8
Everything posted by 89 MJ
Looking for a power steering pump cap like the one pictured. Apparently they are specific to 87-90 Jeeps with I6s. Dorman stopped making them, but the part number is 82585. The Chrysler number is 83505415. I've tried ordering a few off of eBay and the order ends up getting cancelled because it isn't actually in stock. That said, does anybody have one? I'm fine with new or used in good shape.
That sounds about right for the floors.
I hope you pulled up the vinyl flooring too to check out the condition of the floors. I don't think I've ever seen a truck with the vinyl floor that didn't need floor work. Looks like a pretty good truck though. Also, what makes you think that it was two wheel drive originally? I believe that 86s still had the NP207 and the cable actuator on the front axle could have just been to delete the factory CAD stuff.
Are my synchronizers toast?!
89 MJ replied to InTacosWeTrust's topic in MJ Tech: Modification and Repairs
I don’t think anyone thinks that your clutch itself is bad, there’s just most likely issues with the hydraulic system. -
It might even depend on the agent too. My parents had an appraisal that was then the agreed value through State Farm.
Power loss when warmed up, '86 2.5L
89 MJ replied to zithy's topic in MJ Tech: Modification and Repairs
I’m leaning towards fuel pump being on its way out. After restarting, it is giving the fuel pump a chance to prime the system again. -
If I were to do it, I’d use all of the advance adapters parts linked in this video: -
Oh wow, that’s close! I wouldn’t be comfortable with that either. Plus it just sounds like a reason to get stopped frequently.
Ugh, that is terrible. I’m hoping to see you rebuild it in the future.
I was going to ask about this. It looked a little wide. Should be super nice for keeping things shaded and dry.
Mine is the same way, except it’s notchier when it’s cold. It’s been this way since it was rebuilt 10-15k miles ago. Reverse grinds because it doesn’t have a synchro. The only time my reverse doesn’t grind is when I sit stopped for a second, then go for reverse. I haven’t tried your 4th to R trick though. -
Wow! That’s exceptionally bad.
I'm back in AZ, so the truck is parked again, but I wanted to give some thoughts on the rocker bases in the seats. The seats themselves are the same as any standard XJ or MJ bucket. I do sit 2-3" higher in the rocker base buckets than I did in the bench. I don't think that I sit too high though. My line of sight is mostly out of the upper half of the windows, which I prefer. I also swapped in my tilt column, but there is room between my legs and the steering wheel with the column straight.
If I remember correctly, the AX-15 is supposed to take full synthetic 10W-30. I think a lot of people use the Redline though. -
I am also leaning towards the clutch not fully disengaging. Like they said, check the fluid level and try bleeding the clutch. Depending on how many miles are on the transmission, it might be getting to where it needs synchros though. -
Grille parts have been dropped off at the chrome shop. The spreading of filler has begun on the cab. Fiberglass filler over anywhere that had welding done, then just a skim coat over everything else to get it perfect.
Looks like a super nice truck!
I’ve noticed this about my 89 too. I used to always let the fuel pump cycle. I didn’t wait once for some reason and it started much quicker. Doesn’t matter if it sits overnight, if it’s a hot restart, or if it sat in the sun for a few hours. Couldn’t tell you why though.
Not very often that you hear about a 2wd Laredo. Looks like a nice truck for the price.
That thing looks like it’ll be a blast!
The cab got primed about a month ago. It looks wavy in the pictures, but that’s mostly because the primer was still pretty wet when the pictures were taken. It really won’t need much bodywork at all. The doors are almost finished and ready for bodywork now too, but no pictures. I was sent back to Tucson with some grille parts to get chromed.
June 2025 - Squirrelly Dan the Adventure Truck
89 MJ posted a topic in Comanche of the Month (MJOTM)
June 2025 - Squirrelly Dan Owned by @coheed Build Thread- https://comancheclub.com/topic/63980-squirrelly-dan-coheeds-86-custom/ Year/Model - 86 custom' Drivetrain- 2.8, AX5, NP207 but will be swapping in a 3.4, 4l60e, and NP242 when I get back from my current road trip. 4.10 D35 and HP early non-cad D30 swapped in from my grandads MJ Cooling- all stock Electrical/Ignition- upgraded 2/0 battery cables, generic headlight harness, otherwise stock Suspension/Steering- 3.5" RE front springs, General spring metric ton leafs, Core4x4 control arms, Rock krawler trackbar, StinkyFab track bar bracket, Zone offroad lift shackle, Bilstein 5100s front and rear, Moog replacement ZJ steering, JKS disconnects Interior- honey tan interior with the highland check buckets from my grandads MJ, mid 80s S10 steering wheel, an RX-135 radio restored by Jeremy when he was still doing them out of the same truck, a cheap Rockford Fosgate Bluetooth adapter, and a new SMS headliner Brakes- YJ front rubber lines and Dakota rear line otherwise stock Lighting- sealed beam halogen Wagner headlight bulbs, Auxbeam fog lights, Oracle led taillights, S10 blazer cargo lights in place of the factory B-pillar lights Exterior- stock AB beige paint on most panels but the fenders and header panel are mismatched (the eventual plan is to paint it Forest Service green) , FEY rear bumper, krustyballer hitch, 98+ windshield and trim, slider window swapped in from a junkyard truck, early AMC style grill guard Wheel & Tires- 16x7 XJ Icon wheels and 235/85r16 Sumitomo encounters Misc- The obvious thing not listed above is the Ovrlnd pop top camper I just got installed on the truck. I've gone through multiple different camping setups and none of them were ever exactly what I wanted, so I had one built Best MJ story- My favorite experience in a Comanche has to be when I was a young kid my grandad and I had gone up to the mountains to check on some of his land and we had been going up a single-track road in the middle of nowhere. The truck started overheating so we just got out and sat on the tailgate and talked to each other for a few hours CC is Awesome! Why? Having a community that has been around so long and is so full of knowledge is invaluable. Also, as a person that has been in car forums since the early 00's this has consistently been the nicest, most helpful, and most welcome one I've ever been a part of. -
Squirrelly Dan: Coheed's 86 Custom
89 MJ replied to coheed's topic in Member Projects: Your Comanches
That looks like it was a great trip!
