88mjsally
    3
Everything posted by 88mjsally
  1. Major milestone achieved today. Drove the truck around the block for the first time! Drive pretty good other than being loud from no muffler. Brakes worked good after bench bleeding this morning then bleeding the whole truck. It also needs a windshield and rear window badly. Rear lights don’t work but it’s because I haven’t hooked up the wire for them yet. Overall good test drive though. I also replaced the drivers door with a nicer power door. Goal is to add power windows and locks since I have all the parts
  2. Got the booster and master in. I ended up using lines from a 95 and tying them into the factory mj lines that went to the old booster with a couple adapters. That way I didn’t have to mess with reflaring lines. Just have to get a bench bleeding kit tomorrow and I’ll install it for good. Also turns out the rear load valve was already bypassed. Going to try it as is and use the xj valve if it doesn’t work as well as I want. Also put the driveshaft in and did a bunch of little things trying to get it ready for a test drive
  3. Got the 93 axle under the Truck today with all new control arms, steering, shocks, track bar and brake lines. Ended up putting the steel wheels on it since I got tired of having to air up the crappy tires on the turbines and these tires are decent. Started messing with the booster/ master upgrade too but ran out of light. Using a 95/96 xj booster and master with a 93 xj proportioning valve so I can delete the rear load valve
  4. Got the axles pulled out of both the red truck and the doner xj. Supposed to rain all day tomorrow so Wednesday I’ll put the xj axle in the mj with all new control arms, shocks and steering
  5. I appreciate it. Yea that’s the plan right now. I’ll be working on all the body work over the next couple months then painting it
  6. I knew when I got the truck that the drivers door had contacted the fender at some point in the past. I thought the hinges were broken but turns out the bolts were falling out. Got a new fender on today and plan to pull out a door to swap on this week
  7. She’s alive!! New fuel tank, pump and the original sending unit went back in today. Also changed the injectors and fuel filter. Fired right up with no leaks just like when it was in the xj. Just need to add exhaust, a driveshaft and a bunch more to start driving but it’s getting there IMG_2526.MOV IMG_2526.MOV
  8. Throttle body came back in time for me to drive the truck home. Runs really good now and only needs some minor tweaking as well as a brake upgrade. I installed a new to me knakk tool box today and it’s much better than the cheap ranger one I had in it
  9. I have one from an 89
  10. Scored a pair of nos taillights today that will probably end up on this truck. Found them at a Jeep shop up north so I’ll post pics when I get them in
  11. yea I think I did pretty good for $250 although I think that’s what the guy paid for it complete😂
  12. Yea it was. I was pretty surprised to see it on a short bed. Limited slip as well
  13. Picked up a rear 44 and the rest of the black interior I needed for the truck today. Guy was tearing down a 87 chief to make into a buggy
  14. Well after being my daily for a few months the truck is broken again. One injector is not firing at all and another is barely working. Just took the throttle body off and it’s off to Holley tomorrow for 4 new injectors. Truck has run bad for a few weeks and got to the point when it wouldn’t idle at all. I’m graduating in a few weeks so the truck will likely end up having to be trailered home
  15. The engine was rebuilt with a fresh head and a terrible green paint job so that got painted Saturday and installed. Still have to take the valve cover off and paint that. Waiting on injectors now. Going to swap to the newer 95/96 xj brake booster as soon as it gets here. Plan to swap over the 2wd front axle from the xj over as well with the newer unit bearings. Keeping the truck 2wd since the xj was 2wd and I just don’t need a 4wd Comanche. I’ll be moving back home after graduation in December so I’ll try to keep updating this and get it back on the road
  16. Here’s the start of the obd1 swap where my dad and I started moving stuff over from the doner. Got the dash all in and all the wiring under the hood. Adapted the factory xj fuel lines to the Comanche hardlines
  17. Got the truck stripped on thanksgiving and all ready for the obd1 swap to begin. Damage was pretty bad but luckily it was contained to the hvac box area
  18. Bought this burned 89 over the summer from the same guy I got my long bed from. It’s been sitting for a few years and had a pretty bad dash fire in the hvac box. I decided I wanted to try to do an obd1 swap using a 93 xj I bought for $550 running and driving. Here’s pics from when I brought it home. Future plans include a black interior and fresh paint so pretty much what Jeep should have made in 93
  19. I haven’t had the time to make more of these recently, I’ve been focusing on graduating. Once that happens I’ll hopefully have more time. If not there’s another member I may turn the making of these over to
  20. I have a set for sale but they are pretty busted up. The drivers is usable but the passengers is pretty much just the housing. Have a bunch of nicer ones but they are all on complete headers or go to headers I want to make complete
  21. I’ll take a pic for you the week of thanksgiving if that’s ok. That’s the next time I’ll be at the truck
  22. I have a pretty nice used set that I’d let go of. I can get some better pics if interested. They are the ones on this truck
  23. I probably have that piece used if you'd rather go that route. I have one complete set that I'm planning to keep but I have a pile of extras too that id let go of
  24. 87 Quartz dash clock
  25. https://charleston.craigslist.org/cto/d/johns-island-1989-jeep-comanche/7401653034.html The guy I got my pair of 89 Comanches from is selling his other one. It’s a pretty nice truck overall if anyone is interested
