4
Everything posted by JMO413
I'm New! Electrical Gremlin HELP
JMO413 replied to SlimShaney's topic in MJ Tech: Modification and Repairs
Good work! -
http://www.bteventures.com//mj1988electricalmanual.pdf This is a link to the 88 electrical manual. I have it saved to my phone and printed out. With these trucks it is a life saver. -
I had similar issues when I first got my truck. Both front turn signal sockets were bad. The ground tab was rusted off of both. One of the PO's had also attached a wire to the side marker that was scotch locked in and shorted to ground. After replacing the front sockets and removing all the added wiring it was better. I redid the taillight ground and it all worked correctly. So IMO redo the ground and check the wiring for additions or shorts. -
Thank you for the update. Good to hear he's doing better each day.
BA 10/5 really a bad transmission?
JMO413 replied to 88mancheman's topic in MJ Tech: Modification and Repairs
Mine has a BA10 in it. I can tell you changing the oil with Redline MT90 makes it shift smoother. It's is severely better when it's 10 degrees out. I'm will be looking for an AX-15 while I drive it with the BA10! -
Finally got a little time to work on the old girl. Replaced the water pump and thermostat. While I was there I replaced all the heater hoses. Got a OEM pump and thermostat. The bearing was out of the water pump and the thermostat housing was leaking. Someone at one time was a fan of that cheap black silicone. Was very happy to find out the water pump and thermostat were still available from Mopar. Water pump party number is 68382488AA. Thermostat part number is 83501426AD. The Mopar thermostat has the little bleed hole built in. This definitely helped with the coolant system bleeding. Not sure why they needed the mount bolt for the power steering pump bracketbehind the pump. I think the other 3 might be enough. I did put it back in though. Gates hoses are dirt cheap on Rock Auto. $40 for four of the heater hoses and both radiator hoses. Had to get there one to the reservoir from crown. Thankfully I found it on eBay for $8. One piece of 5/8 hose to finish it out. All new rubber should be good for another 30 years. While I had the garage warmed up I also tighten the manifold bolts. Was a little surprised all of them were a little loose. All in all a good day!
‘88 “Eliminator” on Ebay
JMO413 replied to Vineyard86manch's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
This will show you the basics. -
Merry Christmas to everyone. A giant thanks to everyone here. This club is amazing.
Just wondering. Did you ever buy this truck?
It's a problem that the world will always have. What one person thinks is nice another sees as not nice enough.
The VIN decodes as a Pioneer. -
A College Students V8 Comanche
JMO413 replied to 88mjsally's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Looks good. Should be fun to drive!! -
Had a couple days off and took full advantage. Changed the leaking clutch master cylinder. Would like to thank whoever's question on how to bleed that fine unit. My bleeder is just a huge chunk of rust. I read somewhere on here to just pump it fifty times or so and let it sit. Wouldn't you know that worked like a charm. Best clutch pedal feel she has ever had! I took the seat out so I could reach everything easier. While I had it out I replaced the parking brake cable. I was thrilled the back two cables are good and I have a working parking brake. Very nice to have with a manual no more wheel chocks. While I was under there I noticed the rubber fuel lines looked wet. So replaced both of them with new hose and the correct high pressure hose clamps. I also decided while I was under the truck to add the extra fuel pump ground. I believe I have finally got all the grounds refreshed and added. Changed the spark plugs and oil. I went with a Centric master cylinder. I will update how it holds up. Not sure who I need to thank. Shortly after joining the club I read about putting a sponge over the fuse block so when the master cylinder leaked it could catch it. Well that works! The proof is in the sponge. Almost looks like it's supposed to be there.
I replaced the IAC today. She has had a wondering idle almost the whole time I have owned it. The new IAC helped a little. I ordered it from Rock Auto and was thrilled that it turned out to be NGK when I got it. It was only $14. Part #2H1141.Thought about taking a picture after I had started to remove the old one. The new one installed. It did help the idle some. Still wanders a little.
Replaced the windshield with the newer style and rubber gasket. Old windshield with the metal trim. I was amazed with the amount of dirt under the metal trim. No windshield. Very happy no rust to be found in the windshield frame!! New windshield with the rubber gasket.
DrComanches Project "Frankenstein"
JMO413 replied to drcomanche's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Amazing build love your commitment!- 146 replies
No they are long gone.
All factory. It's a loaded limited.
Make sure you have the Jeep running when your programming the home link. Just speaking from experience. My WK owner's manual says nothing about it but is only way it will program.
