88mjsally
    3
Everything posted by 88mjsally
  1. Bottom picture is mine….. I don’t think I ever posted or took many pictures of it though
  2. Crispy got a bath today and a reman steering box yesterday. Did a tape measure alignment and adjusted the rear brakes so almost ready to go to a car show in about a week and a half
  3. Got the interior looking better with some xj buckets and a console to replace the well worn bench
  4. Finally made it outside and around the block. Just needs a little more tinkering
  5. Got some marker lights installed on the fenders. I don’t like drilling holes in impossible to find parts but I wanted them for safety and they make it look like a true dually
  6. Appreciate it!
  7. As long as you see a comanche dually then yes, yes you are
  8. I got the ROL fog lights wired up over the weekend and installed a 12k winch I had from a parts jeep in the bumper. Also fixed the blinker issues I was having and put in all new LED bulbs
  9. Probably easier to do this as a list of the parts I used since it’s not really a kit other than the fenders. Rear axle: sterling cab and chassis 10.5 from a 1995 ford f-350 7.3 dually Front axle: Dana 30 hp from a 1996 Jeep Cherokee. Front suspension: rough country 4.5” springs shocks and lower control arms. IRO adjustable track bar and rough country extended brake lines Rear suspension: stock mj springs and shocks with Barnes 4wd perches welded to the 10.5 spring over. Dually fenders: came out of Florida from a truck that was getting parted out. Unsure if they are JC Whitney or something else but they are for sure mj specific. Someone did fill in the fuel door so I used boat parts to add one back in. Front Bumper: arb from a 97-01 xj with a 12k badlands winch installed in it Wheels and tires: front wheels are from a newer jk with adapters. Rear wheels are just stock steelies with new but cheap mud tires. Brakes: 95-96 xj booster and master plumbed to mostly original lines with the rear prop valve deleted. I used a 91-96 xj brake pedal so I didn’t have to try to grind on the rod from the booster. that’s most of the details and I added all the pics I took so far. Eventual plans involve removing the worn out 4.0 and replacing it with a 5.3 lm7 and 4wd ax15
  10. I have a tan one in Ladson, SC. Needs recovered but good frame
  11. I have one $50 shipped. Parting out a couple 97+ xjs currently
  12. I have a complete set of blue plastics that I’d let go of if you can’t find just the one piece you need. Kick panels, rocker trim, an and b pillar trim. I think I have the rear carpet piece and plastic piece too
  13. It looks good from the firewall side. I don’t have the carpet out currently. I was going to offer the pieces you needed free if you cut them out
  14. I have a 93 2 door xj I am about to crush if that would help. I’m not all that far from you either (about 3 hours). I’ll have to make sure there’s no rust there but I’m pretty sure it’s solid
  15. I likely have one as well. I’ll look at my parts jeep when I get home
  16. Cover shipping and they are yours. Axle was going to scrap anyways
  17. I can take the ones off this axle. They are still good. Axle not so much
  18. I have a bunch of the fender braces
  19. I have an engine harness, automatic throttle body with the bracket and the TCU
  20. I think I have some left from when I used to make the harnesses. I just have to find them
  21. This a complete and total longshot but worth a try. Looking for a set of the jc Whitney dually adapters and wheels that were used to make a comanche dually. I was lucky enough to get a set of flares but need the adapters and wheels
  22. It’s very stable and balanced very well so it tows great empty or loaded with pretty much anything. My friend towed it with his Tacoma and we could barely even feel it back there. It’s also fairly light (around 1800lbs I think) and does have self adjusting drum brakes so it stops great
