Acronyms
AAL = Add A Leaf (to the spring pack)
ABS = Antilock Brake System
AFAIK = As Far As I Know
AMC 20 = American Motors Model 20 axle (rear, used on the '86 MJ with metric ton suspension)
AX-4 = 4-speed manual transmission (early 4-cyl XJ and MJ)
AX-5 = 5-speed manual transmission (4-cyl and 2.8L V6 XJ and MJ)
AX-15 = 5-speed manual transmission (mid-89 - 1999 XJ and MJ 4.0L)
AW4 = Aisin-Warner 4-speed automatic transmission (XJ and MJ w/ 4.0L engine)
BA 10/5 = 5- speed manual transmission (87 to mid-89 XJ and MJ 4.0L)
BFH = Big Friggin' Hammer
BS = Back Spacing
CAD = Central Axle Disconnect
CPS = Crankshaft Position Sensor
CTS = Coolant Temperature Sensor
D30 = Dana 30 axle (front, in an XJ or MJ)
D35 = Dana 35 axle (rear, in an XJ or MJ)
D44 = Dana 44 axle (rear, in an XJ or MJ)
DD = Daily Driver
DS = Drive Shaft
DW = Death Wobble
ECU = Engine Control Unit (the engine computer on earlier XJs and MJs)
EFI = Electronic Fuel Injection
EGR = Exhaust Gas Recirculating Valve (used with early XJ & MJ engines thru 1990)
FSM = Factory Service Manual
FWIW = For What It's Worth
HO = High Output (post-1990 4.0L motor with new EFI)
HP = High Pinion
IMHO = In My Honest [Humble] Opinion
IMO = In My Opinion
IIRC = If I Remember Correctly
LCA = Lower Control Arm (part of front suspension)
LMAO = Laughing My A$$ Off
LP = Low Pinion
LSD = Limited Slip Differential (see "Trac-Lok")
LWB = Long Wheel Base
MAP = Manifold Absolute Pressure sensor
MJ = Jeep Comanche
MPI = Multi-Port Injection
NSS = Neutral Safety Switch (automatic transmissions only)
OBDI = first generation On-Board Diagnostics (also OBD)
OBDII = second generation On-Board Diagnostics
O2 Sensor = Oxygen sensor
PCM = Powertrain Control Module (the engine computer on newer XJs and MJs)
Renix = RENault/bendIX (AMC's source for the ignition & injection system used in the 87 - 90 XJ and MJ )
SOA = Spring Over Axle (rear suspension conversion for MJ, OEM configuration for XJ)
SUA = Spring Under Axle (OEM rear suspension configuration for MJ)
SWB = Short Wheel Base
SYE = Slip Yoke Eliminator
TB = Track Bar (part of front suspension/steering system)
TBI = Throttle Body Injection
TIA = Thanks In Advance
TPS = Throttle Position Sensor
TRE = Tie Rod End
TCU = Transmission Control Unit
Trac-Lok = Jeep factory optional limited slip differential
UCA = Upper Control Arm (part of front suspension)
XJ = Jeep Cherokee
Additions from SummerinMaine and BLHTAZ added. Thanks.
BFH = Big Friggin Hammer
BS = Back Spacing
DD = Daily Driver
DS = Drive Shaft
DW = Death Wobble
HP = High Pinion
LP = Low Pinion
OBDI = first generation On-Board Diagnostics Pre 1996
OBDII = second generation On-Board DiagnosticsPost 1996
TRE = Tie Rod End
*EDIT
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
This is a basic list without going in to all the sub-catagories of the CJ & FSJ's...
CJ - 1941 - 1986
DJ - 1954 - 1982 ??years
SJ - 1963 - 1986 ??years
FJ - 1961 - 1965
MJ - 1986 - 1992 (Comanche)
XJ - 1984 - 2001 (Cherokee)
YJ - 1987 - 1995 (Wrangler)
TJ - 1997 - 2006 (Wrangler)
JK - 2007 - present (Wrangler)
ZJ - 1993 - 1998 (Grand Cherokee)
WJ - 1999 - 2004 (Grand Cherokee)
WK - 2005 - present (Grand Cherokee)
KJ - 2002 - 2007 (Liberty)
KK - 2008 - present (Liberty)
MK - 2007 - present (Compass / Patriot)
XK - 2006 - present (Comander)
This is the basic list I have in my head from being in dealership parts for several years. :cheers:
They didn't make Wranglers in 1996? :nuts:
Nope...no Wranglers in 1996. They were in the process of switching from the YJ to the TJ going from leaf springs to coils and many other changes so they took a year off and introduced the TJ as a 1997.
  • 3 months later...
CJ - 1941 - 1986
SJ - 1963 - 1991 ??years EDIT
FJ - 1961 - 1965
How about wheel bolt patterns:
CJ - 1941 - 1986 5 on 5.5
DJ - 1954 - 1982 ??years 5 on 5.5??
SJ - 1963 - 1991 ??years EDIT 6 on 5.5
FJ - 1961 - 1965 (Forward Control)??bolt pattern
MJ - 1986 - 1992 (Comanche) 5 on 4.5
XJ - 1984 - 2001 (Cherokee) 5 on 4.5
YJ - 1987 - 1995 (Wrangler) 5 on 4.5
TJ - 1997 - 2006 (Wrangler) 5 on 4.5
JK - 2007 - present (Wrangler) 5 on 5
ZJ - 1993 - 1998 (Grand Cherokee) 5 on 4.5
WJ - 1999 - 2004 (Grand Cherokee) 5 on 5
WK - 2005 - present (Grand Cherokee) 5 on 5
KJ - 2002 - 2007 (Liberty) 5 on 4.5
KK - 2008 - present (Liberty) 5 on 5
MK - 2007 - present (Compass / Patriot) 5 on 4.5??
XK - 2006 - present (Comander) 5 on 5
  • 2 months later...
  • 3 months later...
I believe the CJ designation wasn't used until 1945, for the CJ-2. 1941-45 were MA and MB . MA was the original designation used by Willys when they submitted the prototype for evaluation to the Army. It was changed to MB when it went into production for the military. CJ stands for civilian Jeep.
  • 2 months later...
I've heard the CJ designation didn't originally stand for Civilian Jeep. It was just a designation they gave it that had no particular meaning. Multiple people who work or worked for Jeep told me this. One of which worked there quite a long time ago. I don't know how much truth there is to it, but these people told me this without me leading them that way.
Who knows anymore, it was so long ago, I doubt there is a concrete answer.
  • 2 months later...
JEEP
Jumps Excitedly in Every Pothole :banana:
Junked Electrical & Emissions Parts
Just Everyone Elses Parts
Just Eats Every Part
Just Empty Every Pocket
Just Enough Engine Power
Just Enough Education to Perform :smart:
Just Expect Every Problem :thumbsup:
Just Eat Every Payment
Jeez!!!! End the Expenses Please!!!! :wall:
Just Extract Extra Petroleum
Jettison Every Extra Part
Just eat every pu$$%
  • 3 months later...
  • 5 months later...
