88mjsally
3
Everything posted by 88mjsally
The 89 lwb is back together but only runs when the key is held in the run position. I’ve changed the fuel pump and latch relays, the ignition switch, bypassed the ballast resistor, and changed the tps. Also changed the starter relay which was also wired incorrectly. All new fuses in the fuse block too. So I’m currently stumped as to what the issue is. Any ideas would be much appreciated
Bought this truck about a month ago after it had a dash fire. I’ve pretty much collected all the parts to put it back together so I’ll be posting that on here. The plan is probably to sell it after I put it back together since I really need a bigger truck to haul home projects. As fun as it is to have a fleet of comanches, they can’t really tow a car trailer safely
April 2021-88mjsally's 88 V8 Pioneer
88mjsally replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Thank you guys for the kind words! This truck sure has been a fun one although it’s been a pain at times. It’s sure come a long way from what I brought home 5 years ago -
“Custom” Nissan truck that had a body grafted on the back and a removable roof this came into a local junkyard
I have a manual Steering box in my blue truck but plan to put it back to power steering. It steered around pretty easy but I don’t have all the delete brackets for the 4.0
Pretty sure it was a mouse nest since the guy I got it from said the bed was full of leaves when he found it from sitting under trees. So I’m guessing mouse nest then he turned the heater on
89 long bed that I bought with fire damage from an hvac box fire. Plan to fix the damage and I will probably sell it after it’s fixed. The guy I got it from bought it from the original owner and then he drove it for about a year before the fire
Brought home this 1989 long bed 4.0 2wd today. It had a dash fire in the hvac box. Not sure what the plan is yet with it but it’s between parting it out and fixing it
Got a few more things today. XJ rear wiper deletes, 97+ 242 bezel, under column trim and ac knobs. Thanks eaglescout!
I have the fan on my parts jeep but I won’t be able to go pull it off for 2 weeks or so. I’m pretty sure I already sold the shroud from it
A College Students V8 Comanche
88mjsally replied to 88mjsally's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Took my truck to a car show this weekend and it turned way more heads than I was expecting. My dads orange truck still wins the award for guys stopping in traffic to look at it though lol. Lots of people asked about it and I talked to a few other guys with comanches and cherokees. It made the 5 hour round trip with no issues and I drove it 4 more hours back to clemson today. Just need to fix a header leak but that likely won’t happen till this summer -
I got the axle swap wrapped up on Wednesday and so far it’s doing well. I got the cut up yoke installed and bled the brakes. Had a minor issue with the yoke on the axle having a broken u joint cap retainer tab but I found another yoke which I swapped in. This axle will hold up much better with my v8 so I don’t have to take it as easy anymore -
I have a maroon tilt one for sale. $40 plus shipping. It does have a small piece missing from the housing but it still works fine and has a key. I can get some better pictures if you’re interested
I had my water pump pulley bolted on with 2 of the 4 bolts and forgot that I needed to get the other two. I was driving it to Home Depot to buy some lumber and lost power steering. Thought I killed the pump and started taking it out before I realized that the belt and water pump pulley were both missing. Found them on the road leading into the store and got it all put back together after buying bolts and locktite. I learned that if something is designed to have 4 bolts you should put all 4 in
I got the dana 44 installed in my truck today. Didn’t go exactly as planned but overall not too bad. Driveshaft was too long which I expected. I wasn’t expecting the yoke to be too long to I had to go get a junkyard one that ended up not working. I finally cut a spare one I found down but need to go get a new ujoint tomorrow for it. Just need to hook up the ebrake cables, bleed the brakes and install the driveshaft before I can road test it. Brakes are all rebuilt thanks to some parts from my spare dana 35 since rock auto sucks sometimes and sent some wrong stuff -
Jeep comanche trailer wiring harnesses
88mjsally replied to 88mjsally's topic in Vendors- members making products for MJs
Yes these allow you to plug in the flat 4 trailer wiring plug -
parts and deals on Market place
88mjsally replied to rylee144's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I’ve paid anywhere from $20-$75 for the 7 junkyard tailgates I found but most were at small mom and pop junkyards with no price lists. If I needed one and didn’t have so many, I’d pay $200 for a straight one from a junkyard -
Decided to test the pile of stock radios I had today from various junkyard Comanches and Cherokees. In the process I decided that I wanted to have a stock radio back in my truck so I picked the best one and put it in. Out of the 6 I tested all but 2 worked perfectly -
Got my truck all back together and running this weekend with the new hyper spark distributer. I just had to install a coil and coil driver then we cranked it up. It runs so much better now and I drove it 4 hours back to clemson with no real issues. I also got my new 44 all sandblasted and painted so in 2 weeks when I’m on spring break I’ll get the brakes rebuild and swap it in. I forgot to take more pics of the distributer install and wiring but I’ll try and do that this week -
Nos steering wheel and the guy even threw in an nos horn button to go with it! Just need to get nos hardware and put it all together to hang up on my wall
I forgot I already had taken pictures of it to post. I have two other longer mini consoles as well, this one is the shorter version
I have a pretty nice grey mini console. I can pull it out tomorrow and take some pictures
