Those Of You With Soa
Looking for what front coils to purchase that will best match a rear SOA. From what i have found seems like 6.5 is the way to go. Can everybody with rear SOA please post what brand and advertised lift front coils you are running in the front .also would like to hear if you are happy with said coils (do they match rear on height). If ya got pics that's great also.
could be anywhere from 4.5 to 6.5 depending on the condition of your leafs. I've got about 5" of lift up front to match 2wd leafs with an extra main.
also, you're going to want more than coils for lifting the front. :yes:
I Netted about 4.75 for a rear lift, I used ruff stuff spring perches and ground the down as much as possible and used xj shackles. I'm running 4+1 metric ton leafs. What i put up front was some rusty's 305 the heavy duty ones, then got a set of jks acos to be able to level it out perfect. To get the rake i wanted i think I adjusted the front to about 4.5.
I don't actually have a set of stock rear leafs yet, will probably get the best set i can from local junk yard (they have three comanches). Track bar and brake lines are already covered. Thinking i will end up picking up some 6.5 coils, new shocks, and figure out how i want to handle the steering...and should be good to go.
control arms?
^^^ or control arm drop brackets and adjustable control arms. The drop brackets will keep your on road ride better if youre not offroading all the time, and the adjustable arms will get your pinion angle and caster where you need them after lifting..... and make sure to get an alignment when youre done.... then post us some pics of the finished product! Good luck.
I have PORC 6.5 coils with .75 poly spacer in front and factory (2WD) leafs soa with 1.25" tall by 8" long spring pads . sets level.. parts have been in service over 5 years and all is well.
as for steering I run High steer adapter from JB conversions to make steering linkage work perfect! and custom track bar. at 6" lift you will ant to get your steering system right..or it will always suck.
Hi Steer Adapter
  • 1 month later...
For most people, to match SOA in the back you need ~6.5" out front. This needs:
- (adjustable) track bar
- (adjustable) upper control arms
- (adjustable) lower control arms
- longer brake hose
- springs
- shocks
- longer (quick disconnect) sway bar end links
I have heard good things about Rubicon Express and have personal good experiences with Rock Krawler.
Also have personal experience with Teraflex, but it's not so good. According to people who have used Rusty's and Rocky Road Outfitters, stay away from them. Also know people who have used Rough Country components who originally lauded them, but changed their mind later and swapped out their components for another brand. Don't know specifically what the issues were, though.
