8
Everything posted by 89 MJ
Wanting to put a new ax15 transmission in
89 MJ replied to InTacosWeTrust's topic in MJ Tech: Modification and Repairs
I can't say for sure whether you'd need the clutch or not. I would doubt that the either one comes with a clutch though. I wish I could be more help, but I went from a Peugeot to an external slave AX-15 and replaced all of the hydraulics and clutch at the same time, so I can't say what exactly actually NEEDS changing for your swap. I'll tag @Htchevyii as he has been through this before. I'll also link the video they did on their channel. -
Shouldn't need a transfer case. You'll definitely need the bellhousing, clutch fork, throw out bearing, slave cylinder, master cylinder, and clutch line for sure. Probably more things that I'm not thinking of right now. I'd look into something like this: https://www.advanceadapters.com/4993?gad_source=1&gad_campaignid=19546564555&gbraid=0AAAAAD7cfhBqvj96u4j13cQJFlOR4rlF5&gclid=Cj0KCQjw18bEBhCBARIsAKuAFEZJHYG3uV8D148Y5nY8DA_pYdeT7CtFY5_uvGZCFq8TgbckdMdDX7kaAqMPEALw_wcB -
I believe you can buy the external slave kit from one of the companies, maybe even both. That's probably the route I'd go for the same reason you mentioned. -
That would be me. Thanks for the link
I think some people on here have used the Novak one and the Advance Adapters one. I don't recall hearing anything bad about either one. Going to swap to external slave while you're at it? -
Everybody starts somewhere, you’ll learn more with time
Gladiator rear bumper brackets for sale?
89 MJ replied to Ricky8227's topic in MJ Tech: Modification and Repairs
I don’t think anyone makes them, you’ll have to make your own. This thread may help you: -
Could it be something wrong with the ECU?
You are correct, you will need a puller. You can typically rent them from parts stores if you don't have one.
You would probably have to pull the steering wheel and then the turn signal switch to be able to inspect everything. I have had this same thing if some oil gets spilled on the exhaust manifold. The smoke can travel up the column and out the turn signal hole.
That's a good point. It would probably also let you prove the real value of the truck, not whatever number the insurance company thinks its worth.
I don’t know how exactly all of the insurance stuff works in CA, but you might be able to go through your insurance and then your insurance will go after the other insurance company for payment. My parents have had to do this twice in WI, once with a person who failed to provide accurate insurance info to the police several times and another time when they got hit by an uninsured driver. Neither case resulted in their insurance rates going up. Being that their insurance company is dragging this out, it might be worthwhile to call your agent and see what you can do.
Fight for more then. Could you take it to a body shop for an estimate and then would they write you a check for that?
It wouldn’t cost that for you to fix it yourself, so if you’re good with it, take it.
Montana Manche Restoration
89 MJ replied to Montana Offroad's topic in Member Projects: Your Comanches
Those look perfect on there- 57 replies
- comanche
- comanche restoration
- (and 14 more)
87 Comanche Rock Crawler Project Hell
89 MJ replied to AreWeThereYet's topic in Member Projects: Your Comanches
It would’ve had to be from another XJ or MJ. The YJ didn’t get the 4.0 until 1991. -
The top picture is a stock housing from a 258 powered Jeep. The second pic is a stock one for a 96 XJ. I bet that XJ was pretty fun!
In my defense, there were some SJ ones before that! Lol
I think I would trim the rear most part of the 97 bumper end caps off like you were thinking.
engine accessories left on
89 MJ replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
Save yourself the mess and leave the PS pump in the engine bay hooked up to the box. To be honest, I would pull all of the accessories off. In my opinion, it is much easier, especially if you are doing it by yourself. -
Rough country steering stabilizer.
89 MJ replied to 90comanchegirl's topic in MJ Tech: Modification and Repairs
Definitely seems like you’re on the right track with Moog stuff. I would do a hodgepodge of suspension stuff. Probably Core4x4 control arms if you need better ones than stock. Either Old Man Emu or Rubicon Express springs because they seem reasonably priced and I’ve heard good things about them. For shocks, I’d do either the higher end Monroes or KYBs if I were on more of a budget and Fox or Bilsteins if money wasn’t as much of a concern. These are just the brands I would choose though. Really, just about anything should be fine. I’ve just never heard anything good about rough country, especially their shocks. -
New to the comanches world!
89 MJ replied to 90comanchegirl's topic in Member Projects: Your Comanches
Welcome! Sorry to hear about your father. You’ve come to the right place for help. I’ll say what I’m sure most of us are thinking, let’s see some pictures of the truck. Please drop your VIN in the registry and you’ll get a build sheet in a few days.
