Everything posted by boxyjeep
87 MJ WindShield washer Nozzel replacement
boxyjeep replied to Top C's topic in MJ Tech: Modification and Repairs
Junkyard. Likely the same as 97+ XJ. -
1986 Comanche Xls Resto
boxyjeep replied to 19comanche86's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Why convert to manual brakes? That doesn't make much sense? -
The be all end all radiator
boxyjeep replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
I'm running a Mishimoto all aluminum radiator. It's massive. Can't see anything doing better than that. -
1990 Rebirth ('97 Conversion)
boxyjeep replied to Rymanrph's topic in Member Projects: Your Comanches
I suppose that's a pretty good deal if it lasted 9 years. Any pics of the whole truck as it sits now? -
Wow, an update! This was one of the builds that inspired me to get started on my truck. Sad to see that it's starting to wear away like this. How much did you spend on the original paint job and where did you get it done? -
Holy Flock! That came out great. What does the texture feel like when you touch it?
Location of VIN numbers
boxyjeep replied to Phillip Gwin's topic in MJ Tech: Modification and Repairs
What I've seen on my '88: there is one on the dashboard, a steel tag right inside the hood on the drivers side fender/cowl, the last few digits are stamped in the front crossmember. There is likely something on the frame and bed somewhere in the rear, as well as a few other spots. How are you planning to do the swap? -
Comanche Dawn
boxyjeep replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Good job. Too many people take it off and don't consider the environmental ramifications doing so would have. -
do any renix era MJs have a low washer fluid sensor?
boxyjeep replied to Pete M's topic in MJ Tech: Modification and Repairs
Wouldn't be too hard to add. You can buy the correct Packard connector and install it in the appropriate slot of the passenger-side of the bulkhead connector. Then run the wire to the appropriate pin on the cluster harness. -
Comanche Dawn
Looking good! Surprised at how expensive the keyless ignition system is. -
found a company that rebuilds wire harnesses!
Yep, that's the plan. This was taken after I first started it and wanted to fully test everything first. I'd be super concerned leaving these wires exposed. There is a good chance that they would eventually rub through on something and short to ground... -
Upgraded to a Gauge Package W/ Column Shifter
boxyjeep replied to photoguy_43420's topic in MJ Tech: Modification and Repairs
Slide it down the collar. -
Honestly worth doing yourself if you can. I recently redid the harness in my Renix truck and have it super simplified with a Grand Cherokee relay/fuse box, no fusible links, and minimal wiring. -
Steering column support rods
boxyjeep replied to blanzawa's topic in MJ Tech: Modification and Repairs
The front one is a pain to install with the dash in place. They connect to the drivers side exterior wall with bolts that thread into threaded inserts. I believe they mostly come into play during an accident to keep the column in place. -
replacement splashguard material?
boxyjeep replied to TheJeepNut's topic in MJ Tech: Modification and Repairs
How much do you think this helps with keeping the engine bay clean? I've always just ripped these off (as they typically just get totally covered in leaky oil). -
Comanche Dawn
You trailered it and didn't take the opportunity to rip it around the neighborhood with open headers? :-) -
I'd check really closely to make sure your IAC is working properly and wiring is sound. Beyond that, it sounds like an issue with the TPS or the coil/cap/rotor/wires. Check all of that stuff out. I also ran into a lot of idle issues with my '88 that took a long time to figure out. I'm in year 2 and believe it's been solved with a new cylinder head, but this is clearly one of the most problematic issues to fix.
The indicator cable and clip can be clipped onto the steering column collar at any position. You simply adjust it until it reflects correctly. -
Throttle Body Return Spring Mod...
boxyjeep replied to Andy in Pa's topic in MJ Tech: Modification and Repairs
Did you try tightening the spring on the throttle body by taking it apart and winding it around a few more times? -
Ignition and Door Lock Cylinder
boxyjeep replied to comanchefest's topic in MJ Tech: Modification and Repairs
I went with this Remote Start/Keyless Entry module in my '88 with 97+ doors. Pretty easy to install and setup. https://www.amazon.com/gp/product/B00O2EGYDM/ For the lock cylinders, if they aren't broken I'd just use the same ones and possibly reinforce the slotted opening in the door with some thicker steel. I have a good ignition cylinder and key, which I'm planning to match in my door locks. I snagged a handful of them from Jeeps the last time I was at the junkyard and plan on scavenging enough pins to re-key them to match. -
What Color To Paint!?!?!?!
boxyjeep replied to boxyjeep's topic in MJ Tech: Modification and Repairs
Nice. My truck has come a long way since the picture I posted. It's now a hodgepodge of colors after updating to 97+ front clip/fenders/doors and an unfaded/straight hood. Will be going with Chrysler Flame Red likely like this with black bumpers and body-color flares. -
Yep, totally understand that (and I know "seat-of-the-pants" evaluations are BS to begin with). I'm planning to run a HO intake once I'm out of CA and don't have to deal with smog. I went through and rewired the whole Renix electrical system and can now fully appreciate it's simplicity ;-). With the HO head and intake/TB, I would expect some gains. But in all honesty, it's a 30+ year old truck that won't see much time on the road. If/when I need more power, I'll solve that with an LS swap or gears.
