Everything posted by relyt120
:dunno: Last minute or so was pretty good
You've just made my desktop background rotation :thumbsup:
Cummins B3.3 Powered Mj Build!
relyt120 replied to krustyballer16's topic in MJ Hardcore Tech: Epic Journeys to Greatness
They show up on my laptop and phone... Might just be me, can anyone else see them? Okay I opened it on my desktop, can see them fine. Wow that paint is beautiful can't wait to see it in the sun!- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Cannot see pics! :fs1:- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Driveway Ornament To Daily Driver: 7 Years!
relyt120 replied to Minuit's topic in Member Projects: Your Comanches
:oops: I've got one in my garage if you want it -
Are you running the 95+ valve cover? I agree with everyone about the blue felpro gasket, good seal...I even broke off one of the valve cover bolts at one point and it didn't leak. -
Yeah i do -
I'm out of town for 8 days starting 6-6 but any weekend day or Monday after that I would be down. Sort of think it would be cool to crash a car show -
Hood lock and/or kill switch
relyt120 replied to Incommando's topic in MJ Tech: Modification and Repairs
You could easily put a kill switch the ground to the starter relay. Its easy to find and labeled on the relay. -
Glad to hear everything is coming back together for you :thumbsup: We should try to get some of the TN guys together soon. . :MJ 1: . -
I think I had the same issue with the holes not all lining up. I just used the bolts that lined up. No issues in two years though I don't use the ball hitch at all.
My 86, 90 & 91 Into a 99 MJ!
relyt120 replied to DirtyJeepGuy's topic in Member Projects: Your Comanches
:needpics: -
clean comanche
relyt120 replied to Lowly's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
:rotf: That'll be the day ... -
all renix connectors 87-90 should be the same for the rear harness unless a PO changed it out.
Also, soon I am going to have to do something about the door hinges...I'm having to hold the door up a bit to close it some times. Hope the door doesn't try to fall off :crossfingers:
Went to the JY today and decided to grab a couple of door checks to replace my busted ones. I got two passenger side checks from a couple of Cherokees. They are identical on both sides. "Check" out the results:
I got the checks swapped out. Used two passenger side XJ fronts One of them was from a 96 and it had the rubber part Rock frog mentioned. Turns out if you play your cards right you can swap them out by just removing the interior door handle; you can reach the back side from the opening for the handle. Just be sure to grab a hold of the back side before you remove the bolts or else it will fall into the bottom of the door. :thumbsup: Thanks for the advise everyone.
:agree: :needpics:
Sportruck To MJ Project Shoshone
relyt120 replied to 89MetrictonJeep's topic in Member Projects: Your Comanches
Nice looking truck :thumbsup: Welcome :waving: -
Diesel MJ in south jersey
relyt120 replied to dunnc1991's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Diesel Metric tonne with amc 20 rear and waggy headerpanel, pretty cool -
2WD Comanche Front Calipers
relyt120 replied to Jeff78623's topic in MJ Tech: Modification and Repairs
Here is the PN from advanced auto: Part No. 18-4182 http://shop.advanceautoparts.com/p/wearever-brake-caliper-unloaded-caliper-18-4182/5621879-P?searchTerm=caliper#fragment-3- 3 replies
- Front 2wd Axle
- Front 2wd brakes
(and 1 more)
Tagged with:
