11
question about axles and gauges
DirtyComanche replied to vandior2001's topic in MJ Tech: Modification and Repairs
I'm surprised you can find a rear D44 easily, but since you can I would say it's the best way to go. 35s are the marginal limit of a D30. At that point there is a lot of factors to consider. Wheeling style, power, weight, actual behavior of any added traction device, extra reduction, etc. With the gear style in the earlier D30s you will be able to break the ring and pinion at that point, and good aftermarket chromoly axleshafts, u-joints and a full case locker/spool will pretty much guarantee that outcome. If you're just going to tool around on trails, stock engine trans/tcase, I would not worry about it too much. If you want to do more than that I would go another route. Even the JK axle route, they changed how they cut the gears in them and they will actually hold up to 35s at a 5000lb operating weight. So, define what you intend to do and I will give you a more specific recommendation. Since you're regearing past the carrier split I can only assume you intend to buy a traction device. -
The other problem is some of the 'obsolete' stuff is basically only made by Timken at this point. I suppose if there is a hole in the market that the Chicom manufacturers will pick up the slack though.
Are they actually going to cease production of all old bearings, or just not pursue contracts with OEMs in those sectors? If they cease production on old P/Ns of bearings, it will be ugly.
Torx size for seatbelt
DirtyComanche replied to 13 Legion's topic in MJ Tech: Modification and Repairs
Sorry, it's a T50. I have an impact set, T30-T70 and E10-E22. Worth every penny. -
T-45, IIRC. Might be a T-55 though. I'm going out to the shop right now so I'll check. -
Not having much luck getting another MJ...
DirtyComanche replied to DirtyComanche's topic in The Pub
Anyone got any ideas for a name? Gangrene? Or is that too negative? -
What is the fastest you've ever driven your MJ?
DirtyComanche replied to big66440's topic in The Pub
Mine only went 65mph on my trailer. But I was towing it with a Cummins so I probably got better fuel economy than if I had been driving the MJ. -
Unless you're getting some amazing deal on those axles, pass... No point swapping a LP front axle in, even if it will 'work'. I'm hoping that rear was at least an 8.25", because swapping a D35 would be a real waste of time.
I misread the OP. As Rockfrog says, try an earlier year. Or just get them to tell you what they have it listed as covering (if they aren't dorks). They likely have it in their computer wrong. Or their Chicom supplier is not building them to spec, in which case try another brand.
Since it is specific to the knuckle, you may have a replaced knuckle... They can break in even a minor accident. Try the newer one.
Swapping BA10 with TJ ax15/np231
DirtyComanche replied to Poley 77's topic in MJ Tech: Modification and Repairs
You can cut that 'sticky out thinger' off the tcase too, IIRC. It's not there for any purpose that matters to us. -
someone tried to buy Blue88Comanches Comanche today
DirtyComanche replied to Black89Comanche's topic in The Pub
Save more money and buy both? -
Still seems odd. Likely the original hubs could have been turned down and drilled to 5x5.5, and the spindles bored for the 1.5" 35 spline shafts (if they even needed to be). But that's me, like I said, I love FF axles.
Why the semi-float conversion? I personally love full float axles...
Yeah, 87 seemed to be the year that they had them on the shelf and went "Shoot, we better stick these things in some Cherokees before they go bad." Picture only, or you don't know, things get changed over the years. I've bought vehicles only for one a couple parts in the past, swap them out with whatever you have on had and resell. I KNOW people would do that for an XJ D44. Personally I'm going to say you're better off with an Exploder 8.8. They are very plentiful, so they are cheap, and they are strong and have disk brakes.
It turns out I know the guy who owned it before the guy who I bought it off. There was a lot of thought put into it. I don't know if all of it was good thought, so I'll have to do some poking around. It's an 88, started as a 2wd, probably a 4cyl at that. He swapped the 4.0L and AX-15 in, I don't know what year any of that stuff came out of but it's a Renix setup and it has the dreaded C101? connector above the brake booster. Tow hooks were very likely added, I will have to see if the braces are installed, but I suspect he would have known to do that. I didn't check too close, but I'm sure the bucket seats were swapped in out of an XJ. Were those mirrors the factory option tow mirrors for a MJ? It has been converted to an open cooling system also. There is no windshield wiper reservoir, guess he just never got around to that. I don't know if he bondo'd the body or if he had bought it like that? He also tracked down the XJ D44 to swap into the rear of it, but he took a job in another town before he got it swapped in. There is a long 2wd driveshaft in the 'parts' truck (in it, as in it's in the bed), so I can have that cut down to either fit with the D35 or the D44 if I decide to swap it in. Or I'll see if I can find a SYE and go that route. I'll have to check gear ratios either way. But before I do anything to it I will have to decide what the plan is. And look at all the junk in the back to see if anything in there is good besides just the D44. -
In my driveway. Image Not Found Drove on and off the trailer pretty well. Didn't even need to jump start it, just had to squish one of the lugs on the battery cable so it actually made decent connection. -
problems with over fueling / flooding
Is there a single CPS out there that actually has the wires secured as in the picture? -
I'd not worry about it since the head was replaced.
Pretty much. More driveway obstructions. Heaven forbid the sun should shine on the gravel, -
Umm. Now the proud owner of two Comanches... -
I have 2~ rusty FSJs also. They're in line before any Comanche project at this point. I really don't know what to say though. I'm betting he would go down to $1200 today. I could sell the XJ rear d44 for $400 easily. Arrrgh. -
Price went down to $1500 for the two of them... hmm. -
There's some nicer ones out of province, it might even be the best bet... Half tempted to phone this guy and see if he's starting to get desperate: http://www.kijiji.ca/v-cars-trucks/lethbridge/1987-jeep-comanche-pioneer-pickup-truck/1146589878?enableSearchNavigationFlag=true The one I looked at tonight was 'alllllllright.' It's been spray-bombed green over god knows what. I would call the box a write off, magnet didn't stick in all the usual places, feeling it up some of the paint flaked and I could see my flashlight shining through from the other side. :doh: Rockers are pretty done, but I can get over that since the floor and door sills were still solid. Clutch master leaked and ate the firewall, not the hardest repair in the world but it is time consuming. 4.0L ran nicely and has an AX-15 in it, so that's not bad. Clean basic grey interior with buckets. The guy seems fairly honest and was fine with me saying I needed a week to think about it. Parts truck has a title, box got crushed by a tree over 1' in diameter and MIGHT have tweaked the frame in the process. Sheetmeal on the cab looks okay on it too, not beyond the point of being able to be saved. Parts truck has no engine/trans. Also the package comes with a D44 that allegedly matches the front axle in the 'good' truck, just add a driveshaft to complete the 4wd swap. And probably 10 million little things. :rotf: Pic of the green one: Image Not Found He's asking $2500 for the both of them, I think it's steep. Asking and taking are two different things though. Honestly, part of me just wants the parts truck. -
My '15 JKU runs pretty well for what it is Mine is a 3.8L rebadged minivan. Actually, the 2.5L 5spd base model XJ might give it a run for the money, if it was tuned up right with factory 28" tires. Let's just say I wouldn't put pinks on that race. :rotf:
