JMO413
    4
Everything posted by JMO413
  1. Well we definitely got some snow in Iowa today. They say between 8" and 12". The old girl plowed right through and sure is fun in 2wd. Glad I got most of the issues worked out before today!
  2. You are not the only one happy to not see angry eyes!
  3. Had to find a picture of when I bought it. And it was in correct then. I must have put it in upside down when I added the headlight harness. I can't believe they made it so it could be installed upsidedown.
  4. I can say the bored throttle body seemed to have the most noticable gain. I know mine is a Renix but just thinking and typing. It might be in part to already having updated the injectors and later ECM.
  5. Pulled the grill gaurd of today so I could put my grill in right side up. I also pulled the wiper transmission out and rebuilt it today. Best $4 I have spent in along time!!! Thinking I should get newer style arms my springs are not very tight anymore.
  6. Just installed my bored throttle body from meanlemons and wow. I am overly happy and impressed with this upgrade. There is definitely better throttle response. My butt dyno is happy! Taping the MAP sensor hole. Neal does great work! I believe this is one of the best upgrades you can do!
  7. Did anyone ever ask what you plan on doing with it? Just wondering? Mine is just as rusty and I absolutely love it. I do understand somewhat where everyone is coming from.
  8. It's all in the eye of the beer holder! Rust is just something we deal with in the rust belt. I know my truck will never be rust free. It's sure fun to drive in the fresh snow!
  9. I sent you a PM
  10. Any chance you would want to detour though Iowa with a hitch?
  11. Got my throttle body today and it looks nice!! Just gotta get it put on.
  12. I just meant I took the insert out so I could spin the pulley. That's when I figured out it was just spinning on the insert.
  13. Hopefully these are useful to someone. I thought they were kinda cool to look through.
  14. These are the VIN decode pages from the paper parts catalog.
  15. I had the same issue. I replaced the headlight switch and that didn't help.The wire from the headlight switch is orange with a black tracer. My turn signal indicators worked along with the bright indicator. It took me forever but I found a break in the orange wire finally. I added the extra ground also and that made them noticeably brighter.
  16. Just thought I should alaborate on the name. I had the truck a month or two and we ordered pizza from Domino's. The delivery drivers name was Ratricha. Do from that day on my wife called the Comanche Ratricha! It's fitting she's kind of a ratty truck!
  17. That's my 5 month journey with Ratricha. I will keep this going from here on out. Thanks to everyone here for all the help!!! Special thanks to Ohm for the wiring help!! And a shout out to Cruiser for being awesome and having an amazing website!!
  18. Frame repaired in process photo. You can see the broken eyelet from the leaf spring on the ground. NOS oxygen sensor I got from New York. New Doorman vacuum harnesses.
  19. Pictures of when I bought her.
  20. I also replaced the blower motor resistor. That lasted two weeks. Then I changed the resistor and the blower motor. The blower motor sounded good in the truck with it out I'm surprised it worked.
  21. I blew the coolant out with my air pressure. Filled the core with vinegar and let it set for 20 minutes. Poored the rest of the gallon through it. The gallon was only $2. Can't buy any flush chemical for that! Flushed and back flushed with water. Now you have to turn the heat down it's so warm.
  22. I just got done flushing the heater core. Thanks to mjeff87 for the idea of using vinegar to flush the heater core. I did get something a little too wet while flushing the heater core. Had to let it dry out for a day before she would start. Now I have good heat and she runs a little cooler. I also replaced the ICM beacuse the sealed bottom was falling apart. My meanlemons bored throttle body should be here tomorrow yay!
  23. I also installed the lights from the roll bar under the bed for back up lights. I also painted the rear diff cover when I changed the fluid. I also change the transmission fluid and transfer case fluid. Changed the rear pinion seal and rear transfer case out put seal.
  24. I'm not sure. I got it close on install and went from there. The track bar from Rusty's is pretty nice.
  25. Does the spring looked better in this picture?
