DirtyComanche
    11
  1. Interesting idea. Easy to do also. I have a master switch have for the battery buried in my XJ. You would just need a piece of 8ga wire to bypass it though, providing you realize what's going on. But it's dead in the water otherwise. Also really handy is the NSS is so poorly adjusted that you need to wiggle the shifter while starting it, however I intend to fix that. TMR customs sells a battery disconnect that the handle comes off when turned to the off position, acting as a key. I would have bought that style over what I have, but I was not aware of it at the time.
  2. See my last post. You just don't have to do anything to the head. Don't be afraid to use a BFH. I've had more than a few of the roll pins come out in pieces...
  3. That's too bad. Grind the head off with a die grinder. A rolock pad with 40 grit would make quick work of it. Get a good 1/4" pin punch and a little 2lb sledge and go at it from the top. Dousing the hinge with oil and working the door back and forth while doing this will help. Otherwise, pull the doors. It's not a big deal. Just make sure you have a good quality torx bit that goes on a ratchet. They will be much easier to drive out with the doors off since the hinge is unloaded and you have more room. That's me, YMMV.
  4. I have modded 2dr bucket seats in my 4dr XJ, and the covers are beat and gross. I'm not looking to fit different OEM covers to them, rather just a universal cover. Has anyone purchased any off Amazon or the like? How well did they fit, would you buy them again, etc? Just want a grey or black. Really looking for people to not have the first reaction of 'Eww' when they see the interior. :rotf:
  5. That. Cheap, effective, available locally, and less likely to break than the OEM style roll pins. Or, if one was interested, now would be the time to do quick release hinges. I have them on my XJ just so I can get the doors off for maintenance.
  6. I was going to say it won't stay, but if it's the foamy stuff it probably will. Contact cement, despite being 'for use on rubber' doesn't hold rubber that well. Great idea, I'm going to have to see if I can find that stuff around here.
  7. 88 and 89 have some major wiring differences. If you want I can look at my 89 FSM to tell you if that matches it, but I'm thinking it does.
  8. I'd write off the front tires. They are time bombs if you try to use them. The D30 might need new seals and the ball joints may not last long after that. Brake calipers might not be okay either. Otherwise it should be okay. Forget the engine and Trans. The engine might be good for a core, but I wouldn't even do that given that I could get a better core for nothing. 231 might need new seals, I doubt it got hot enough to really wreck it, however they really aren't worth anything (I started throwing them out) and would find a known good one before bothering with that one. So, I think you've really got a box that can be fixed, a tailgate and lights, a set of rims, a rear axle, and maybe a fuel tank and some odds and ends. Value is subjective, but I could sell that D44 for $400 easy, so I'd probably go as high as $700 or so. But I know I could use that box (I have one that had a tree fall on it). Really up to you what's it's worth though.
  9. Hang on, listening to it... Pull the lead wire from the coil to the disty, see if it does it while cranking like that. If it cranks cleanly until the battery starts to fade (30 seconds of cranking at least), I'm guessing it's actually an issue with too much timing advance during the start. Why this would be is something to think about.
  10. How was the battery actually load tested? 90% of the tester out there are complete garbage. Being who I am, I'd put the battery from my plow truck in it and try it... Because as I see it, you've either got a bad battery, a silly issue (loose connection somewhere, you could try making sure everything is tight when hot), or real problems. 2 minutes to check the big ground on the block and big positive connection on the solenoid, and wiggle the battery terminals to make sure they aren't loose when warm, then I'd move on to swapping the battery. If it's real problems, it's a whole post as to of where I would go with that.
  11. And who is that....????
  12. I'm still liking Gangrene. Even if it isn't very nice. I've debated 'The Green Hole', as it will be a money pit (a hole to be filled with greenbacks), but there might be something along those lines that is better. Also on the radar is 'The Green Hornet', which might be overdone, but I'd be specifically alluding to a vehicle that appeared in several of the old Pink Panther movies. This vehicle was less than reliable...
  13. Princess Auto has the other style (shorter and fatter ones) for $13.99/each normally, I think. And they go on sale from there. Of course they charge more for the yellow diesel ones. :???: So if anyone ever steals my 'gas cans' they're going to have a fun time getting their car to run with what's in them. :rotf:
  14. You really don't need to drain the tank to do the sender or pump. I doubt a dealership would even do that. You can test the sender/wiring/gauge by pulling the whole assembly out and moving the float up and down manually. Just make sure it isn't going to hang up on anything when you put it back in.
  15. I had a stack on my old truck. It's very pointless. I don't remember why I did it, I think just because it was easier than bending up a new pipe that went all the way to the back. There's a ton of space, as long as you still have leaf springs, to tuck the exhaust up so it won't be damaged. Just run a dump at the rear axle if you're afraid of crushing your tip. Or run it through the bumper if you're ballsy. But if you want to do it, it's your truck. Keep if mind if you put anything in then bed you will need a heatshield around it. Edit. Just saw you said stacks, implying two. That would be harder than just running the exhaust out of the back and even more pointless.
  16. Yeah, it will be fine. Pull the cover and make sure everything is in good order and go from there.
  17. Yeah, a Lada probably doesn't have clearcoat, I don't see Ivan and Boris thinking that it was a necessary step... It also probably has super nasty carcinogenic toxins in the paint, which help it to last longer anyways. :rotfl2:
  18. Let's face it. 1992 was 24 years ago now. The only way clear coat from that era lasts that long is if it doesn't see sun.
  19. Does anyone know what that black stuff they used on the factory connectors is? It honestly seems to work pretty well. I'm not exclusively a jeep guy, and I actually find the Jeep electronics hold up better than many of the other brands...
  20. You've bumped an old thread. You would be best to post the specs of your MJ. The chances are that it will share driveline components with a like model XJ, and that will be the easiest way to get the needed parts to do a 4wd conversion.
  21. The later (dual diaphragm) booster is the exact opposite of compact, just a FYI. Probably the best compact option is a hydroboost setup, but they are typically pricey as I am not aware of a junkyard option that doesn't need modifying to work.
  22. Depends how far you stretch the word corrosion. They are oxidizing just sitting on the workbench. Either way they certainly can deteriorate.
  23. I beg to differ. However, I will admit that a SYE is largely unnecessary for a street driven rig with minimal lift and good driveshaft angles. I was merely saying that if it was me at that point, being that his driveshaft doesn't fit, and he's already hacked the output, I'd probably just buy the flange or build the DIY one. However, I believe Jeep ownership is the anti-economics and will regularly purchase and install 'upgrade' parts that probably are addressing issues that only reside between my own two ears.
