Everything posted by Blue88Comanche
put clear coat on dads new fender. got rid of dads seat cover. bought a set of ten spoke rims for my MJ
good to know that it works! thanks
AFTERMARKET FOG LIGHTS
Blue88Comanche replied to 88AMComanche's topic in MJ Tech: Modification and Repairs
Whatever you're drinking, I'll try one. :clapping: :rotfl2: -
I agree, I have a Wet Okole on my bench seat and the fit is great and so is the quality. what seat cover did you get? do you still have the item number? dad got a cheap one for his bench and it as super baggy and looks tacky. thanks
the 2 inch lift for cheap..?
Blue88Comanche replied to coon.hunter_21's topic in MJ Tech: Modification and Repairs
:agree: when i put the MT springs on the rear it must have lifted the back of the jeep about 3-5 inches from where it was, going over bumps is fine but if i drive through a hole the shocks max out and its not very smooth ride with short shocks -
my uncle has a 1991 300ZX and it has dual 4 inch exhaust. we think the last owner hollowed out the muffler and possibly the cat, all we know is it is stupid loud. I just sold the car he was letting me borrow while my jeep is in the shop and now i need another car to use. we don't really have time or money to get a new exhaust put in it at moment. in theory a exhaust silencer attaches to the inside of the exhaust tip and makes the 4 inch hole a 2 inch as well as quiet it down a little.
a puck or coil spacer is a spacer put between the front coil spring and the frame. as for the shackles it is just a longer shackle however it will wear your leaf springs faster. I would get some coil springs from a V8 ZJ 1997 grand cherokee 4x4. you would gain about 2 inches lift and would go through the same steps as installing spacers. you can get moog brand from advance auto parts for about $80, i have variable rate springs and they smoothed the ride out a lot. i don't know much about shackle lift but you can get add a leaf lift kits for about $100 or so. -
you will need to move the engine wiring harness from the Cherokee to the Comanche. the 2.5, 4.0, and 4.0 High Output all have different engine harnesses.. I think you may need to do some rewiring in the cab but maybe someone will have an answer for sure. you may need to redo the dash wiring because of the H.O. swap and the electronic speed sending unit on the transfer-case
I have done it a few times and installed a new rom on it.. it ran faster and was able to use a faster "h" network instead of the 3G
viewtopic.php?f=2&t=31495 -
Yes, that's what I wanted to do. And thanks for the info! Hopefully he can get one made if he has the time :wrench:
when mt AX-15 mount comes in (hopefully it is the correct one this time) i was going to get some measurements so my cousin might can make a few at Auburn's machine shop. what type of metal should we use, steel or can we use aluminum? the part i want to make is the metal plate that bolts the transmission to the cross member thanks
guess that is more of a dealer option. as far as i can tell however it was the bumper that was sold on the truck.
need some help
Blue88Comanche replied to Blue88Comanche's topic in MJ Tech: Modification and Repairs
i think i found what i needed, it had a nice little picture to chose from.. -
need some help
thanks, should make things a little easier -
about six months ago the transmission went out in my Blue MJ (my DD) it had the BA-10/5. seeing this as the perfect time to up grade transmissions i have everything needed but the transmission mount to attach the transmission the the cross member.... so far the guy on ebay has set me back by 7 weeks.. it took him to 2 weeks to get the part shipped and a week to get to me :headpop: , only to find out that he shipped the wrong part (yes i also ordered the wrong part but the part sent was not even the part i bought) so a week of email back and forth and he said that he would send the part i thought i was what i needed. two weeks later he ships the part, so a week later i finally get the second part only to find that it is an AX-15 mount but its for a wrangler... :fs1: so i sent them another email yesterday and have yet to hear back... :rant: does any one know where i can get a transmission mount for my AX-15, i need the part that bolts onto the transmission to the cross member... i have been looking for the past 7 weeks and can't find what i need, my search only brings up the rubber part...
that could be a stock bumper.. the one on my red jeep is, or at least it says "Gulf Coast Jeep Eagle Mobile ,Alabama"
awesome! i might take a look
:popcorn:
Project Comoche (Ca-moe-chee)
Blue88Comanche replied to BryGuy's topic in Member Projects: Your Comanches
:thumbsup: -
Best cnadidate donor for 4X4 swap
Blue88Comanche replied to Timmmmmy's topic in MJ Tech: Modification and Repairs
here is a link for drive shafts lengths viewtopic.php?f=9&t=20131 i don't know if rear shafts will be the same on Cherokees and Comanches i think there is a wheel base difference -
Blue88Comanche Pioneer 4X4
Blue88Comanche replied to Blue88Comanche's topic in Member Projects: Your Comanches
:ack: yep first time. But now is the opportunity to drop in a locker or limited slip -
front axle is a direct swap, and unless you plan to do spring over axle you won't need reweld anything. -
pulled off the diff cover, had i know what it was going to smell like i may would have waited. the teeth on the ring gear look in good shape
