swamprat
    Howe, Texas
  • Interests
    jeep stuff
swamprat's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. are your tires properly inflated? last time you changed oils? i average about 20-22 in my mj, the key is maintenance.
  2. i had the plug to change over, i had the full HO harness it was just hacked to hell by the previous owner ghetto rigging it after the accident.
  3. for future reference, HO tail light wiring: Black - ground Brown/Green - back up lights Blue/Red - running lights (parking) pink (salmon) - brake & right turn signal Green - brake & left turn signal Renix taillight wiring: Brown: Right turn and brake light Black: Ground Blue: Tail (parking) lights Brown with white tracer: Backup light Grey with black tracer: Left turn and brake light so renix to HO plug convertion would go as such: Black - black Brown/Green - brown/white Blue/Red - blue Pink - brown Green - grey/black
  4. colors are different from renix to HO, looks like i need to do some more digging
  5. as long as the color codes are the same between the years, i can swap them. i've already got the bed off and ready to install my straight one. and the donor wasnt factory trailer wiring. it was a really clean and good wiring job.
  6. My truck is a 92 sport, the donor is a 89 Pioneer.
  7. I bought a new harness for my comanche, and its different than my factory one. only thing I can think of is my jeep doesn't have factory trailer wiring and the harness does. Does anyone have a diagram of both harnesses so I could merge the two?
  8. Its ok I found some $40 a set an hour away. Going to snag the other three sets next paycheck.
  9. Cheapest I found on ebay was $250, for that I can almost buy another mj
  10. after searching endlessly for a set of taillights, i have resorted for a nation wide search. i am in the market for a set of MJ tails, willing to ship. i'm just really tired of the S-10 lights that make bulbs go out almost weekly. -ian
  11. ok little more update, i have a co worker with a 96 2wd xj he is scrapping, so i am getting all of the aw4 stuff out of it. pedals, harness tcu, cables, everything. a buddy of mine is giving me a 21 spline 242, and all i need to get now is a sye for that 242 and a custom driveshaft for my MJ. that should be everything i need for this swap.
  12. So all the trans harness and stuff is completely seperate from the main harness, except for power?
  13. How is the baja shifter on the road?
  14. pretty much as the title says, I'm looking to make my 92 mj 4x4 on my college kids budget. mecanically eveything will bolt up fine, but I'm worried about what i'll need to add for the aw4 to operate. i found a good deal on a bajashifter from radesigns and from what i understand that should be enough to atleast get the truck moving again. but seeing as its currently my daily driver, atleast till i get my turbo swap done on my impreza. i don't want start swaping things with out knowing if it'll work right.
