Blue88Comanche
Everything posted by Blue88Comanche
  1. so I called most of the local JYs today.. none of them have an AX-15, however one of the people I spoke to said not to buy JY ax15 and just get a remaned or a new one... what are your thoughts? Would a JY tranny be fine? what should I look for when I go to get one (aside form driving 100 miles round trip just to find out it was a 2wd tranny and not the listed 4wd.. again) I did find a AX15 4wd, hopefully, but it is 100 miles away... one way... any other tips or something to look for would be great. Thanks
  2. well my leak was the clutch fluid... i could press the clutch and watch the fluid drip some.. that and my fuses where melting from the dot 3 fluid..
  3. my BA-10 broke... input shaft bit the dust... but i just used gear oil.
  4. will any jeep ax15 bell housing mount to my 1988 4.0? I am doing the BA10 to AX15 swap.. and what type of bell housing should i get? (i know one with an external slave would be the best rout.) but my mec. was saying something about the Crank shaft sensor being in a different spot from the BA10.. My predictions I told him about the BA10 where correct.. He did not believe me when i said that it most likely broke and that it would cost an arm and a leg to rebuild.
  5. well, after work I might play xbox, or watch netflix on the PS3, I have been playing Total War: Rome on the PC while I watch netflix... I also have a tendency to watch recorded TV on my computer while I play the XBOX or PS3.. Punkbuster does not like my ISO of BF2... I have the disk its just simpler to use the ISO..
  6. I have BF2, hardly play it know that I work full time, and have 3 Jeeps... lol :yes:
  7. our Beagle named Chaos, (pictured to the left) is one spoiled little pup that is addicted to chicken... and knows that then the chairs at the table move its time to eat! He eats about as well as us. It is cheaper to get a chicken from walmart cook it and be able to feed him for a month for about 75 cents per day.
  8. I wish I had those pics when I was trying to to my lights... I was kinda lost when it came to where the 10 pen connector was.. :shake:
  9. my guess would be to check your clutch for excessive ware. it could be its time to replace it.. but I am sure there are other reasons that someone will point out
  10. I pretty much ask the same question here is the thread to the answers I was given: viewtopic.php?f=2&t=29833 hope that helps
  11. how are your tires? do they need to be rebalanced or replaced (bubble in tread)
  12. this is one light after i got it wired in.. keep in mind that the pic was taken at night with my iPhone. and it was not put in place 100% where did you get those led replacement bulbs?
  13. the light unit is in the same manner as the factory lights, so unless you can find a LED version of the bulb you may need to hack something in to make it work
  14. my WARN Trans4mer Grille Guard attaches to the bumper mount... there are some spacers between the bumper bracket and the frame. I know its not a very good pic but it all i have at the moment. hope that helps edit: I think I saw some tow hooks online somewhere that did mount in the same spot
  15. I got lucky with mine... they where rust free and just had a build up of dirt and clay on the threads making it a pain to remove
  16. i guess it would be coolant temp not oil.. should have thought just a bit more :shake:
  17. my tranny broke, a/c leaks (and is thus useless for Alabama summer), doors leak, and the pressure bottle leaks.. does that count as "high maintenance".. if so then I feel your pain..
  18. It will not be 100% plug and play.. you will need to swap out the sending units for oil temp and pressure. other than that just plug in the now cluster... also if the plastic is blue on your cluster you need to go for another blue one, same goes for white. in 1990 or 1991 (can't remember what year) they swapped to electronic speedometer
  19. i bought some of those a while back.. I like them, finally have some light in the cab at night
  20. :agree: my cheater bar was a 5 foot chain link fence post the impact wrench was very nice with any luck you won't have mine... on page three is where i did my leaf swap viewtopic.php?f=7&t=29859&start=30
  21. Like learn how to ^&$)ing spell, especially when the name of what you're selling is BADGED ON THE SIDE OF THE VEHICLE. Also, picture or I don't care. Most things can be sold by just a description, but if you're selling a vehicle, put up a freaking picture. :agree:
  22. well i was looking into a engine for my Red Comanche, I was going to get a re-maned engine V8 :brows: or a bored and stroked I6.. not really sure yet.. red does not have an engine right now so might as wall get a "new" one The turbo thing i haven't seen many on our jeeps and was wondering if one of us has done it
  23. I did some searching on CC and could not find anyone that turbo charged a 4.0.. I know some people say is would not be ideal for a 4wd for off road use, but for street use i think it would do great for some extra go.. has anyone done or heard of someone doing that? and would the engine computer need to be "updated"? Just a thought thanks
  24. I got a phone call from the Mechanic telling me the "bad news" about my BA10 tranny... the input shaft broke and damaged some clutch parts with it... ...So i started looking for an AX-15, and the parts required for the swap... I now have 2 Comanches I can't drive... one with an engine, but no tranny, one with a tranny but no engine... and no i am not moving the engine to red, and reds tranny is an auto 2wd and i don't have the drive shaft... so no quick fix
  25. ...when you tell your mechanic your BA10/5 has a tendency to brake, he says it is something else, only to find that you where correct...
