Dana 44 Rubicon axles under MJ
ghetdjc320 replied to Bugout 1's topic in MJ Tech: Modification and Repairs
You can use a driveshaft yoke adapter or swap the yoke on the pinion. As for brakes, you’ll want to swap the prop valve to something like a ZJ or and adjustable valve like the Wilwood one. Rear disks need a bit more pressure than drums. A dual diaphragm booster is helpful and stick with a master cylinder with between an 7/8 to 1” bore. Are you planning to swap over the compressor for the lockers? -
Renix and HO bored throttle bodies available!!
ghetdjc320 replied to cruiser54's topic in MJ Tech: Modification and Repairs
Keep in mind that the taper improves velocity. When Painless made their “perfect” 4.0 throttle body, they went with a tapered design that necked down to 63mm which is the manifold inlet size. -
Cable Transfer case shifter
ghetdjc320 replied to 89 MJ's topic in MJ Tech: Modification and Repairs
I’m running the Novak cable shifter on my current MJ. Works well -
Ticking noise after engine is off
I’ve always heard it coming from the lifters in the middle 4.0 as they bleed out and settle after running. But every 4.0 I’ve ever had makes that sound -
You can ship a Dana 30 as loose cargo through FedEx or ups ground (under 150lbs). Take it off the pallet and shrink wrap it. You could save even more if you remove the knuckles and ship them in a flat rate box. You can use pirateship to get good ups rates unless you already have an account.
But before you start, make sure you completely bleed out your new master cylinder
Could you post some pictures of what you’re finding? Is this for your 89 MJ in your sig?
Do you still have the rear load sensing valve? When you replaced your master, did you bench bleed it before install?
ax15/np231 rebuild questions
ghetdjc320 replied to watchamakalit's topic in MJ Tech: Modification and Repairs
I went with the crown ax15 kit several years ago. Worked fine. My current ax15 I’m sending off to Marlin Crawler to build as they are pretty much the only company out there that produce upgrade parts for the ax15 and can make them incredibly stout. For the NP231 I got a kit from Novak. Good quality seals -
Once you try to fill 1/4” or more of a hole or gap, some sort or reinforcement is advised. You could use a good short strand filler like evercoat fibretech using the tape method advised above after applying por15 black. But first, keep at your seam sealer and strip it all out. I suspect you will find a TON more rust hiding in the atrocities know as MJ factory spot welded seams. If you don’t get it all removed, you will never be able to get to or eliminate that cancerous hidden rust.
Do yourself a favor and keep removing all that seam sealer. Especially the this giant blob in the corner. A multitool with a caulk blade works exceptionally well for removing the old sealer. I suspect you will find a lot more problem areas
Blower switch - all or nothing
ghetdjc320 replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
Also check the connector on the blower motor switch. -
Adjustable track bar out of adjustment!
ghetdjc320 replied to Warthog's topic in MJ Tech: Modification and Repairs
You can use a ratchet strap to recenter it. But you shouldn’t be setting your track bar in final position until you get all your weight in the truck. -
Por15 silver is your friend. Mask off the back side of the holes first.
Advice on 2006 jeep tj
ghetdjc320 replied to MariaManche's topic in MJ Tech: Modification and Repairs
The Mopar opda units are known to be defective. The crown opda is the upgraded version. -
New Comanche owner, Lift tips?
ghetdjc320 replied to Backpacker's topic in MJ Tech: Modification and Repairs
If you want to go 4” lift, you’ll need to consider your brakes, steering and suspension geometry. But if a 2” lifted Hilux struggles, an MJ on 32’s won’t do much better. For your commute I’d look more into traction aids (lockers) and a good front bumper. -
I ended up using the door portions of the weatherstripping but went with some nos Mopar seals for the cab opening. Perfect fit and worth tracking down.
Bashing on our mopars again -
How much should I pay for Rubicon JK axles?
ghetdjc320 replied to jakesmog's topic in MJ Tech: Modification and Repairs
They should both be 44’s with e-lockers. Should be HD44’s with 8.9” ring gears also. Not bad axles but not a straight swap by any means. Different bolt patter at the wheels, different width and none of the bracketry will fill the MJ. I’m no pricing expert but I’d be looking maybe in the 1k range for both if they were in good shape. I wouldn’t want them if they had been running 37’s though. Not that they can’t handle them but it’s far more likely that someone had been abusing them. -
X3 to the above. -
BDS, Zone and Fox are all related companies. I’ve had good success with Zone and BDS and have run both. Anything over about the 2.5-3” mark is where you are going to need to start looking at many other factors, steering geometry, brakes, adjustable control arms, track bars etc. a simple puck and shackle lift along with some decent shocks and 31’s is a very good route
