pizzaman09
Everything posted by pizzaman09
Starter issues after AX15 swap
pizzaman09 replied to jazzyjeeper's topic in MJ Tech: Modification and Repairs
What are the symptoms? Does it make noise when you hit the key? Do you hear the motor free spinning but it isn't engaging the flywheel? -
Awesome! I had run into the same issue when I pulled mine to do the external slave conversion.
Are you confident you have the bolts out near the top? There are a couple sheet metal screws near the top that can allow you to pull the transmission 1/2 inch out but then no further.
Jeep variable assist steering pump.
pizzaman09 replied to 512tr's topic in MJ Tech: Modification and Repairs
No but it looks intriguing. Judging by the connector size it might be just a two pin connection. -
Thanks! The trouble I've found is just knowing what a trail has, I had purchased a trail book for Moab and used that to research the trails I went on with some success and some not. Even knowing what trails are maintained was a complete unknown, last time I was out there we ended up an a very scary place because 7 mile rim had been blocked off and we didn't know it until we were on a ledge looking a 1000ft down. Generally staying to the popular trails helps. A more local person like you is so awesome to be able to talk to to get the scoop on trails that are passable for stock vehicles. I'm looking forward to scouting out sand hollow area this year and seeing what we think will be stock Comanche capable.
- 103 replies
- 98 conversion
- bushwacker
(and 3 more)
Tagged with:
1990 Comanche Eliminator
pizzaman09 replied to pizzaman09's topic in Member Projects: Your Comanches
1988 Comanche BMW M57 Swap, Rear Coils
pizzaman09 replied to colthrax's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I am so excited to see build is going well! You are going to have some serious torque. Out of curiosity what displacement is this engine? Is it a cast iron block? -
Like many of us, my high mileage Comanche has a very saggy driver door. This repair method uses JB-weld to fill the hinge holes that are worn out and redrill them to the original 1/4" diameter instead of drilling out larger and using a larger bolt. My hinges had the center section hole worn out, initially I figured the role pins were worn but they weren't. That said the roll pins were completely rusted in place. First step was to remove the door, make sure to remove the door card, speaker and wires. Then door detent device. The 3 bolts on each hinge are T40 torx, and are extremely tight since they are deformed thread and loctited in place. I chose to spray the inside of the threads with PB blaster prior to removal. Due to limited space, a 1/4" drive T40 bit and a 1/4" ratcheting box end wrench were needed. With the door removed my door had two spacers between the door and the hinge. The first a body shim, the second a thick steel formed plate that cups around the hinge. As stated my roll pins were rusted in place, no reasonable amount of hammering with a punch would move them. To get around this, I got a Dremel with a cutoff wheel in between joints on each end of the hinge. I originally used the standard Dremel cutoff fiber reinforced wheels with the little screw on mandrel. Apparently those are fragile when the disc gets pinched and I broke two screws. A friend recommended the much more robust quick change cutoff arrangement made by Dremel. This did take some patience, do the bottom gap first then left the hinge and do the top gap. My goal was to abraded away as little of the load bearing surface of the hinge as possible. The stub pieces of roll pin on the C part of the hinge, I had to push out with an arbor press. Next I used brake clean and Q-tips to make sure the hinge pin holes were super clean. Once cleaned, I mixed up some 6 minute JB Weld and used a tooth pick to spread it around the bore and on the top and bottom faces where the Dremel had abraded the hinge. After the glue is cured, use a file on the JB Weld to make a flat surface for the hinge to sit on, I did top and bottom. The goal was to make the hinge fit snuggly so there was no up it down sliding play. After filling, I drilled out the holes first with a small drill bit, 3/16" or so, be careful the glue really grabs and pulls the bit. Then very carefully one drill size right below 1/"4 and a final pass at 1/4". I decided to use 1/4" bolts instead of the replacement roll pins as they were far easier to install. Those bolts were slightly tight in the glue, even though they measured 0.247" in diameter. I finished the hole with an oiled 1/4" ream spun in carefully by finger. Assembled with a copious amount of grease and painted. The bolts were roughly a 3" bolt with just the end inch threaded and the rest solid shank. Door alignment was a fun and challenging process, my tips are have a friend to help move the door up and down, and also note that the door striker hex is 18mm. Even though the hinges were now tight, the door was still slightly saggy, so I removed the body shim from the upper hinge, this allowed for excellent alignment.
Will do! -
Fixed up the driver's door hinges to get the sagging door righted. It was a challenge. The roll pins were predictably stuck in the hinges. A Dremel with a cut off disc at each end of the pin got it apart. After disassembly I found that the roll pins were not worn out but actually the hinge holes were on the part welded to the body. To fix that I filled the holes with JB weld and the areas that were cut on the top and bottom by the Dremel. Filled the top and bottom of the hinge center section to height. And drill out the holes, carefully stepping up and finally using a ream by hand to finish them. Everything got a coat of black paint too, none of this I took photos of. Replaced the broken door holder opener thing. With a new bumper style one The threaded studs on the new one were a bit closer together but it just fit putting it in the door. After about an hour of alignment exercises I did get it aligned well enough. It still takes a good slam to overcome the seal. So far the results are awesome, less wind noise and I expect less water seeping in making the floor wet. -
best engine swap
pizzaman09 replied to comancheee87jax.fl's topic in MJ Tech: Modification and Repairs
I've looked at this a couple times. If the right MJ came along, I'd try and do a BMW S52 or S54 swap, which are the engines from the 96-99 M3 or 01-06 M3 respectively. The later being an 8000+ rpm screamer with great torque across the rev range. The adapter plate to an AX-15 is available in Europe. Those BMW engines are pretty easy to swap due to the electronics packages being well self contained, maybe a speed sensor would be the challenging part. The Supra engine is also tempting as if I remember correctly the transmission used in those cars are closely related to the AX-15. In general the challenging part to most exotic engine swaps are the ECU and controls. Swapping the ECU is easiest if you can get all inputs satisfied. Doing a custom stand alone ECU is a science project all it's own. -
I'm curious on your opinion on taking a stock 4x4 short bed Comanche to Moab or St. George. I've been to Moab twice and rented two door JKs both times that were mega built, however I have an itch to make the 3000 mile drive in my MJ to run it somewhere not muddy. I feel like it could easily handle the first half of Hells Revenge and probably a lot of Fins and Things but am worried about dragging the rear bumper. I'm confident it wouldn't get far in Poison Spider Mesa. I plan to scout out the St. George area this year when I head out and rent some side by sides for a day.
- 103 replies
- 98 conversion
- bushwacker
(and 3 more)
Tagged with:
I take the little bites approach and sometimes just force myself to do things. Like I've been putting off changing my door pins until today. I dug in today, took the door off, couldn't get the rusty pins out, now need to buy a new Dremel disc mandel as I broke it trying to cut the pin out. I started the project today as I had nothing going on this evening, and knew it would rain in the coming days so I was unlikely to drive the truck. So for now the door sits in the garage until I get to the hardware store tomorrow to buy a new Dremel mandrel. This is how many projects go, once it's taken apart, I make it a point to get it back together as soon as I can so it's useable again. Also I find that daily driving it gives me the motivation to fix stuff as the not perfect stuff bugs me. The trick is to have another vehicle one can drive if you screw up enough to need to let it sit for a day or three while you get more parts or tools.
Wiring The Interior Lights
pizzaman09 replied to Biotex's topic in MJ Tech: Modification and Repairs
If you smoked it, you probably blew the diode. Change the diode with another and all will work correctly. If you don't then when you turn on that light individually it will back feed and run all of the interior lights. It's not a big deal but just something to note. -
New My old piece was toast. The new one from crown appears to be nice. I did find that the bolts were a bit too close together but it just fit in the holes so it technically bolted right up. Once I get my door pins replaced I'll let you know how it works.
Harmonic balancer replacement
pizzaman09 replied to Car Enthusiast's topic in MJ Tech: Modification and Repairs
I rented this tool from Advance Auto, it worked amazingly for removing and installing the harmonic balancer.... After I removed the thick washer. https://shop.advanceautoparts.com/p/powerbuilt-tools-kit-45-harmonic-puller-pulley-installer-kit-648616/9150003-p?product_channel=local&store=5323&adtype=pla_with_promotion&product_channel=local&store_code=5323&&&&&gad_source=1&gclid=Cj0KCQjwlZixBhCoARIsAIC745D2t9WM-jfkHw63cgsLpmyUM37Q8C9D_cHC_seOqzkAN9P5oF8DkHIaAlorEALw_wcB&gclsrc=aw.ds -
No need to pull the radiator, at least the harmonic balancer tool I rented managed to fit. I do recommend a ratcheting box end wrench to drive the tool due to limited space. When you get the crank bolt out, don't forget to take off the 1/4" thick washer that's under the crank bolt head. Mine was so stuck on from grime that it stayed in place causing me to spend considerable time trying to pull against that washer. -
fuel mileage has dropped
pizzaman09 replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
Are you calculating MPG based on the odometer or off of say a GPS distance? Since you have larger tires the odometer distance will be less unless you changed the speedometer gears. That would account for about 1 mpg. 13.8mpg does sound low to me, I'd expect 18-19mpg. Spark plugs and O2 are likely decent places to start looking. Also checking to see if your manifold bolts are tight. Do the basics of a tune up. -
April 2024 - Eureka's Pioneer Metric Ton
pizzaman09 replied to 89 MJ's topic in Comanche of the Month (MJOTM)
I really like what you did adding the graphics. This is wonderful useful truck with the long bed and metric ton package. -
Teraflex D44 Disc Conversion Questions
pizzaman09 replied to Bonkers's topic in MJ Tech: Modification and Repairs
That's what I was going to say, the D44 has nice large drums that work well. -
Added a hidden trailer connector block under/behind the bumper. The flat 4 pin that was wired into the truck was so long that if it fell from the place it was nestled in the rear bumper, it would drag on the ground. I may eventually add trailer brakes, currently running lights, turn signals and reverse lights are wired in. -
I'm a big fan of vintage Jags, was cross shopping early 00s Jag XJs with the 8th Gen Honda Civic Si when I shopping for a replacement for my Oldsmobile. I can't say I know much about those, appears to be fuel injected, if it was a bit older with a set of SU carbs I could definitely help. In the end it's still an engine, spark then fuel then air. If it has those three it should run. Given the vintage I would expect it to have an electronic pickup distributor. Those cars were known for having a bunch of relays up near or above the radiator, not particularly well shielded from the elements. Good luck! It's a cool car.
