watchamakalit
Everything posted by watchamakalit
  1. I used the TJ boot in my truck fit great.
  2. I don't have any experience with the long arm kit. Did you try the search?
  3. can't you just run it up the next mountain to slow it down?
  4. hahaha i like it.
  5. Absolutely a beautiful build. One of my favorites.
  6. wow. Can't wait to see the strip kit installed.
  7. For those with experience. Does it make a better trailer if the rear of the mj is kept? Or does it make a better trailer to build a dedicated frame?
  8. Man I wish I could have made it. Glad to see a good turnout so far. Be safe and have fun.
  9. Contact Core. Their customer support is superb. They will be happy to work with you to remedy the problem, I am sure. I have their track bar and adjustable short arms and they were very helpful through all my install.
  10. Looks to be a control arm and a swaybar end link. Shouldn't be too bad of a fix. Hopefully there is no bend in the frame side control arm mount.
  11. So far so good.
  12. ^makes me jealous with all his jeep time and camping trips.
  13. Patiently waiting on pics of the carnage......
  14. I have a set of torque sticks. They are a really convenient tool. However we still always check with a torque wrench just to be sure. I usually torque mine to 80ftlbs. Seems to hold the wheels on good. Lol
  15. Less than $5 at the hardware. New grade 8 bolt, washer, and nut. First was to drill out the hole to 7/16". I only had to remove a very slight bit of material. Next was to test fit.... Tack washer in place And final product. Fresh paint makes the welds stronger. Lol All in all a pretty solid fix in my opinion.
  16. Sucess! Off to the parts store I go.
  17. I don't need a trackbar and the bushing isnt worn. That is a core 4x4 tier3 double shear trackbar. Their bushing seems to be oversized. Time to run to the hardware and fire up the zeus machine and get it over with.
  18. Hadnt thought of that. Just assumed it would be a factory only kinda thing. Gotta get the old one off first....
  19. I am in need of the hard line from the drier to the condenser. Seen with the twisted end in the photo. I have checked junkyard local with no luck.
  20. I just checked. The trackbar bushing inner is exactly 7/16". So If I get a new 7/16" bolt, washer , and nut. Drill the holes and make a new flag nut it should solve the issue right?
  21. Everyone says hardened washer. Does that simply mean a grade 8 washer like the local hardware store would have? Or is it something I have to special order? Given the amount of slop in the track bar bushing itself I am tempted find a bolt that fits it snug and get a washer to fit said bolt. Then weld on the washer and make a new flag nut. Sound like a solid plan? Am I over thinking this? I don't have immediate plans to wheel this truck but it might see some light to medium trail use at some point in the future. Just want to make sure all is well and reliable.
  22. ^ Lives outside the rust belt
