Everything posted by boxyjeep
1988 SoCal Jeep Comanche Build
boxyjeep replied to boxyjeep's topic in Member Projects: Your Comanches
This is the set I used -- https://www.amazon.com/gp/product/B0002NYBH8/. I would suggest buying a replacement set of bolts too. Also, take a good long look at your cylinder head. I ended up pulling everything out a few years later and replacing the head. -
The truck finally arrived in NorCal (Fremont) and had a very bad misfire. I could barely drive it off the shipping truck. I had just started a new job, so it sat for a few months before I could work on it. Turns out the distributor rotor had broken apart. I replaced that and I started right up (but still had a rough idle). It was now time to tackle the next big leak--the RMS. It must have been the original oil pan and gasket, as they were fused together. I couldn't get the pan off without destroying it, so... time for a new pan. I also spent almost two days scraping and cleaning off the old gasket material from the block. I also took the opportunity to replace the oil pump with a new standard-volume Melling pump. Started right up with great oil pressure. At this point I also realized that the muffler I put on back in 2018 was garbage and starting to make weird noises. I decided to replace everything from header back with a new CA-legal cat, Flowmaster muffler, and piping. At this point it was driving okay (still stumbling a bit) and not leaking oil. I used it to commute from Fremont to Menlo Park for the rest of the year without issue, as I started to accumulate parts and plan the next stage of the build. I bought JCR bumpers and sliders during their Thanksgiving sale. Unfortunately, wasn't very happy with them--they took a very long time to be shipped and when I got them there were a ton of missed welds on the front bumper and sliders. JCR gave me a discount and sent out a replacement set. I still wasn't super happy with how the sliders would mount, so I ended up selling those and just hanging onto the bumpers. Primed and ready for paint. -
At this point, the interior was getting pretty cleaned up, but the truck still ran like crap. I had replaced the exhaust manifold and gasket, made sure the O2 sensor was good, and started looking for other potential causes. Fuel pressure was good. Distributor was clocked correctly. I verified the grounds and followed the tips to replace the C101 connector. Unfortunately, still a very rough idle and close to dying at stop signs. I also verified the TPS and other suggestions from Cruiser54 and others on this forum. I was able to take it out for some drives into the hills, but still wasn't comfortable enough to go anywhere far. I also ended up replacing the Rusty's Heavy-Duty steering with OEM replacement. I could finally drive on the highway with zero death wobble. However, at this point, it was around the middle of 2019, I had the truck for a year, and I took a new job in northern California and had to move. I loaded the truck up and got it shipped up there. -
Next leak to fix was the rear pinion seal. It was destroyed, so I took the opportunity to inspect the Dana 44 rear, install a Lubelocker gasket, and also replace the u-joint straps with yoke-style retainers. I ended up not being able to use the yoke straps, since the pinion yoke would need to be drilled and didn't have an opposing flat surface. I ended up changing this a few years later to the yoke style. The strap-style with 8mm bolts has always been a weak point that I'd like to avoid. Next up was getting the interior cleaned up. I had bought a new carpet and was planning to change the interior from blue to grey (to coordinate with the future exterior paint being either silver or red). Blue interior pretty much only goes well with blue exterior... Nasty old carpet: SoCal truck it's whole life. No rust :-) Insulation installed throughout: Carpet installed: I went with a 97+ center console. My end goal would be to refresh the front clip, dash, and doors. For now though, the console would have to do it. -
I bought new terminals online at Del City, used a pick to pull out the old ones, then soldered and heat-wrapped the new ones in place. I used these parts from Del City: 7388520 Single Terminal for 1 Way ATC/ATO Fuse Block 7389520 4-Way Terminal Strip for 4-Way ATC/ATO Fuse Block -
I finally had a chance to replace the exhaust header and extract a broken manifold bolt from the head. Somehow it went well with an extractor kit and I was able to get the new header installed. I also replaced a bunch of the vacuum lines and took Cruiser54's advice to tap my throttle body and replace the MAP sensor line. At this point, the truck is starting to look good, run slightly better, but still periodically have a rough idle and stumbling condition. I had done a bunch of other validation of plugs, wires, etc., but still didn't have a great idea of what to do. -
The truck came with a really rough set of Turbines and shot 225 tires, which I wasn't a huge fan of. I got some inspiration from one of the build threads here (Ryanmrph IIRC) and decided to get a set of TJ Ravine wheels. I liked how these looked and the fit was pretty good with the 30" BFG A/T's. I started working on other small issues in the interior (like seat belts that didn't work) and issues with the manual windows. I also wanted to level off the rear after adding the 2" front spacers. I achieved this with some longer rear shackles and new poly bushings. This was inside a bad seat belt retainer: Removing the OEM rubber bushings and sleeves was not fun. After installing these, I quickly found out that they were very rough. I may switch back to rubber in the future. -
I got some of the wiring stuff fixed and continued on towards fixing the leaks. The rear main seal would only leak after driving for a long period of time. However, for some reason it always smelled of burning oil. I found a leak from the PS pump (or so I thought) and ended up replacing that and then eventually the steering box and lines. While I was in there, I also replaced the terrible engine mounts with Brown Dog. Somehow the new engine mounts introduced a level of rigidity that ended up causing death wobble. So I decided to replace all the steering components and throw in 2" spacers and new shocks to level the truck out. I ended up buying the Rusty's heavy-duty steering kit, Rough Country track bar & bracket, and JKS disconnects. Despite spending a lot of money on this setup, and getting it properly aligned, I found that the Rusty's kit drove terribly. There was always a dead spot, it still had death wobble, and the tie rod would contact the track bar bolt on full turn. Unfortunately, eventually I swapped this back to an OEM system. -
So one Sunday, I got an Uber and met him about halfway. I took the truck for a quick test drive and realized that it was in a lot worse shape than he mentioned. It could barely idle, the engine ran like $#!&, the exhaust leak was really bad, and the rear main seal leaked excessively. When I pointed all these things out, he was quick to show me that the AC still worked. I was already $170 into this with the Uber ride and would need to figure out a return trip if I backed out, so I went over it a bit more and made an offer that he accepted. I drove it home the 2 hours and was very surprised that it kept up with highway traffic, didn't overheat, and didn't have death wobble, so that helped any sense of buyers remorse I may have had :-) I got it home and quickly started digging in. I found that the exhaust header was bad and had a few bolts missing or broken off in the head and that there were a ton of wiring gremlins. Most of the sensors on the drivers side of the engine had their wiring simply cut off (including knock sensor, O2 sensor, water temp), which I thought was contributing to the rough idle. Additionally, most of the terminals in the fuse block were corroded and none of the blinkers worked. I got the fuse block pulled out and re-did a bunch of the terminals. I also found a few bad bulb sockets that needed to be replaced (I didn't even know these could go bad). -
How it started in Aug 2018: How it currently sites April 2025: Backstory: It's been 3 years since I bought the truck so I figured it was time to start a build thread. These pics start from middle 2018 to now. Some background--I'd grown up with Cherokee's as a kid, but hadn't owned a Jeep since ~2005. In 2016 I was living in SoCal and got the urge to buy a truck--I kept my eye on Tacoma's but couldn't believe how much used ones were going for. I think I saw a Comanche build online and decided that I could get the best of both worlds: have the bed of a truck to haul stuff and the reminiscence of my first car (a 1990 Jeep Cherokee). I kept my eye on Craigslist and followed-up on a few listings, but nothing great fit my criteria. I wanted a short bed, 4.0L, auto, 4WD. Preferably 91+ for the HO engine and non-Renix systems. I was willing to consider a manual transmission or 2WD if the opportunity came up, but needed to stick with the 4.0L since engine swaps in CA are hell. After almost two years, a posting came up for a 1988 Pioneer with everything I wanted, plus D44 rear axle. The only negative was the engine not being HO and the paint being totally baked. But it was a desert truck, absolutely zero rust, and the guy who was selling it had bought it from a neighbor he knew that had it since new. He'd done some maintenance like a new fuel pump and radiator and promised it was in good condition other than an exhaust leak and some electrical issues. I specifically recall it "not leaking a drop of oil" when I spoke to him. His asking price was high ($4000) and he was about 2 hours away, but this was the best rust-free, straight body MJ that I had seen since I started looking out for one. My goal of this project is to build a streetable, but also capable offroad Comanche pickup with original straight body in "almost show" condition. I wanted to keep it under 6" lift and 33" tires. Ideally with HP D30 and D44 stock axles (re-geared) and 4.0L engine. I'll be driving it around town, on some trails/rides, and using it for any light hauling purposes around the house. This is not an offroad-only truck and will be babied for all intents and purposes. Listing photos:
Yeah, agreed. There is a lot of time that would go into this, even though the full set from T&M is about $350 and I already have a welder. I'm moving to a snow state soon and was planning on pulling the bed and painting everything with POR-15. This might be a good idea to take care of at the same time.
Sorry to revive an old thread, but thinking about getting a set of front and mid stiffeners for my '88. I've found that if I jack up and support the truck with jackstands in the middle of the frame, the doors are hard to open. This is a California truck with zero rust and no accidents. I think that once I've added larger tires and other weight, this would get even worse...
Let’s discuss taillights
boxyjeep replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Very interested to see what the reproduction lights look like and cost. -
87 MJ WindShield washer Nozzel replacement
boxyjeep replied to Top C's topic in MJ Tech: Modification and Repairs
Junkyard. Likely the same as 97+ XJ. -
1986 Comanche Xls Resto
boxyjeep replied to 19comanche86's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Why convert to manual brakes? That doesn't make much sense? -
The be all end all radiator
I'm running a Mishimoto all aluminum radiator. It's massive. Can't see anything doing better than that. -
1990 Rebirth ('97 Conversion)
boxyjeep replied to Rymanrph's topic in Member Projects: Your Comanches
I suppose that's a pretty good deal if it lasted 9 years. Any pics of the whole truck as it sits now? -
Wow, an update! This was one of the builds that inspired me to get started on my truck. Sad to see that it's starting to wear away like this. How much did you spend on the original paint job and where did you get it done? -
Holy Flock! That came out great. What does the texture feel like when you touch it?
Location of VIN numbers
boxyjeep replied to Phillip Gwin's topic in MJ Tech: Modification and Repairs
What I've seen on my '88: there is one on the dashboard, a steel tag right inside the hood on the drivers side fender/cowl, the last few digits are stamped in the front crossmember. There is likely something on the frame and bed somewhere in the rear, as well as a few other spots. How are you planning to do the swap? -
Comanche Dawn
boxyjeep replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Good job. Too many people take it off and don't consider the environmental ramifications doing so would have. -
do any renix era MJs have a low washer fluid sensor?
boxyjeep replied to Pete M's topic in MJ Tech: Modification and Repairs
Wouldn't be too hard to add. You can buy the correct Packard connector and install it in the appropriate slot of the passenger-side of the bulkhead connector. Then run the wire to the appropriate pin on the cluster harness. -
Comanche Dawn
Looking good! Surprised at how expensive the keyless ignition system is. -
found a company that rebuilds wire harnesses!
Yep, that's the plan. This was taken after I first started it and wanted to fully test everything first. I'd be super concerned leaving these wires exposed. There is a good chance that they would eventually rub through on something and short to ground...
