Best Spark Plugs?
IMHO for a Renix engine NGK plugs are best -- the standard ones, not platinum. Close second are the Champion truck plugs.
:agree:
(For HO - never had a Renix). Personal preference only; I prefer the cadmium(?) plating on the NGKs (and Bosches  too) to the zinc plating on Champions  because it is more durable. Probably makes no difference to most people, but I am both meticulous and cheap when it comes to spark plugs (and a lot of other stuff too). What most folks would toss in the trash, I refurbish with a file (to re-flatten the center electrode  once worn rounded to enhance/rejuvenate spark generation capability).
In my 2.5 I run bosh iridiums and I love them it smoothed acceleration a bit to
Probably because you needed new plugs anyway. I will never use Bosch again as I have done back to back tests with them versus NGKs. Both times I was fighting a driveability problem for someone else. Out with bosch, in with NGKs. Problem solved.
Bosch Platinums don't live as long with CDI or HEI ignition. The old racers story is Champions are sold in boxes of 10 so you have a good chance of getting 8 good ones in a box. (I think that was more how the warehouse handled them and dropped so many things that caused it)
If you have a ping issue, NGK BKR6EK plugs tend to fix it. (EGR is disconnected on mine with no ping) Plain old factory Autolites are good but not to fight ping.
  • 5 years later...
Champion copper.  Tried NGK in my 97+ truck when I first built it and they didn't last long (biased due to an issue causing excessive fuel).
My 95XJ had a super old Champion plug in cylinder 6 because someone apparently didn't know how to change it so they left it.  Looked like it had been in it since 95 but it still worked.
Never had an issue with Champions and will always use them in a 4.0L.  As far as wires, I get the middle of the road of whatever the auto parts store has.
Ended up going with Autolite Platinums. Had NGKs in there and well let’s just say they were long overdue to be changed. One plug was pretty bad. The other 3 looked rough. Sounded great on startup. Not much of a choice on wires at Autozone. Duralast  or Denso. I went with Duralast.
  • 2 years later...
