Akula69
Everything posted by Akula69
  1. Akula69
    Expensive lesson
    Eagle - Does 100% Synthetic DOT 3+4 qualify as silicone? I looked at the bottle but it does not say.....
  2. I have two. One rebuilt (without fuel pump) and one not rebuilt (with used fuel pump). PM for details but rebuilt is 125.00 and non-rebuilt is 80.00 (plus shipping).
  3. Wow. It must have a hella battery setup to power the AC and exterior lights :rotf:
  4. John is correct. Having worked here thru Katrina and the aftermath, there are several important things: Take your important papers, in a zip-lock AND inside a Tupperware container. Get the people out...and pets. Plan and re-check the route (remember the 6 P's) DON'T come back in until the authorities say so. It will be almost irresistible to do the "looky-see", but don't. You will just endanger yourself and put more of a burden on the first responders. There is no water, no food, scared and rabid animals, and looters. There is nothing you cannot replace except your life.
  5. Huh. We called it 'Whale S..T" cause it smells so bad....
  6. I have one for a long bed you can have for the price of shipping if you want. Of course you'd have to cut it down.
  7. Hells creek sold us a set of metric tons for 500.00. other then a small amount of surface rust they have settled in nicely, and I have not found the ride to be that different....
  8. Not really. A small bore punch directly on the stiffening wire is the way. I have one that is about 8 inches long that I wrap with masking tape (protect the crank bearing surfaces). Once the top seal is partially out you can usually push it with your finger the rest of the way. In really difficult cases I have loosened (not removed) mains 5 and 6 - allows the crank to move just enough to loosen the seal up. Good luck!
  9. OK - after replacing all three solonoids the old transmission feels like new again! So far (approx. 100 miles), the codes have not returned and the transmission is shifting crisply in all gears. Thanks for all the help! Jake
  10. I always take your advice! When my son and I converted Junior we cleaned and checked these and every other connector (unlike when we did his and chased a 'no bus' condition around for awhile....)
  11. I'm with you on this one, but I figured mentioning the other poster's comment might spark some additional thoughts. AFAIK, the torque converter is simply a fluid coupling...but it does affect pressure. I've never known anyone who has experienced a bad one (kinda one of those parts that hangs on forever). I do have an older (small) trans cooler on this rig and did replace the OD solenoid with a mopar part. if all else fails I suppose I could try a larger cooler.
  12. Thanks for the input Don. Yeah, I've heard about the aftermarket sensor issues - actually had them with this MJ on the TPS and the CKP....had to lay out the $$$ for the mopar sensors.... :doh: Did use the ohmmeter on the harness (forgot to mention that in the original post) and was getting approximately 12.9 ~ 13.6 on the scale (which would seem to indicate good..?) One of the posters in the thread talked about the torque converter itself...but if that was weak or malfunctioning I imagine the other transmission actions would reflect that.
  13. Basically, just what the title says. The 2000 AW4 in Junior is misbehaving...throwing the P705 code which translates into the OD solenoid is not 'electrically' checking out upon start. I have replaced the solenoid and it worked for awhile but now has started to throw the code again. The problem is the OD works occasionally and has no pattern to its misbehavior. Over the weekend the truck was driven to Hattiesburg and back - OD worked on the way up and did not on the way back (which would seem to indicate fluid circulation and/or warm up is not the case). When the solenoid was replaced the filter and fluid was changed out - no particular debris or dirt was observed (filter and fluid had been changed when the trans was installed at conversion). Because the solenoid is mechanical (activated by an electrical signal) can the TCM be the culprit here? When the truck is started, does the TCM physically actuate the solenoid or just check to see if it worked the last time the truck was running? Thanks Jake
  14. X2, and we still had to use two floor jacks and a rachet strap attached to an eye bolt on the wall of the garage.
  15. Great info Don - glad it worked for you. I had already switched to 134a when we re-worked both the trucks...but If I still had 12 I'd go this route. One lb cans of R-12 (when you can find them) are about $600.00 each down here now :doh:
  16. Funny. That exact radio and those bucket seats were in my daughter's first Jeep - a '92 XJ. I suppose they could have swapped in whatever parts the dealership may have had on hand? I'd ask about any records they might have.
  17. X2. I believe that is what caused mine to leak. I know there is a thread around here somewhere about temp sensor bungs on the housing, but has anyone ever tried to put a pressure gauge on it?
  18. Mid life crisis indeed...I wish I had the green to go there! Every time I hear the name of that vehicle I get chills....It looks great!
  19. We just replaced the front U joints on my son's truck (89 4x4) with the Moog brand (greasable). The Moog part number is 377. We used a 20 ton press to set the joints, and had to carefully spread the ears beforehand so the 'C' clips would fit. The ID of the ears before install should be 3 5/16".
  20. I used the AN connectors on the transmission lines after fighting the "seep" for awhile. Yeah, its overkill but it solved the problem. I ordered Earls fittings from Jegs If you go that route remember 90 degree for the back line and 45 degree for the front (to clear the dipstick pipe).
  21. Yeah, they have always been proud of their shipping prowess. :rotf:
  22. I really need this bedside...but he won't ship :fs1:
  23. http://www.moparpartsoverstock.com/p/__/SLEEVE-Torque-Limiter/6928518/53020598AB.html .68 apiece.
  24. Yeah, I was gonna mention that in the write up but am easily distracted. :D Sent from my E5803 using Tapatalk Blinded by the light....?
  25. Princess Auto has the other style (shorter and fatter ones) for $13.99/each normally, I think. And they go on sale from there. Of course they charge more for the yellow diesel ones. :???: So if anyone ever steals my 'gas cans' they're going to have a fun time getting their car to run with what's in them. :rotf: What about this? http://710keel.com/thieves-try-to-siphon-gas-from-rv-suck-sewage-instead/ Yes. Karma does deliver occasionally....
