I have a pool of water on my passenger foot area. I've been looking for the past few weeks here. Thought it was a window seal. But i cannot for the life of me determine where the water is coming in from. Rained all last night and all the seals seem dry. Where do these things usually leak from?
Pete M uses baby powder to locate where the leak is coming from . It could be around your windshield , where the inner fender and firewall meet in the engine compartment ( the seam seal cracks and lets water in ) or it could be coming from around the rear glass as well .
Mine was rear window primarily. There was also evidence of water coming through the radio antenna cable through hole. The rubber grommet had shrunk over the years and it simply fell out. Add broken up fender liners in the front wheel wells to helping allow water in antenna cable passage.
Fixing this right now. Mine is leaking from the antenna cable, where the HVAC/Heater box meets the firewall (or could be the blower motor seal on the engine side) and on the driver side at the fuse box. I originally thought my leak was coming from the fresh air intake under the cowl but it seems to be ok there.
Rear window and doors for me.  Ging to look into getting new weather stripping and seals this summer and having my rear window re-installed/sealed.  Hopefully that at least reduces my swimming pool problems.
I like having floors though... :(
That's the thing I just re did the floors really not looking to do them again. Guess I should've found the leak first. Thanks for the reply's guess its going to be some trial and error here!
