mj2stay
    New Caney,Texas
mj2stay's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. PM sent
  2. Looking for a 1986 LB 2.5 L, 23 Gallon Fuel Tank Sending Unit to replace the Cherokee sending unit that some jackass swapped out with mine.
  3. I was checking out the post and was wondering if the rod and rod end need to be LH threads? If so, why?
  4. Bucket seats?
  5. Thanks, I tried that. I think that a few years ago, I botched a registration using my current email address, so now it will not let me use it.
  6. Is there any way to change my email address for any notifications I may get. I registered under one email address, but life goes on and now I have a new email address.
  7. Anyone had any experience lately with carpet from any of the manufacturers I've seen on the web. Also, will XJ carpet fit my MJ. I want to replace my vinyl flooring with carpet, but not sure which way to go. :dunno:
  8. That's what I would like to know. Are the potentiameters replaceable? I actually have a sending unit with a good potentiamenter that I would like to replace with my current unit. It is from a 23 gallon tank, fueling a 2.8 engine. I have a 23 gallon tank fueling a 2.5 engine. Will the potentiameters interchange?
  9. Great, thanks a bunch Dave. I'll go to O'Reilys tomorrow. Roy
  10. 86' comanche, long wheel base. I need the cable that runs from the e brake split-bracket to the drum brake housing on the passenger side. At this time, I only have the drivers side e brake hooked up. I dsconnected the passenger side cable from the lever inside the drum housing. Does anyone think this is a bad idea?
  11. 86' comanche, long wheel base. I need the cable that runs from the e brake split-bracket to the drum brake housing on the passenger side. At this time, I only have the drivers side e brake hooked up. I dsconnected the passenger side cable from the lever inside the drum housing. Does anyone think this is a bad idea?
  12. I think I need to take mine off and check them. The one on the passenger side looks fine, but the one on the drivers side looks wrong, like it's leaning forward a bit. I'll pull it first and check for the "left" I.D. I believe the drivers side would be the left side.
  13. Simple question, are the black vent covers on the cab, drivers side / passenger side oriented? In other words, are they both the same and it doesn't matter which side they go on?
  14. Its an '86 manche. Looking at the pic of that particular sending unit, I don't see where the pump actually attaches to the sending unit. I'm gonna call with questions. Thanks for the link :thumbsup: Roy
