8
Everything posted by 89 MJ
86 parts rig - Dana 44 and what is this bumper?
89 MJ replied to 88towmanche's topic in MJ Tech: Modification and Repairs
Looks like it has a lot of parts worth saving. I believe @eaglescout526 is looking for a bellhousing for an 84-86 with a 2.5 and a manual. If I were you, I'd take the parts off of it that you want and replace it with whatever extra parts that you have, then try to make it run and move and sell it. You could probably come out ahead on it then. -
They do look to be in very nice shape, I don't know if they are $100 per wheel nice though.
I had a very similar issue until I added my AAL. I would look into adding one if I were you.
I bought a brand new starter solenoid for my snow blower tractor, installed it, cranked the engine over, all seemed good. I went to clear snow with it 2 days later and the brand new starter solenoid had failed.
I'm super jealous of the window sticker!
Little bump for MJOTM!
January 2021 @olddude's 89 Pioneer Build Thread- Year/Model - 1989 Pioneer, 222,794 miles Drivetrain- stock AW4 w/overdrive Cooling- stock, closed system added aluminum recovery tank w/pressure cap replacing plastic tank . Electrical/Ignition- stock, replaced ign. switch(the switch sometimes does not engage) Suspension/Steering- stock, Gabriel HD shocks Interior- stock, bucket seats, recovered 5 yrs ago Brakes- stock Lighting- stock, LED's in inst. panel(old guys need light!). Headlight harness upgrade. Exterior- stock, sterling metallic original color, repainted 5 yrs ago. Wheel & Tires- BFG KO2 30x9.5 on jeep 5 stoke wheels. Misc- pretty much plain stock Comanche pickup. Best MJ story- Really don't have a good MJ story. The truck is amazing, in 31 years it has failed me once, crank sensor. People are always commenting on it and asking if I would sell it. I am proud of it. It's been the best little truck I've ever owned. CC is Awesome! Why? Good folks that just love Comanches and enjoy sharing experiences and helping members maintain their Comanches. Congrats @olddude, you have a beautiful truck!
J10s had D44s in the front and rear before the hot the AMC 20. The switch was sometime between 80-82.
IIRC, the local parts store had them.
I love these things!
Comanche 86 dealersip trucker style hat
89 MJ replied to Pete M's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
That’s freaking awesome! -
Does your state have inspections? If yes, get everything legal first (ahem, turn signals). If no, sign the title in your name, then head on down to the DMV, if it’s open, and tell them you want to register it. They should be able to get plates for you on the spot. Also, you need to make sure that you get insurance on it. I’d do full coverage because the price difference probably isn’t super great.
I think @eaglescout526 and @Minuit would be the guys to help you.
I wouldn’t trim. I would do a lift. You should get by with just getting a front spring spacer.
89 crew cab comanche? $1,234,567
89 MJ replied to Jesse J's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
No, he loves trannys -
The Chevy COE buildthread has pics with an explanation. -
That is why, in order to build a crew cab Comanche, one should use an MJ afoot as the rear door as well and cut the top front section off of an CJ door. That would make everything line up correctly. -
Looks great!
Are you getting spark?
The only time my truck is inside is in the winter, when it needs work, and if it is going to storm bad. I think lots of the other trucks are outside even more than mine.
I would keep the 5 leaf pack if I were you. The added capacity is definitely worth it. The AAL amaze my truck drive and ride MUCH better because of the stiffer springs. Plus, with the softer springs, you won’t be able to tow/haul as much. If you can’t tow/haul, there isn’t much point of having a truck.
Part of your spring stiffness could be your shocks. They might be bent or just two stiff. Pete and I both have 5 pack leafs and I for sure am happy with the amount of flex I have. Try jacking it up with your shocks attached (towards the outside of the axle, maybe under the leaf sting plate), then do it without the shocks. If your shocks are bent, then it will not flex as much, which could contribute to a stiffer ride.
I see he is SOA rear. I’m not sure on the details on the front lift.
