Jeep Driver
Jeep Driver
    20
  1. Do you have a 4 cylinder or a 6? 2.5 or 2.8? Why did you think there was more than one O2?
  2. Don't know about the 86 and this is the first I've heard of the O2 at the Cat. O2 is at the exhaust manifold or in the down pipe about 6" below the manifold.
  3. Yes, order per the year. That said, nothing will really change. And if you are changing trans any way, you'll want a '94+ to get the external slave/bell.
  4. No, you must keep the O2.
  5. That pic gets around......... Thank god I'm not fat.
  6. Are you actually rebuilding the engine?
  7. I've got Hancook on the XJ and the Nissan both are excellent Highway Tires both are good in the snow and rain. I have Nitto on the MJ it's a fairly large Tire but it's excellent on the highway very smooth I'm getting ready to go up in size and I will get another set of Nitto.
  8. Scroll down to two wire..........makes more sense to me now. https://www.classicinstruments.com/tech-info/testing-speedometer-signals.aspx
  9. Good for you!!
  10. I've put a lot of weight on a tailgate, from motorcycles to materials, never have a gate fail. Use a little common sense.
  11. https://www.esurance.com/info/car/myth-comprehensive-covers-everything Comp does cover animal collisions.
  12. Sorry to hear...............
  13. For a double cardan the pinion is supposed to be looking directly at the TC, from what I see here the pinion angle is correct. http://www.billavista.com/tech/Articles/Driveshaft_Bible/index.html
  14. I have not installed these yet but you do have options.
  15. Yeah, and I'm curious as to what hood he's using.
  16. When I look up 2004 Escalade VSS it shows that it reads a tone ring, is the VSS in the Atlas gear driven? Are you assuming that the values or signals are compatible? I'm not smart enough to mix and match decades old tech with more modern tech. Nor do I think you're going to run a single wire from a GM PCM to run a tach that was driven by a Chrysler PCM that you are no longer using. What is driving the tach? Lost on me...............
  17. See my build thread. I'll do one more vid after it's installed.
  18. https://www.ebay.com/itm/1985-92-Jeep-Comanche-tail-light-LH-NOS/202444613012?hash=item2f22a3a594:g:DeIAAOSw--xbpQmR
  19. Just finished wiring mine up tonight. There are always options.
