DirtyComanche
    11
  1. I'd not worry about it since the head was replaced.
  2. Pretty much. More driveway obstructions. Heaven forbid the sun should shine on the gravel,
  3. Umm. Now the proud owner of two Comanches...
  4. I have 2~ rusty FSJs also. They're in line before any Comanche project at this point. I really don't know what to say though. I'm betting he would go down to $1200 today. I could sell the XJ rear d44 for $400 easily. Arrrgh.
  5. Price went down to $1500 for the two of them... hmm.
  6. There's some nicer ones out of province, it might even be the best bet... Half tempted to phone this guy and see if he's starting to get desperate: http://www.kijiji.ca/v-cars-trucks/lethbridge/1987-jeep-comanche-pioneer-pickup-truck/1146589878?enableSearchNavigationFlag=true The one I looked at tonight was 'alllllllright.' It's been spray-bombed green over god knows what. I would call the box a write off, magnet didn't stick in all the usual places, feeling it up some of the paint flaked and I could see my flashlight shining through from the other side. :doh: Rockers are pretty done, but I can get over that since the floor and door sills were still solid. Clutch master leaked and ate the firewall, not the hardest repair in the world but it is time consuming. 4.0L ran nicely and has an AX-15 in it, so that's not bad. Clean basic grey interior with buckets. The guy seems fairly honest and was fine with me saying I needed a week to think about it. Parts truck has a title, box got crushed by a tree over 1' in diameter and MIGHT have tweaked the frame in the process. Sheetmeal on the cab looks okay on it too, not beyond the point of being able to be saved. Parts truck has no engine/trans. Also the package comes with a D44 that allegedly matches the front axle in the 'good' truck, just add a driveshaft to complete the 4wd swap. And probably 10 million little things. :rotf: Pic of the green one: Image Not Found He's asking $2500 for the both of them, I think it's steep. Asking and taking are two different things though. Honestly, part of me just wants the parts truck.
  7. My '15 JKU runs pretty well for what it is Mine is a 3.8L rebadged minivan. Actually, the 2.5L 5spd base model XJ might give it a run for the money, if it was tuned up right with factory 28" tires. Let's just say I wouldn't put pinks on that race. :rotf:
  8. What's notorious about the 4.0L? That it will outlast 90% of other engines? That it actually has low end torque? That it actually wasn't designed on a computer by somebody that never opened the hood of a vehicle nor would be able to? Get new PCV parts. Pull the valve cover and do the PCV mods and cleaning. Put the compression tester away. Drive it.
  9. If anyone wants to hear my drivel... The diesel one wound up having nowhere near as clean of body as I hoped. Detailed pictures were sent and it would need a large repair around one of the doors, above at least one of the wheel wells on the box. and probably some work around the window seals. Basically, it was not 'clean and rust free' and didn't seem like it would be worth the hassle and added cost of going to get, given that I felt the engine is likely pooched. I had somebody with one minus a driveline, said the body was pretty near mint. Perfect, I have a spare everything from an XJ that could go somewhere. It's stored a couple hours out of town, and he says he's going out there and can get me a bunch of pictures. Alright... I was half tempted to just hitch the trailer up and take some cash since it's a nice drive anyways, but I actually lent my trailer out for the weekend. Last night I text him to ask if he took pictures "Oh, sorry, when I told the guy whose property it is on that I'm selling it, he bought it." Arrgh. There's another one that I might go look at tonight, if it works out. Comes with a parts truck. Pictures have already verified one rocker and cab corner is MIA other than the bondo. It's repainted, so I'm not sure what else is being hidden... And it's in the midst of a 4wd swap that has probably been going on for years, so who knows when it was last driven on the road. It just started snowing (was beautiful spring weather before), so I'm not sure that it will help me much. Honestly if the parts truck has a title it looks like it might be better, since it's factory paint so I'll at least know where the rust is. So, in short, I got nothing.
  10. The ball joint axles have proven themselves... Basically if you air it out the uppers will get sloppy in short order, and if you're really hard on it they will actually start to pull out of the knuckle. There's a couple guys who have been boring out the knuckle and the taper bushing to run a lower ball joint in the upper for those reasons, but for 98% of users it isn't needed. I debated sending my knuckles out for it, but I can't justify it. And unlike the Ford kingpin knuckles, the ball joint ones rarely break in half. Kingpin Ford knuckles are notoriously weak, and on used axles (not wheeled) it is common to find them cracking if you look closely. Throw big tires at them and go wheeling and they break in short order. To do everything over again (and stay with 1-tons) I would just buy a F-Superduty D60, preferably the F-450 and bigger version, and be done. 35 spline inners, outers, and hubs, large unit bearings that actually last, low profile hub design due to the unit bearings, bigger/better ring gear, massive u-joints in the axleshafts, etc. ftpiercecracker1, have you tried phoning heavy truck wreckers? Places that do semis and equipment... The ones around here seem to get 1-ton trucks fairly often.
  11. I can't stand driving the 2.5L... They make my JK seem fast. Is there any glass left in that thing?
  12. I had a 99ish Dodge 1-ton 4wd diesel on my trailer, thought it was in gear (swore I checked), undid the straps and kicked the chocks. It took off and mangled my ramps on the way off, then mowed over some trees before coming to a stop... Was really glad I didn't get caught up in that thing when it went. Be careful...
  13. I do not consider the D300 to be strong. Stock for stock, it's on par with a wide chain NP231. Upgrade the outputs and it's maybe a bit better than a NP241, with the advantage of being able to be twin sticked. You can just throw money at a D300 all day long, and in the end you would be better off just buying an Atlas, or just rebuilding a $100 NP205. Hell, I have less in my EcoBox/NP205 setup than most guys have in a built D300... Plus guys like to flip them, because you can, then they do nothing but leak oil, and that irritates me. But that's me, this is IMHO. There is factory closed knuckle D44s that run a steering arm off the kingpin, it should not be unsafe by any reasonable measure. People get all weirded out about steering components, without realizing that factory steering components are often beyond garbage. Look at how aftermarket kingpin D60 arms are made, basically if it's like that it will be as strong as the knuckle is (if not stronger). The axle is an orphan in that it wasn't popular to begin with, was less popular with the aftermarket, and nothing comparable or compatible with it has been built in 50+ years. There is some info out there on on them if you dig for it, such as you can swap disk brakes on it if it has drums (for years people didn't think you could), and you can fit better axle shafts and hubs on them. However, it's not like pretty much any of the normal mainstream axles where you can just buy whatever you need or want and be done with it.
  14. I don't know what to make of you having a closed knuckle axle in that year truck, it's swapped in or something. Are you intending to keep your wheel lug pattern, and what pattern is it? The axle should be full width (67"+ wide), which means the GM squarebody trucks have what you're looking for as an easy swap, and there was eleventybillion of them made, however you're either going to have to buy a D60 ($$$) or a 12bolt/D44 and aftermarket knuckles ($$$). Also, all the D50s and D60s are 8x6.5" pattern, unless you get too new, then they're the metric 8x170, which isn't going to work well if you're trying to keep your wheels either way. You should be able to put high steer arms on top of the kingpins in the closed knuckle D44... The axle is an orphan, so I don't know if anyone is actually making arms to do that, but they can be made providing that axle is set up how I think it is. I actually have a J-truck D44 front that would also be what you want, but we're not exactly geographically aligned for that to be an option. If you're having little trouble digging up driver's drop axles that are good (Ford D44, D50 solid, or D60), you could consider putting a Ford NP205 in using the GM TH-400 input gear, you might need to swap your TH-400 output to the GM style also, but I know it is very possible if you can get parts. IMHO, and only IMHO, the D300 is only good for selling to somebody that actually thinks they don't suck.
  15. Have you used that bandsaw yet? Like it? I want to upgrade mine, it's small and cheap... No cold saw or dry cut yet? I'm thinking that will be my next purchase since I destroyed my cheap Rage3 and can't bring myself to go back to an abrasion saw.
  16. I believe a JK truck is supposed to be in production in the next year or two. If it will be like that one or not I don't know, but Jeep has been rolling out a lot of JK based truck concepts to gauge reaction. Reaction so far has been quite positive. And to the OP, I would never sell a Jeep to replace it with a Toyota.
  17. That's terrible. But you could probably change it to that, then change your own display preferences to not show avatars, thus shielding yourself from your own terrible avatar.
  18. Like it says. :dunno: Is it annoying, or do you get jealous? :rotf:
  19. Reminds me, there's one in the boneyard here. 89, black, longbox with a 4.oh. It makes me sad every time I go there. The body damage is something I could fix just working on it in the evenings over the course of a week.
  20. I'd personally guess alternator. As said, pull the connector for the A/C clutch. If it's still there, I'd pull the connector on the alt. If it's still there, well, it ain't either of those things. :laughin:
  21. Talking to the owner more, he said constant bubbles in the coolant, couldn't get it bled, it blew a brand new radiator apart (hard to say what happened there?). He was trying to convert it to an open system, and it didn't go very well, I could see it being hard since the radiator is lower than parts of the head and intake. He said he tried bleeding it on a steep hill too. Personally my experience with the thermal efficiency of diesel engines leads me to think that I'm still on the right track with a cracked head. Anyways, I've tentatively agreed to buy it, there's another guy that is interested, and he needs to send me a few more pictures (apparently there is a couple rust bubbles), then we'll see if I'm still going to go for it or not.
  22. Swapping a 4.0/AX15/242 into an '86 isn't too bad. Firewall and radiator support aren't hard to change on it either. The only thing I would have done differently is cut the firewall section that needed to be clearanced, and welded a new section in from an 4.0 equipped MJ/XJ. Unfortunately, I didn't have a good grasp on welding, especially thin metal, so I just gave it the big hammer approach. Check my build, in my signature. You'll see plenty of pictures and tips. I'll check that out later tonight, but thanks for the heads up! Looked through your thread, and yeah, the swap doesn't look that bad. I think I actually have the piece of firewall that is different.
  23. My guess is he's doing the dash/gauge cluster and the resistance for the sending units changed... I can't confirm that because I don't have a later FSM anymore. Otherwise I got nothing.
  24. Doesn't mean it's good. Fuel filter new? Try another gauge, or another regulator.
  25. Swapping a 4.0/AX15/242 into an '86 isn't too bad. Firewall and radiator support aren't hard to change on it either. The only thing I would have done differently is cut the firewall section that needed to be clearanced, and welded a new section in from an 4.0 equipped MJ/XJ. Unfortunately, I didn't have a good grasp on welding, especially thin metal, so I just gave it the big hammer approach. Check my build, in my signature. You'll see plenty of pictures and tips. I'll check that out later tonight, but thanks for the heads up!
