8
Everything posted by 89 MJ
Taddraughn's 1989 Comanche Progress Thread
89 MJ replied to taddraughn's topic in Member Projects: Your Comanches
I don’t think they were labeled from the factory, but it’s been a while since I’ve had the pan off of a 4.0. I’d be doing a rebuild too if I were you. -
Rough country steering stabilizer.
89 MJ replied to 90comanchegirl's topic in MJ Tech: Modification and Repairs
Welcome to the forum! Is this truck an off road toy or will it spend time on the road? I would just run a Monroe or KYB steering stabilizer. That said, you’ve already got it. If you can’t return it, you might as well run it. Is the N3 stuff their higher end parts or is that regular stuff? If it’s a higher quality part, it might be worth a shot. -
What you took a picture of would be considered the frame side because it mounts to the frame bracket. The axle side would be the mount on the front axle. In theory, you shouldn't need to jack it up before removing the bolt. The goal of the track bar is to keep the axle from moving side to side, so at ride height, it should be in a neutral position. That said, its an old truck, things might not be perfectly how they left the factory.
What ratrapp said. That's the joint end. What you're seeing there is the dust cover. You'll need to remove the bolt and move the track bar at the axle side to see if the axle side of the track bar mount is worn out.
Sorry to hear about your father. Sounds like you have a lot of good memories with him and the Comanche. I’m looking forward to the updates on this truck.
87 Comanche Rock Crawler Project Hell
89 MJ replied to AreWeThereYet's topic in Member Projects: Your Comanches
Seeing that pic of the rear suspension has me thinking there probably was a bad axle wrap problem. Those spring perches are awfully tall, but good for a little bit more lift. -
Fuel Pump Ballast Resistor Upgrade
89 MJ replied to HOrnbrod's topic in MJ Tech: DIY Projects and Write-Ups
You can also bypass the ballast resistor with no negative effects. Just hook the two wires attached to the ballast resistor together. -
When you replaced your thermostat last, did the coolant passages look pretty corroded? Corrosion will make it harder for it to cool, your water pump might not flow enough, your lower rad hose might be getting sucked flat, or your rad might not be good enough, even though it’s new, you also might not be getting enough airflow and need a fan clutch. By design, you should need the electric fan unless the AC is on. Clearly that’s not what’s going on, but that’s the way it’s supposed to be. What is the temperature drop across the radiator?
Can you post a picture of the ones you are thinking it might be?
I don't think you are. For how capable this truck will be, you're into it dirt cheap.
Have you verified that the temp gauge in the dash is working correctly? I want to say that the electric fan is supposed to come on at 218, but I do not remember for certain. If it isn't kicking in, I would suspect either the relay is bad or the switch is bad. When you replaced the thermostat, how did the coolant look? If you didn't do one, it is probably worthwhile to flush the system out really good. Do you still have the closed loop cooling system or do you have the open loop system? Is the Jeep mostly stock or does it have mechanical modifications? With my answer to your question and the questions that I asked, I am assuming your truck is a Renix truck. You might want to add details about engine, trans, transfer case, and any mods to your signature.
That looks like a very nice one. Perfect for the Mrs.
This is going to be a very capable truck
No spark after replacing the CPS
89 MJ replied to Kickin’Chicken's topic in MJ Tech: Modification and Repairs
So it didn't start before replacing the CPS and it still won't start after replacing the CPS? Have you pulled a spark plug to verify that there is in fact no spark? -
Good to know
What is the benefit of the GM IAT? Just availability?
Hold off on ordering the track bar until you check out the axle side mount for the track bar. That hole becomes oval shaped pretty easily, so I’d check that first. I don’t have any suggestions on the sway bar other than measuring it.
Usually that is caused by one of two things. The track bar being bad or the mounts being ovaled or not having enough caster.
Pinging under load need help
89 MJ replied to ja_racing's topic in MJ Tech: Modification and Repairs
Sounds like your knock sensor might be failing. This is exactly what it’s supposed to prevent. -
@krustyballer16 makes them. Check out his posts in the Vendors section.
Some more progress has been made. The door jambs now have all of their bodywork done and the cab got another coat of epoxy primer. The underside of the cab was also bedlined with Raptor liner. There is a huge storage compartment under the floor that gets accessed in front of the rear seat.
Exactly. The lack of overdrive definitely hurts the fuel economy with the 3.54 gears and the fact that I drive it like a regular car doesn't help either. It gets driven in stop and go traffic and spends time idling, which kills the mileage too. I bet if I just went on a nice cruise in it, it would be in the 20s.
The idle smoothed out a lot, but all of the stuff I pulled off had sat for years and probably wasn't tuned perfectly. I'm not sure how much the MPGs improved because I didn't drive it on the road with the old stuff, but I get around 16 with the new stuff.
Sounds like your brake light switch either went bad or is out of adjustment.
