88mjsally
3
Everything posted by 88mjsally
Oh yea for sure! Hopefully I’ll score more wall hangers this weekend at a few junkyards
Yea that’s correct. Too good of a deal to pass up
Yea luckily he took an offer😂 I didn’t need it at all but I didn’t have a chrome one
I’ll have it out when I pull the dash to put the black one in so I’ll try to remember to make a diagram then for whoever needs it. I just kinda have the truck together enough now so I can move it around
I never made a diagram but I can pull it back out of the truck and make one. I just kinda started tracing the circuit board and hooked it all up
I used the Renix gauge in the ho cluster so I could use a Renix fuel sending unit and have the gauge read correctly. It’s not really necessary now because MTS makes new HO MJ sending units which they didn’t make at the time I did the swap
Started stripping the bedliner off the passengers door and put some primer on it. Still needs some finish work though. Talk about something that sucks to remove. Used a scraper and a heat gun which worked but it still wasn’t easy
Yea I know lol. Just let me know, I’d like it to go to a good home before it gets accidentally broken in my building
I still have the one out of this jeep. It’s in great shape from what I remember. Not sure if you’ll be over my way anytime soon though
Yea they are taller and skinner than regular xj/mj ones
I have quite a few but none have been tested
full cluster with column shift?
88mjsally replied to Pete M's topic in MJ Tech: Modification and Repairs
I have one but it’s a 3/4 cluster from a police xj. I haven’t had a factory full column shift cluster -
Not at this time, maybe in the future
Yea it would be…. Not sure what the demand would be though
Some really good finds this round -MJ mudflaps with brackets -tailgate bumpers both triangular ones and the small round ones -Some emblems -LH and RH MJ bed wheel wells
I dolly tow with my v8 comanche all the time and it tows pretty good. I will say that even around the mostly flat area having brakes on the dolly are a must to me. The truck can’t really panic stop without them. I bought a used dolly a couple years ago on eBay for $800 with brakes that hadn’t been used very much
HO Jeep Cherokee AW4 trans issues
88mjsally replied to 88mjsally's topic in MJ Tech: Modification and Repairs
Tested the solenoids and they all tested at 17 ohms. Tps tested good as well. Did make a discovery. Found atf in the coolant bottle and a milkshake in the radiator so I think the trans cooler and radiator are now one. Going to try to source a new trans now since I’m pretty sure this one is cooked -
Forgot to add that the guy I bought it from said he changed the solenoids, fluid and filter. Fluid looks good and it’s full. I haven’t personally dropped the pan yet
