Everything posted by watchamakalit
I don't think its hack work so much as just not something a show truck or restomodder would do. I guess it depends on the use of the truck. If your concerned with what the final product looks like, take 15 mins and grind them off. If the looks are not a concern of yours then leave them. My personal opinion, I would take them off and take the opportunity to paint the axle while its out of the truck.
lower trackbar bolt hole
watchamakalit replied to watchamakalit's topic in MJ Tech: Modification and Repairs
Just took some pics. Here is what I'm dealing with. The factory holes are oblong front and rear There is visible slop in the hole to bolt fit. And the bolt is sloppy in the trackbar itself. So I am open to suggestions. Core says I can drill the trackbar if nessecary but it doesnt look like I will need to. -
Finally found one...Now it has a new floor.
watchamakalit replied to watchamakalit's topic in Member Projects: Your Comanches
Well my spare is back in. I lost a turbine and brand new tire some time ago. The factory bracket under the spare folded in half and I never heard or felt it go. So I made a new bracket, don't worry the knot and nut are temporary till I run to town. Also on the list was a tool to kae lowering and raising the spare simpler. And after the last instance no chances taken. It now gets a dedicated ratchet strap backup. I'm not loosing another turbine. Now to dig into the trackbar....... -
Glad nothing bad happened and good to hear the bypass worked. Time for all new stainless hoses. Lol
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
I never ruled out the washer idea. Just wanna makee sure I am fixing the issue as permanently as possible. I don't want to just bandaid it. If the original slop is from the trackbar being loose on the bolt the washer won't fix that. -
^ has a confusing user name. Is he a fan of lug nuts off of flats? Or is he a fan of fake shotgun projectiles?
Therein lies the issue. I need to repair the damage as well as fix the problem. -
After some thinking and looking I'm not sure the BMB bolt will work for my situation. It won't take care of the slop in the axle bracket made by the old bolt. I am looking strongly at this kit which come with a new larger bolt and sleeve. Any thoughts? https://kevinsoffroad.com/products/kor-9906-hw-track-bar-upgraded-hardware-kit -
New snap ring in and transfer case reassembled. New tires installed. Hoping to get pan gasket, rms, and trackbar taken care of tomorrow. -
People Going to the All Breeds Jeep Show Headcount
watchamakalit replied to 89 MJ's topic in The Pub
Well I get to be the last minute cancellation. I will not be able to attend this year. However I'm all ready making provisions for next year. I hope all you that make it have a great time and bring home an award for the CC. -
mini beast Project: Stock To Beast!!!
watchamakalit replied to MiNi Beast's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I hear the residents are a little silly from time to time....... -
Its a process called magmafluxing. However I don't know how it works but it'll highlight the cracks.
Plannned on it. They are both sitting on the shelf waiting on me. -
Hood light repair?
watchamakalit replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Is the connector the same on the fords? -
Well she is back on stands waiting on parts. Pulled the tailhousing to reseal a leak and discovered a broken snap ring. I must have stressed it when I tore it down. I have a new snap ring on the way. Guess I'll take time to fix a trackbar and oil pan gasket while its down. -
Very rough idle and fuel leak on rail
watchamakalit replied to Jesse J's topic in MJ Tech: Modification and Repairs
can't say I remember being hit by any of my 4.0l's. I got smart after the hei -
Never had much experience with a GM hei setup have you? I'm a firm believer thats one of the strongest "spark checks" I ever experienced. -
Torq's 2nd 1991 Eliminator
watchamakalit replied to Torq_Shep's topic in Member Projects: Your Comanches
I heard if they are black they are bigger..... -
Solid advice. Putting a bad head on a motor will cause alot more aggravation than its worth. Have a capable shop give the head a good work over. Its worth the peace of mind.
I just put a set of atx's on my truck. I went black wall. -
Its amazing the difference a dash will make in the look of the interior.
I bet it would.....
Hood light repair?
If you send me your light I will gladly fix it and put it on my truck....
