DesertRat1991 Posted December 30, 2018 Share Posted December 30, 2018 On 12/26/2018 at 12:22 PM, GreasemonkeySC said: So what did everyone's MJ get for Christmas? Picked up an HD Tie Rod and new TREs from Iron Rock Offroad during their Christmas sale. This thing has gotta weigh north of 12lbs -- 1.25" dia and solid. Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted December 30, 2018 Share Posted December 30, 2018 Today she got a new rear bumper, all 4 shocks, bump stops, complete front brake job, and I put the first layer of fiberglass on the headliner board.Think the brake rotor was bad? Link to comment Share on other sites More sharing options...
Pete M Posted December 30, 2018 Share Posted December 30, 2018 nah, you've still got some good steel there! Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted December 30, 2018 Share Posted December 30, 2018 nah, you've still got some good steel there! Before I retired I would see that stuff all the time. I was a government fleet tech. I had to trailer a fire ladder one early morning. They shattered all 4 rear brake rotors. Like glass! 93,000# truck on a 35ton trailer.Officer comes in after a high speed chase, and request we check tires, brakes, and it's been making a funny noise for about 1500mi.I barely get the car on the lift, and I hear what sounds like a shotgun come from the rear axle. "Um.... Ya think you could manage getting noises checked out a little sooner, so you don't die!" Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted December 31, 2018 Share Posted December 31, 2018 Pic of new rear bumper Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted December 31, 2018 Share Posted December 31, 2018 Installed my keyless entry system, and the driver's door actuator today.Jeep made the grommet in the driver's kick panel solid rubber, and nearly 3\4in thick. Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 4, 2019 Share Posted January 4, 2019 New inner the rod end, and a set of new 97+ XJ side mirrors. Just gotta short out a switch to operate them. Link to comment Share on other sites More sharing options...
Vineyard86manch Posted January 9, 2019 Share Posted January 9, 2019 When I bought my 86 mj last March I promised the old girl I would restore her stripes eventually after it was painted. Thanks to Spencer at jeepsticker.com we made it happen. I had a friend who does graphic design put together the design and Spencer brought it to life. Great work Spence! Link to comment Share on other sites More sharing options...
Jargon Posted January 9, 2019 Share Posted January 9, 2019 4 hours ago, Vineyard86manch said: Very nice. Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 10, 2019 Share Posted January 10, 2019 So my leaking internal slave cylinder turned into a leaking slave, leaking rear main, and leaking oil pan gasket. Decided to order a new pan since this one has been repaired.The PO had left out the shifter gasket, and the shifter boot was about 1\2 gone.Is there a plug to go in the hole where the hydraulic clutch lines pass through the bell housing? Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted January 14, 2019 Share Posted January 14, 2019 My weekend! Bottom end inspection, Wheres the Tap coming from? (Not the bottom end....) OILPAN GASKET!!!!!!!!!!!!!! /end rant. Sanded, Primed (SP148), Painted (SP154), Clear coated (SP145) the pan. all VHT 550F rated. Color Grabber Green, . Replaced Oil pan gasket, ,Oil pump, Oil Filter, Oil 5w30, Transmission oil. 75w90 On 1/9/2019 at 9:53 PM, GreasemonkeySC said: Is there a plug to go in the hole where the hydraulic clutch lines pass through the bell housing? idk, but i noticed something that bothered me when i was doing my inspections this weekend that kinda of goes with this... the lines that go in to the trans for the slave, are the suppose to be able to move? (push/pull) at all? Link to comment Share on other sites More sharing options...
carnuck Posted January 14, 2019 Share Posted January 14, 2019 The plug/dust boot may be available but the lines move around a bit due to the floating slave unless someone has their foot on the clutch. Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 15, 2019 Share Posted January 15, 2019 So.... oil pan off, no gasket-only RTV, 2 broken bolts with the heads RTV to look right, and as I'm looking up from my creeper..... What do I see?No bolt in the intermediate shaft at the steering gear! Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 15, 2019 Share Posted January 15, 2019 The plug/dust boot may be available but the lines move around a bit due to the floating slave unless someone has their foot on the clutch. Can't find the dust boot listed anywhere. I guess I'll be making one. Link to comment Share on other sites More sharing options...
carnuck Posted January 15, 2019 Share Posted January 15, 2019 Item 112155133608 on that evil bag site. Keep in mind that it’s also a Wrangler part. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 15, 2019 Share Posted January 15, 2019 Item 112155133608 on that evil bag site. Keep in mind that it’s also a Wrangler part. Sent from my iPhone using Tapatalk Thanks! Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 15, 2019 Share Posted January 15, 2019 Item 112155133608 on that evil bag site. Keep in mind that it’s also a Wrangler part. Sent from my iPhone using Tapatalk Whoa! That comes up as a Like slave kit for $90 Link to comment Share on other sites More sharing options...
carnuck Posted January 15, 2019 Share Posted January 15, 2019 Crap. I must’ve copied/pasted the wrong item number. There was a bag with the dust plug in it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 15, 2019 Share Posted January 15, 2019 Installed new oil pan & gasket, put bolt in intermediate shaft, replaced sway bar bushings. Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 16, 2019 Share Posted January 16, 2019 New clutch installed, transmission is back in. Needs the CPS installed & slave bled out.Still gotta put a shifter seat seal, and new tail shaft seal in it.I found rust!!!Front corners of both floors, right at the fender\firewall. Only about the size of a half dollar right now. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted January 17, 2019 Share Posted January 17, 2019 18 hours ago, GreasemonkeySC said: I found rust!!! BURN IT WITH FIRE!!!!!!! Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 18, 2019 Share Posted January 18, 2019 BURN IT WITH FIRE!!!!!!! Translation - Weld in New Panels Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 18, 2019 Share Posted January 18, 2019 Finally done with the clutch, and shifter rebuild, ect......I thought my truck had some pep before, but now it's crazy. I have a hard time not letting my right rear tire chirp every time I start off.Now I need to find a D35 LSD on the cheap! Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted January 18, 2019 Share Posted January 18, 2019 8 hours ago, GreasemonkeySC said: I have a hard time not letting my right rear tire chirp every time I start off. I had that during my earlier time of owning mine... Hell she use to spin them 1st, 2nd, chirp 3rd... Now its hard to make the old girl chirp for me. 8 hours ago, GreasemonkeySC said: Translation - Weld in New Panels or grind the hell out of it like i did and por15 it. edit: see reference 7/8 and 7/28 on my build page in signature. Link to comment Share on other sites More sharing options...
GreasemonkeySC Posted January 18, 2019 Share Posted January 18, 2019 or grind the hell out of it like i did and por15 it. edit: see reference 7/8 and 7/28 on my build page in signature. Oh, I can definitely smoke a tire in 1st,2nd, and chirp 3rd. I'm having trouble just normal driving! Link to comment Share on other sites More sharing options...
