Everything posted by james750
Looking to buy white header panel. Mine got crunched an few weeks ago while wheeling. I don't need the headlight trim or turn signal trim. Just need the fiberglass panel and the metal trim piece fitted across the top of the headlights/grill.
That hose is there to bring warm air up from by the header while the engine is warming up. If you look inside the air box intake there is a butterfly valve in there that closes when its cold to bring air in through that hole, and it opens when the engine is warm to draw in colder air from behind the front grill. Without a hose leading to the air box, the butterfly valve won't open and air will not be drawn in from behind the grill, this creates an intake restriction that can in theory hinder engine performance.
I just bought a set of the MT springs from Hell Creek last week. They are awesome springs, The CC discount is nice too.
Sweet, I guess I'll order up some M/T springs then. Thanks!
Right now I am running SOA with a 2'' AAL. The truck sits at a decent height right now with about 6.5'' front and 8'' rear. I was down changing the centering pin in the left rear leaf spring tonight and found out that one of the springs in the pack is broken. I think I am going to replace both sides with some fresh springs. The only stock height springs I am finding are the Metric Ton springs from Hell Creek. Could I add my 2'' add a leaf to these springs and maintain a good ride quality/lift height?
I called the Police when I was living in Utah a few months back and locked the keys in my car. After about an hour about 5 highway patrolman on bikes rode up and had it unlocked in 10 seconds, for free.
I tore out the carpet in the MJ this weekend to remove the surface rust from the floor boards now that i have my water leak fixed. My problem now is that the factory underlayment that layed underneath my factory rubber floor is deteriorated and mildewed. Does anyone know where I can get a good replacement underlayment?
non renix to renix transfer case swap info
james750 replied to james750's topic in MJ Tech: Modification and Repairs
We were talking about input shaft compatibility relating to the tcase, not the speed sender. Weren't the speedo gears for an electronic speedo a different length than the mechanical ones? For some reason I thought that the electronic speedo's used a short speedo gear and the mechanical speedo's used a long gear. -
Yeah, but the short length 23 spline input was only behind the AX15, and the 242 was only offered behind the AW4 (which has a long length 23 spline) as far as I know. (http://www.novak-adapt.com/knowledge/np ... _gears.htm) Would I have to swap inputs to get the lengths correct? -
That answers my question perfectly, I wasn't sure if the NP242 used a hall effect type sensor on the electronic speedometer versions instead of a gear. I should be able to make this case work then. Thanks! -
I'm looking at swapping a non renix (1991 and up) NP242 transfercase into the MJ. I already know I need to swap input shafts to make this work with my AX-15. But I also know that non renix XJ's are Electronic speedometer control. Is there a way that I can make this case work with a mechanical speedometer? If not, what would I have to do to convert the MJ to read an electronic signal?
I have a 90 which was the first year for the AX15, will I have a 23 spline input?
Fixed some things...now click, click, click
james750 replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
Are you hearing just one click each time the key is turned to the start position? Or are you hearing multiple rapid clicks as your post implies? If it is just one click your starter solenoid has a problem. If it is multiple clicks then you are not getting sufficient current flow to the starter solenoid. The Starter Relay and Ignition switch are not your problems. You are getting power to the starter solenoid (that is the click noise) which means that the starter relay is turning on and sending power to the solenoid, and your ignition switch is making a complete circuit to the relay because if it wasn't the relay would not be functioning and sending power to your solenoid. The gauge cluster has nothing to do with the starting system on a truck this old. -
YAY! :jump:
Slide the vent strait up, pull out.
Comanche of the month, Dec 2010 --- XJS4EVER's 1989
james750 replied to Automan2164's topic in Comanche of the Month (MJOTM)
Yeah, my summer got really busy, really fast, and I wasn't able to go on too many runs, but your always welcome to come along when I am going. I'll let you know next time I am going out, but I need to fix a lot of things on the truck for next summer and am also dealing with my dads totaled XJ (blue XJ that he brought along on Illinois Gulch last season) part out or rebuild as well this winter since some lady rear ended it on Santa Fe, so it may be awhile before I can head out again. -
Did you stop wheeling because of the breakdown? -
Congrats on MJOTM Rick. I think I have some pictures of the day we went to go pick your truck back up on Slaughterhouse... -
Smoke after running for about 20 minutes
james750 replied to 87Chief's topic in MJ Tech: Modification and Repairs
That oil pressure reading is a tad high, I wouldn't want my oil pressure too much beyond 60 psi at any RPM. That may be something to look into as well. -
Keep in mind, a little oil on the exhaust makes a lot of smoke. Also your oil pressure is much higher at cruising/driving RPM's vs. idling, and much more oil will come out of cracks in the cover. -
What color is the smoke? Blue=oil white=coolant black=unburned fuel -
adjusting steering so wheel is straight
james750 replied to MJ86YJ90's topic in MJ Tech: Modification and Repairs
And then break your clock spring when it gets hyper extended during steering from lock to lock... -
how many cranks before it starts?
My MJ takes 4-8 turns to start, always has. The 97+ XJ's (have three of them in the family) used to always start on the first 2 cranks, but now two of them have fuel pumps that do not prime to operating PSI at key on and they take 10-20 cranks to start if the pressure on the fuel rail has depleted. If they were mine (these ones are my parents) I would have replaced the pump, but they have been running it on the old fuel pump now for about 3 years on one of them and 1 on the other with no other problems. -
what is causing battery light to be on?
14.9 is a little bit high, but it is still in an acceptable range. It could be a voltage regulator problem. Does the voltage spike if you increase RPMS? -
Carpeting/Trim For Rear of Cab
james750 replied to 1987Comanche's topic in MJ Tech: Modification and Repairs
I got lucky and found one of these carpets in a JY MJ a few years ago with matching interior color. My base model didn't have one either when I got it. They are bolted to the floor at 3 points along the bottom, the factory floor carpet has three cutouts that the bolts/ brackets would go under at the back of the cab. It also rests behind the trim piece under your rear window. They have a cutout in the center for the jack handle to be able to still clip to that bracket, if your MJ still has that, if not they can be found at TeamCherokee.
