ghetdjc320
  1. I’ll throw in my .02. On my first MJ I went with the JCR Vanguard. Nice bumper, well made but the design doesn’t fit the truck. I’m also not a fan of a winch sticking out on an MJ. After seeing a lot of the factory options, hidden winches and Mopar brush guards, I settled in the first gen warrior with shackle mounts. To me, it most resembles a slightly more modern but still factory option. The arb looks nice as well. It’s a thinner bumper than the warrior though and is more engineered to provide crash protection than off road protection. With the gen 1 warrior, there is no need to trim fenders or flares, and a set of stock Marchal fogs fits almost perfectly in a factory style position. I have that bumper still wrapped up sitting in my shop ready for my current build. I’m running the boostwerks hidden winch setup also and what a clean combo indeed. Both the warrior and arb are pricey bumpers. PS. The Hansen rear bumper is almost a perfect match to the front. But you have to call them to order as they don’t list the Comanche rear bumper on their sites
  2. My project “Tomahawk” is siting in Pea Ridge right now . Though I live about 9000 miles away. I’ll be back early part of next year for a few weeks and plan to get a game plan to finish it up. Lived many years in Bella Vista and Rogers too.
  3. Well, it’s always a gamble with used but I’d say the odds are in your favor vs aftermarket.
  4. Use a plastic safe electronics cleaner
  5. Go oem Mopar New or used. Much better than the aftermarket ones. Here’s a used one and it comes with the connector https://www.ebay.com/itm/196001898981?hash=item2da29fa1e5:g:EAwAAOSw-ZFlFDao&amdata=enc%3AAQAIAAAA4CH6huA0t1Dnlo7wIHfzMwW9dEs6HzT2YJt6M3OJ3jD2i%2FsfNUj4AB7ywbR5JNnG08Owgls8YiYOOt5xpgjgJqy6789MqXX2X9SYeBp3jdI9%2BndaCRcPeMLQjYnJiF%2B58qGUZGzNMdj6LvATA1kuPA%2FZ4jOLag4fzM1eGNUBZsDIiaO6fBH8cS%2FcbeF1utnPBL0Bx6xsUwzgOkd6n5Xs%2FVT%2FaPBTLfDL5ySqrv7XnLVuH0tKISWMcy3qf9lU1arszcrsi7diErYvzHL%2FjiJYdSGjgaJbwFhfwb%2FPzS6twL%2BJ|tkp%3ABFBM-pGzjeFi
  6. Try to find an oem Mopar fan. Moves a lot more air than the aftermarket replacements. The stock wiring should work if it’s all in good shape but it was always marginal at best. You need a solid 30amps for the fan to run at full rpm and therefore get the full cfm needed. Many will swap on all e fans and wire them up using a relay to the battery. But many fans’ CFM are rated at alternator voltage which will typically be around 13.8-14v.
  7. I was just thinking about the linkage but good point. The ZJ box could be an upgrade depending on what you’re looking to accomplish
  8. Considering that my local auto glass shop in the middle of the pacific has them in stock, I’d say there are plenty still out there. Maybe have to cast a wider net though. Have you tried auto body/collision shops? But as a general rule, there aren’t many shops who sell just the glass online.
  9. Grab the spicer/dana ball joints and the moog ZJ tie rod. The rest or the components such as drag link and tie rod ends just use moog replacement MJ/XJ parts. The ZJ tie rod is where the strength comes from. Ball joints are the same but best to grab the spicer ones.
  10. I ran nexen roadians in that size on a stock 4wd with zero rub. In addition to sidewall “lugs” and patterns, there may also be slight variations in where everyone’s steering stops are set on the knuckle
  11. I should probably qualify my experience with plastic paints and dyes (including sem), I have done all version of the above prep work with my interior plastic pieces. It helps for sure, and yes, it will hold the color if you don’t actually put any wear on the item. But I’m talking about being able to actually scuff a panel with the abrasive tread of a shoe and not peel off the color layer revealing the base material color. No product other than the Eastwood stuff has accomplished that and even that stuff has its limits. It’s the closest thing I’ve seen to actually altering the material color itself though while still being a spray-on coating. Kind of like the difference between acid-staining concrete or using some kind of floor paint, one penetrates the substrate and the other just adheres to the surface. Proper prep will make any product work the best it can. Try to follow the manufacturers TDS if they wrote one. Again, I’m referring to wear-resistance and not how well a product color matches a factory trim color or how long it adheres to a panel.
  12. The ZJ tie rod is solid bar vs the hollow ones in MJ/XJ/TJ’s
  13. I will say that personally all the plastic paints/dyes have let me down except for the Eastwood plastic restorer. It’s meant for black plastic but will convert other colors to black as well. It’s a pretty flat finish but you can get it to about a semi gloss if you keep adding layers. This stuff “burns” into the plastic quite well and I haven’t had it come off anywhere. I went with original black plastic pieces for the kick panels and door sills but the b pillars and back of can trim were all original grey panels. I used the Eastwood coating on all the pieces for a good match. Really looks great and held up perfectly. No matter how I prepped or what products I used, I could never get the sem to give me any durability. That being said, the sem did give a great finish aesthetically
  14. Find out what they tightened. The stock bar itself is solid so knowing what they tightened will help you know what needs to be fixed
  15. Curious what exactly they “tightened”. There is a nut on the tie rod end side that goes through the frame side bracket and also a bolt and flag nut on the axle side. They don’t normally some loose though. I could see a bad bushing, bad tre or a worked out axle side bolt hole. What track bar you may need depends a lot on lift height and tire size. The whole point of the track bar is to keep your axle centered with your truck and keep the suspension in line.
  16. Warrior also makes a nice set. Part number 90783
  17. 1-2* below the ideal angle for your pinion depending on your setup. See the article posted above for reference on the ideal angle based on the type of driveshaft you’re running
  18. You can get most stock style parts from rock auto. General spring can get you original style springs but you may sit a little higher than stock with those. You could go with possibly the XJ upcountry front springs that are about a 1” lift and they *may* match replacement rear springs. You may have to play around with a small spacer though to get it back to factory rake. Was the steering and track bar modded with the lift? Are there any control arm drop brackets in place?
  19. That’s a clean install, very nice
  20. I’ve also ordered plenty from them and boltdepot.com
  21. On both my TJ and WRX I went with 5% ceramic tint. They have a clear ceramic film here they recommended and installed in the TJ. Seems to work very well as it cuts down the heat quite a bit but I can notice the slightest color variations through it when wearing polarized sun glasses.
  22. This article gives a thorough explanation and includes videos and pics for reference. May be really helpful moving forward https://4xshaft.com/blogs/general-tech-info-articles/driveshaft-angles
  23. I used the same method as above once confirming the correct pushrod length. Set to zero lash then go a bit further (in my case that was one full turn)
  24. Get a 7 blade mechanical fan for a 4.0 on eBay, the Napa/Hayden hd clutch and run an oem Mopar 2001 XJ 10 blade e fan as your aux fan. Also get the mech fan shroud. I’ve been down this road and that’s the only combo that really works. The MJ’s stock electrical doesn’t have the capacity to run 3 e fans of sufficient cfm to replace the stock setup at alternator voltage (+/-14v).
