what engine or engines can cheaply and easily swap into an mj and make it faster while keeping a near normal gas mileage? (17 mpg)
  • Replies 51
This post is entirely too vague.
What year MJ do you have? What engine is currently in it? Define cheap (give me a maximum price range). Define easy (how mechanically skilled are you).
If you have a 2.5 4 cyl, or a 2.8 V6, your best bet would be a 4.0 swap from a donor Cherokee, that includes everything from the engine, trans, dash and engine wiring harness.... everything. Or if you have a 2.8, you could swap in a 3.4 V6 from a Camaro, If you need more power than a 4.0, well.... It aint cheap, and its extremely involved, including advanced fabrication, and or cubic dollars. Let us know what youre trying to do and what ya got and we can go from there! :thumbsup:
sorry, i have an 88 4.0L 5 speed commanche, i lack any true in depth experience with engines, however, i have a friend who has swapped out a number of engines before. for price i would say anything under $1500.
also the idea is to possibly swap a more recent v8 that is more efficient since engines have come a long way in 23 years. i love my mj its just i want it to really scoot while still being my dd and still a capable hauler.
Unless you have driven an MJ with a 4.0, you'll realize real soon that you don't need a V-8 under the hood.........at best, put a stoker in, and you wouldn't have the cooling problems and fitment problems you'll have with trying to get a V-8 in there.
Also.......What's this???
Is that your budget for a replacement engine??? Are you going full re-man???
Good used 4.0 with around 100K are selling around here for $200-$250. I'm sure that's about the same price down your way :dunno:
Going stoker.......ask one of them guys what they got into there engines.
There are several people doing 5.3 Chevy V8 swaps, but I don't beleive you could do this swap within your budget unless you owned a wrecking yard and shop and had access to all the needed parts and fabrication tools and talent. Advance adapters makes adapters for the chevy engines, and I think small block fords for the XJ/MJ platforms, but like I said, its gonna cost ya. If you could build it yourself you might be able to do a stroked 4.0 with a header and cam, for close to your budget, but I think you may still go over even that way. If you need more than what a 4.0 MJ can give you, then you may need a different vehicle alltogether.
I think the RENIX 4.0L that is in your jeep is plenty adequate, and should be able to pull down 20 MPG with good driving in stock form.
Rob L.
swap in an axle(s) with a better gear ratio and you'll get better performance and better fuel economy. :D
  • 10 years later...
I have the 4.0 in mine. I’m running 35’s right now and the truck is a bit too weak for them. I’m new to diy and am ignorant haha. What would you recommend if I wanted to beef it up a bit so I can haul lawnmowers and stuff like that. I know upgrading the gears will help but not sure what is best. Maybe even downsize to 33’s??
Even with 33s, you'd want to regear.  For an automatic, 4.56s or 4.88s at least.  For a manual, 4.10s or 4.56s are good.
I had a 2.5l on 35s and the biggest help was regearing the axles. I went from 3.55 to 5.13s.
Now I also did an engine swap on my jeep. I swapped a '96 4.0l in place of the 2.5l and did it all for around $250 all said and done (including stuff like new oil, coolant, motor mounts, thermostat, spark plugs, etc)
That
Thanks man I have the 5 speed in mine I don’t want to mess with the motor yet because Ik it has a lot of life in it but I was looking around for a new transmission. Would the stock AX 5
What are some brands you trust that make quality gear kits?
Thanks man what brand gears did you use?
1 hour ago, John Richard Page said:
That
I trust the brand the shop buys and warranties.
Installing gears requires precision work with specialty tools.  You can probably do it.  But there's a lot to be said for having a shop give you the guarantee.
This^^. The manual trans vehicles had 3.07 gears and the ones equipped with an auto had 3.55 gears. Swap in a set of 3.55 axles.
$1500 ain't gonna get you another motor.....
There's a lot of good info here  long story with my 86 and my ideal would be to drop this thing off and pick up later turn key. I can do a lot and have so far but would really like to get a point where I'm not working on it every time I get in it. Yeah I know   It's still a jeep. Has the very weak stock 2.8 5sp manual. Would like to swap to a much better engine and an auto ( yeah my tj is 5sp but I'm getting old) new t sure wha gears are in it currently but goal is to run st least a 33 and have plenty of power to turn them  so where's some good information that might be me through this   Tia
Seeing as though you have the legendary, awesome, 2.8 V6 of fury, I'd put a GM 3.4 or 3.1 in it with a 700R4 behind it. As for gearing, I'd run either a 4.10 or 4.56 (probably the latter) in the axle(s).
Thanks I have read a little about the 3.4 swap as supposedly one of the most straightforward swaps and I'm running 4.10s on my 2.5 tj with 31s and it's not bad but figured I could do a little better running the 4.56s wanting to run 33s. This is a sentimental build so really wanting to put the time into it to make it a nice ride
if you really want some extra bonus points, install the complete 3.4L with fuel injection and accessories.  it's really not that much more work if you're doing a slow build. :L:
