Everything posted by TexanEliminator
how many miles on your truck's factory engine?
TexanEliminator replied to Pete M's topic in MJ Tech: Modification and Repairs
Lund visor repops
TexanEliminator replied to frankspeed420's topic in Vendors- members making products for MJs
120 mph speedometer
TexanEliminator replied to fiatslug87's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I’ve got one! I’ve had it to 100 before with 3.07 and 31” tires. Wasn’t out of breath yet but close. It might be able to do 120 now that I’ve got 3.55. -
Farm truck doing farm things. 75 gallon fuel tank is no longer in there. I have a scale ticket of it weighing right at 5k. It honestly handled the weight great!
1991 Eliminator ROW Rig
TexanEliminator replied to TexanEliminator's topic in Member Projects: Your Comanches
Well the old girl made it to 350k and earned its first trip to a mechanic in 7 years. The d44 I swapped in has a howl and seal leak so I’m having it rebuilt. This has been the most reliable vehicle I’ve ever owned. -
Been awhile since I’ve been on here with Facebook killing the classic forum. This old girl is still kicking with 340k on the clock! I no longer pipeline and now shes the fishing/ranch get around truck. -
I’ll get pictures today. Sorry for the delay, I don’t get on here very much.
Comanche rear Mudflap template
TexanEliminator replied to JoeM88's topic in MJ Tech: Modification and Repairs
I have a NOS front and rear I’ll take $400 for if you’re interested -
I have one in Muskogee, OK. 3.07 gears $500
Mine earns its keep to the tune of .58/mile for work, but this is the only actual “work” it’s ever done pulling the camper to the annual camping/fishing trip.
Double din install
TexanEliminator replied to ghetdjc320's topic in MJ Tech: DIY Projects and Write-Ups
Following. This is looking great! I’ve been scratching my head how to fit a double din in mine. -
I bought a set of the regular 4/1 springs from them and they rode fine. Bushings were offset and caused rattling. Fixed that with an air hammer. Only ran them 2k miles then replaced with Rusty’s 4” springs. I wish there was an option for taller springs and still stay SUA. I carry approximately 800# of tools in the bed at all times and even with overloads maxed out, I’m sitting dead level with 5” lift up front.
Check your tail light fuse. While installing my cruise control stalk with the battery connected, I somehow blew the fuse. The next morning I had no dash lights or tail lights. I guess it is some kind of a fail safe to let you know that your tail lights are not working.
90 Eliminator revival
TexanEliminator replied to Renoenvy08's topic in Member Projects: Your Comanches
Amazing yours made it to 500K! Mine is currently going strong at 310K. I'm hoping to make it to 500K before I have to think about an engine. At 60k/year it won't take me long. Can I ask what your started doing? -
fender flare bracket studs
TexanEliminator replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
If you are lucky and the broke studs are on the front flares, Quadratec sells new mounting brackets. -
Full console Yetti Cup holders !!!!
TexanEliminator replied to Red Mistress's topic in MJ Tech: Modification and Repairs
I haven't measured the depth of the console where we all would like this insert to go, but if it would fit depth wise, all that would be needed is a piece of textured ABS with the proper size hole cut out to go over the cubby. Could be secured with ornamental stainless screws to make it look nice. -
That was me that was selling them. I sold them to him.
I have had the same exact idea! I’m in if someone can make it happen! -
1989 Comanche Rear Lift
TexanEliminator replied to 1989commanche's topic in MJ Tech: Modification and Repairs
I run them on mine and I like them. they ride good and haven't sagged too much over 60K miles from what I can tell. I run overload springs to compensate for the tools I carry in the bed. With JKS shackles, I am sitting right at 5" of lift. -
Factory cruise control info (91+)
TexanEliminator replied to Minuit's topic in MJ Tech: Modification and Repairs
Not a problem sir. Depending on when you get them ready to send will determine where I need them sent. Thankfully I'm about to leave Montana and head south back to Texas for the winter! -
Finally got around to installing everything the other day. The stalk install was a PITA like I thought it would be but I got it done! Everything under the hood installed perfect but I was disappointed when I tried the cruise and it didn’t work. Ordered a new servo from teamcherokee.com and installed it today. It works perfect! Thanks Minuit for your write up! -
Reproduction Comanche Emblems
TexanEliminator replied to carolinajeepman's topic in Vendors- members making products for MJs
Following for chrome over black -
Fuel pump and sending unit
TexanEliminator replied to CarterD's topic in MJ Tech: Modification and Repairs
I'm still satisfied with mx XJ sending unit in my tank without the pan. I have since installed the bosch fuel pump because the delpihi didn't make is 20K miles, but it reads accurate on the gauge. I have put 16.5 gallons in it before. The fact that the XJ sending unit is a bit shorter than the factory comanche one doesn't seem to make much of a difference. 16.5 gallons is close enough to empty for me. The only complaint I have, if any, is that, without the pan, the gauge seems to fluctuate when going around corners and up/down hills when there is less that 1/2 tank.
