ComancheKid45
    3
Everything posted by ComancheKid45
  1. Hmm, intresting but id hate to see a peice of History like the Street Comanche be subjected to this....idk
  2. I'm in for a few bucks!
  3. Or.....Purchase a trailer that can fit the MJ and the popup camper on together and tow with the Cummins :dunno:
  4. :yes: That pretty much sums it up!
  5. Finally decided to swap out the worn parking brake assembly, I got the old 1 out figured id compare. While i was under the dash I found this nice little bundle of wire, This was very likely the culprit to the electrical issues this truck was plagued with shortly after i took possestion, I'm glad it never escalated into anything worse, and I'm very glad i found this and was able to take care of it this evening. As mentioned before, there is a suprise coming for this truck....It should be ready to ship Saturday and hopefully be available for me to share with you guys sometime next week... :)
  6. Haha o ok, i just got excited i guess. Oops
  7. I believe i see 5 leafs in those packs :brows: Metric Ton! Nice looking truck bud!
  8. got a few flurries and rain here......dissapointing.
  9. Pull the lower radiator hose to drain the system, Than if your gonna use a hose to flush the system just undo a hose or 2 at the Thermostat and run water through everything till it is clear from the other side. When youre done and ready to refill either jack up the truck as high as you can from the rear axle or back it up onto a slanted service. Crack open the coolant temp sensor on the back drivers corner of the engine and fill system untill coolant begins to flow from that area. Drop the truck down and Let engine reach operating temp. Then fill coolant bottle to spec.
  10. Still search 1-2 times a week, Still have come up empty everytime in the search for a Comanche model or diecast...
  11. My Spartan has been great in my D30, I noticed the other day that Rockauto.com offers Spartans for less than $300 ;)
  12. Just to be sure, pull them off and make sure theyre bare metal where they connect to the battery post. If they are not and theyre powdercoated all the way around then theres no connection being made to the battery...I had that problem with a set of terminals awhile back ;)
  13. The new ends you put on, were they color coded? Like a Black and a Red 1 or were they just bare metal?
  14. I'm on your side as well! Great stuff!
  15. Well Ive had a clunking noise arise from the front axle recently, after throughly checking the brakes and unit bearings I came to the conclusion that it was my Locker. So I ordered up a rebuild spring/pin kit and dug in tonight. Got the old stuff out And got the new in and the carrier reinstalled this evening, Itll spend a day or 2 in the garage till i get some gear oil and get the rest back together. I immediatly noticed improvement in engagment and hopefully this cures my noise issue. If for some reason it doesnt, well atleast ill have a fresh locker! hahaha
  16. Either or, but you can just use RTV without a gasket. just make sure both mating surfaces are very clean before reinstallation. ;)
  17. :( True, but I'm gonna continue to fight it in every way i can! :wrench:
  18. looks like a 97+ XJ console, Great progress!
  19. No way dude Cinnamon Life might as well pack up and high tail it outta there, If the real Lucky Charms show up!
  20. ^^^ You musta watched that movie on TV last night. hahaha
  21. Very nice! Skidplates and all. The reserve is likely pretty high though
  22. Cool deal, just began reading some of that article this week.
  23. I just screwed hard can coozies to the floor in Oscar...haha
  24. Dorman part # is 03269.
  25. Awesome progress and adventure pics! Keep it up!
