8
Everything posted by 89 MJ
More updates! Bed mounts are added and the frame is painted. He had to add a 1 inch body lift to get all of the body lines to line up on the truck, but that's okay because he wants to run 35s and this will help with clearance. He and my dad also primed his OEM bed that he is going to sell. He did find that with minor trimming (it needed to be narrowed), his stock Jeep tailgate will work with the stepside bed.
Ummm, fix the wiring and use it as is? Maybe do a 4x4 swap. No sense in sticking a bunch of money into it if it works as is and isn't rusty. Then look for options you want to add down the road.
Funny, my truck is an original Florida truck that has made its way to Wisconsin.
Where are you located now? I’m just a couple miles north in Holmen.
A few more posts and the classifieds will open up to you. You either need 1 or 6 more posts, I don't remember right now.
A trailer brake controller is definitely on my list of things to add to my truck too. With the 4.0 and 4.10s, its got plenty of pulling power, but not as much stopping power as I would like.
He also fixed the frame rust and added a new rear crossmember because the stock one was all messed up because it had some terrible "custom" bumper brackets on it. The rear spring hanger mounts are for a 1990s Ford Ranger, IIRC. The stock spring hangar has the shackle pointed upwards and is cup shaped, so it traps dirt and moisture, leading to rust. These should fix that issue, and it allowed him to lift the rear up a little more. New crossmember. The pieces of tubing that go crossmember to crossmember and are parallel to the frame rails are to support the K5 Blazer tank.
Well, he found a decent deal on a mid 80s Ford stepside bed that is from down south that he decided to try to put on his truck. It probably wasn't the route I would've went on it, but it should look good once he puts his Jeep fender flares on it. He has to do some trimming to get it to sit right. Some CAD (cardboard aided design) to see what it will look like with the Jeep widetrack flares on it.
Yes, according to the FB post, preorders get 20% off. I posted what will end up being the real prices later.
I saw that after posting it
I know nothing about this, I just saw it on FB. Looks like tinted ones will be $320 and non tinted will be $300. Not too bad, IMO. https://www.oraclelights.com/products/groupbuy-oracle-lighting-jeep-comanche-mj-led-tail-lights?fbclid=IwAR1SGJiryZL0zuuk5lTFkcVdDkg7gQj9pLGds8UFsLVdg86NxnHGOdF5_Ck
Good looking truck. What are the plans with it? It may also be time to update that sig...
Master MJ/XJ Junkyard list
89 MJ replied to WranglerMangler's topic in MJ Tech: DIY Projects and Write-Ups
Similar to scguy's comment, 21 slot grilles and Wagoneer header panels are worth pulling. Probably any chrome front end pieces too. As are XJ Wagoneer taillights. -
There is also this thread going, but its more upgrades rather than parts to grab, but still helpful. -
Front skid plate too, I didn’t see that on the list. I might’ve missed it too. Factory 2.5 AC stuff is rare. The bellhousing off of a 2.5 Dakota can mate an AX-15 to a 4 cylinder. -
Soapy water is your friend. Use lots of it that way you can manipulate the graphics some.
Wet carpet - Leaky windshield?
89 MJ replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
@Pete M I think has has baby powder technique. Basically sorrels out a thin layer on the floor near where you think it’s leaking and follow the trail. -
Retaining 5 on 5 pattern with WJ brake swap
89 MJ replied to Billabob's topic in MJ Tech: Modification and Repairs
@SoCalJeepComanche I think has 5 on 5 on his truck. -
That is @ComancheKid45's truck.
