021 any updates @bruceb? Link to comment Share on other sites More sharing options...
Pete M Posted March 25, 2021 Share Posted March 25, 2021 4 hours ago, Pland said: I know it's been a while, so I'm not sure if he will respond, when in doubt, be sure to quote one of his posts or type @ and then his screen name as Jesse did and he should get an email alert. Link to comment Share on other sites More sharing options...
Pland Posted March 30, 2021 Share Posted March 30, 2021 Thanks @Pete M! Link to comment Share on other sites More sharing options...
bruceb Posted August 6, 2021 Author Share Posted August 6, 2021 Things slow (stand still actually) during this Covid-19 period, but the truck is at the painters and looking forward to a shiny new "truck" in a couple of months! Link to comment Share on other sites More sharing options...
Pete M Posted August 11, 2021 Share Posted August 11, 2021 how exciting! Link to comment Share on other sites More sharing options...
dragordie Posted January 3, 2022 Share Posted January 3, 2022 A lot of good information here. On my 4th Comanche (87 2WD 2.5L 4speed short bed) Working on a direction for my build. Bruceb like the direction your going. Keep us updated on your transformation. Link to comment Share on other sites More sharing options...
bruceb Posted January 6, 2022 Author Share Posted January 6, 2022 On 1/3/2022 at 1:45 PM, dragordie said: A lot of good information here. On my 4th Comanche (87 2WD 2.5L 4speed short bed) Working on a direction for my build. Bruceb like the direction your going. Keep us updated on your transformation. The progress is going slow so far, as my auto body painter has other jobs in front of of my Comanche. I do have a new cyl head, cam, headers to install once I do get it back. So my recent focus has been on my other Comanche for more camping and 4x4 trails: Link to comment Share on other sites More sharing options...
Jlindsey86 Posted January 12, 2022 Share Posted January 12, 2022 This is such a cool build! Looking forward to further progress! Link to comment Share on other sites More sharing options...
bruceb Posted May 17, 2023 Author Share Posted May 17, 2023 Started back on the body work after a very long covid-19 pause. Link to comment Share on other sites More sharing options...
bruceb Posted April 15, 2025 Author Share Posted April 15, 2025 Painting is complete, looking at different race livery designs for the next stage of this long running project Link to comment Share on other sites More sharing options...
Htchevyii Posted April 16, 2025 Share Posted April 16, 2025 Cool! I still remember a 2wd with a body kit sitting is someone's front yard when I was in highschool. I wanted it bad, but didn't have the means. Link to comment Share on other sites More sharing options...
neohic Posted April 17, 2025 Share Posted April 17, 2025 Looking forward to more updates. Link to comment Share on other sites More sharing options...
