Everything posted by Blue88Comanche
That was a cool find! Sent from my iPhone using Tapatalk
It’s been a while, so here is an update. This past November we sold the family business, I was out of work for six months till I was hired at Best Buy as the Microsoft Expert. Starting to get caught up on my bills again. But most importantly a new Jeeper will be in the family this February! We are super excited as are our families!
CB radio question and suggestions
Blue88Comanche posted a topic in MJ Tech: Modification and Repairs
I have a bearcat 880 CB I plan to install just had a couple questions before I get started. Where did you find the best antenna location? I’m currently thinking I’ll mount it to my toolbox or the the truck bed near the cab. I read an article that suggested placing the antenna on he driver’s side vs in the center. What are your thoughts? For the cable I think I’ll use RG8x cable. Would you suggest a different cable and why if so? What is the outside diameter of the standard connector fitting? I’m looking at blue sea systems clam grommet to provide a waterproof seal for the cable to pass into the cab. As for the antenna I’m looking at the firestik 5’. They seem to have a good range and are very durable. Would a antenna Spring be suggested? Thanks for you input and suggestions! -
That’s awesome they contacted you.
Blue88Comanche Pioneer 4X4
Blue88Comanche replied to Blue88Comanche's topic in Member Projects: Your Comanches
All right time for another update now that Tapatalk is working again! I completely removed the dash and will be replacing the in dash harness. The heater core has been replaced and the ac evaporator core has been cleaned. After I figure out what I’m going to do with the radio I’ll be reinstalling everything soon. The new shifter cable for the aw4 has also been routed in the cab. It apparently is run through the fire wall to he right of where he master clutch cylinder is located. Between the clutch and aw4 shifter cable: the bottom is the hood release cable and the top in used hole I believe is for the cruise control harness. Still to come: Replace the exhaust manifold Replace the engine harness Swap the AX15 for the AW4 Swap input gears between the NP231 and NP242 so I can keep the NP242. Rout transmission radiator lines And probably a few other things I can’t remember right off. -
Well y’all are on top of things, I can login with Tapatalk now lol
Just a update I got from Tapatalk support. Hey said there should be a new Tapatalk plug-in available. Below is the response I received this morning. “Hi Jeff, We released an update last week. Any forum owner updating to the latest version of IP board also needs to update the Tapatalk plugin. Once they update the plugin, login will work again. Chris Tapatalk Support”
Radio antenna wire grommet
Blue88Comanche replied to Blue88Comanche's topic in MJ Tech: Modification and Repairs
Thanks for all the input, when i decide what route I'm taking ill report back. -
While the MJ is torn apart one of the things i am looking to replace is the rubber grommet for the radio antenna cable. The existing grommet shrank and poped out.... thus confirming the leak when it rains. Where could i get a replacement grommet or a new antenna cable assembly with the rubber grommet?
Lots of progress the past couple days. removed the dash, air box, clutch master cylinder, brake booster. swapped the Manual harness for the Auto harness. Lower dash removed by Blue88Comanche, on Flickr Upper dash removed by Blue88Comanche, on Flickr Air Box by Blue88Comanche, on Flickr Passenger side foot well by Blue88Comanche, on Flickr Brake and Clutch petal assembly removed by Blue88Comanche, on Flickr engine bay by Blue88Comanche, on Flickr M/T Harness Full by Blue88Comanche, on Flickr -
I finally got around to picking up the “new” transmission from Jimmy. I still have a few things I need to get from him later but this is a start. Now I can begin my AX-15 to AW-4 swap I started removing the dash and petals today More to come soon Sent from my iPhone using Tapatalk -
Quick help, damaged E12 Torx removal
I still have my AX-15, it needs to be rebuilt but if you have an AW4 you would like to trade I’m interested. Sent from my iPhone using Tapatalk -
Didn’t see it till just now. Unfortunately the Jeep with the transmission I was going after was sent to the crusher ahead of schedule. And a bell housing swap wouldn’t work for me as I was going from an ax-15 to the aw4. Sent from my iPhone using Tapatalk -
Cre8tive beat me to it. But also if you have a facebook account, be sure to follow his page “nickintimefilms”. You can message him to set up a pre-order.. currently he sells out in the preorder stage, and does not usually have many for a public sale. Sent from my iPad using Tapatalk -
Ours does not allow sawzall but they do allow rotary cutters. Torches are banned for good reason. But if they are worried about fire wouldn’t the sawzall be the best bet? Idk their logic but we will be returning with a dremel Friday. I talked to the guy up front and he said they won’t be clearing the row the jeep is on till next week. So if I can’t get it Friday then I’m just not meant to have it. Sent from my iPhone using Tapatalk -
Price check & rebuild question
Both my and the junkyard AX-15s are bad. I was wondering if there was any worth spending $80 to get the external slave tranny even tho it wasn’t working. Side note, where can I find these warrantied transmissions for $200? Sent from my iPhone using Tapatalk -
While I was at the junkyard today I saw another AX-15. It’s an external slave 4wd. Now the only issue, with it in neutral (or any gear) the rear output shaft won’t turn. So what is the value of a non functioning external slave 4wd AX-15 (may have 250k miles) including the bell housing and other external slave parts? As i am replacing my current non functioning AX-15 same question but internal slave. I have never rebuilt a transmission, but have heard the AX-15 is easier than most. Seeing as my current tranny is dead and not risking anything, what more specialized tools would be needed before taking on this as a project? Sent from my iPhone using Tapatalk
Do you have a picture of what you are talking about, i don't quite follow. Now this being removed from the donor xj. I still have all the bolts holding my AX-15 to the engine. So shouldnt i be able to reuse my original bolts? Sent from my iPad using Tapatalk -
We got some bolt extractors that several people said works well but we still couldn’t get it off. Friday we are going to come back with a dremel and cutoff wheel and just cut off the head off. Sent from my iPhone using Tapatalk -
Transmission or clutch issue
Yay.... I killed an ax-15... well it was a Junkyard find... thanks for the help everyone! I will be looking for a reman unit I suppose. Possibly converting to the AW-4. I’m not sure yet. Sent from my iPhone using Tapatalk -
Ax-15 It feels like normal when shifting, i can feel it go into gear like normal... But only 4th gear works. Sent from my iPad using Tapatalk -
So got up this morning at 4am, its 36 degrees outside and i had to bypass my heater core the yesterday cause it was leaking bad. Left the house bundled up and cruising on the interstate to meet up with a jeep and there was some clanking noises (not many) then the transmission stopped receiving power from the engine (engine act like tranny was not in gear). The clutch also felt like it lost pressure. Coasted to a stop on the side of the interstate and called AAA. 2 hours later I'm home with the jeep. I let it sit for a while and now the clutch has pressure but when i put it into gears 1,2,3,5 and Reverse, Nothing happens. Only 4th gear seems to work. At first i thought maybe the clutch blew out, but now I'm wondering if the tranny died. Thoughts? This is in reference to my Blue Comanche, see sig for details. Sent from my iPad using Tapatalk
Got some work done on the comanche yesterday while precooking thanksgiving turkeys for my family. Replaced the shocks and organized my toolbox. Will post pictures later
